Question about Canon PowerShot SD600 Digital Camera
The camera will not turn on. We have a fully charged battery and also tried turning it on while attached to the computer. Any suggestions?
  • 159 Answers
SOURCE: battery is fully charged but camera will not power up
Check you manual .. is there a 'back up' battery (coin cell ??) .. if not then the battery is dead (rechargeable batteries do not last for ever) .. try a brand new battery
Posted on Mar 22, 2008
t00nz
  • 4738 Answers
SOURCE: Canon Powershot A540 - Change Batteries when Batteries Fully Charged
Some of The Canon Powershot A530 and A540 cameras are subject to an advisory recall. Seems that a small spring on the battery compartment door can short out the batteries. Suspect this of yours, in that you mention that your batteries aren't lasting long. If your camera is on the list, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following link for more info:
http://camerarepair.blogspot.com/2007/12/canon-a530-a540-with-short-battery-life.html
Posted on May 28, 2008
darntoothysa
  • 489 Answers
SOURCE: Battery Fully Charged Camera Won't turn on
Hi
There are several things that could cause this.
1- Check the battery door indicator switch under the battery door and beside the memory card slot. Is the little black switch damaged or missing? Try pressing down gently using a pen it with the door open and then press the power button. Does it turn on?
2- The fuse has blown and needs to be replaced. Offhand I don't recall where it is on the SD600 PCB or how hard it is to solder on a new one (depends on if its tricky to get at or not). Good thing is fuses are really cheap.
3- Other power problem with the PCB due to corrosion or impact damage. The PCB or 'motherboard' of the camera will need to be replaced.
A couple solutions would be to either buy a defective camera online and make one good camera from the two if you can do that sort of thing yourself, or secondly have it repaired by somebody.
Don't bother trying to send the camera to Canon if it is out or warranty (though you can call them and verify what I'm about to say) because they will want $150+ to do the repair for you. Parts are not cheap to buy from them.
I know of one very affordable digital camera repair business... because I own it. The name is Darntoothysam, feel free to check us out, we are on that big auction website also (I don't plug their name for free), our seller ID is 'darntoothysam'. If you Google "darntoothysam" you will find us.
If we can help with your repair then please let us know.
Hope this helps,
Thomas
Posted on Nov 11, 2008
  • 5 Answers
SOURCE: My camera won't turn on. It is an older cannon rebel sx (8mp).
I just got off the phone recently with Canon. I explained the problem to them and they stated that it appears it is due to the cold weather. I saw some stuff on these posts about Christmas Time, etc...They said that most of the time the camera will be ok after it thaws out, but some issues can be caused because of this. One of them is total lack of power. They said that the camera I have has a minimum temperature that it can handle of 30 degrees. This can cause the LCD to freeze, can cause short circut problems, etc...Thus leaving your camera totally in-operable.
The technician tried to help me first rule something out. He had me REBOOT the camera....seems odd to do that if there is no power, huh? Here is how I did mine....
Power on the camera....Remove the battery...then the Disk battery....leave the battery door open for one full minute. Now turn the camera off.....put the disk battery in, then the regular battery....close the battery door....power on. If you have power and your LCD monitor goes on it will say something like 00007 or something like that.
Unfortunately.....Mine didnt. So they are sending me info on my email to send in my camera. It will need to be repaired/replace the parts etc...
I hope that your cameras end up working. They guy from Canon suggested that in the cold weather while carrying it, keep it under your shirt close to your body to keep it warm, dont change lenses in the cold air, and if you are photographing an outdoor sporting event and its cold enough for you to be covered up, then do the same for your camera.....he himself wraps a hand towel around his whole camera except the end of the lens and the view finder (the one you put your eye up against, not the LCD) Wrap a rubber band around it to keep it in place on the lens and unit.
So....like i said, please...I hope this helps.
Keep me posted!!! Would love to hear positive things that your camera has started working again.
Julie
Posted on Jan 09, 2009
mannforever
  • 23 Answers
SOURCE: Camera will not turn on. Battery fully charged;
You can give it to an expert for repair, he can repair it for less as there must be just a fuse problem, which can be fixed for a very less amount.
Posted on Aug 11, 2009
I have a brand new Nikon D3100. The battery was fully charged and placed in the camera. I took about 4 photos, and then turned the camera off. When I turned it back on the battery wasn't working to...
The solution to your problem is simple, Kathrynbax.
The battery never comes in fully charged. It's always charged only so you may be able to check if your camera is working. I suggest, you take out your battery and put it to charge for exactly 90 minutes as the manual says. Then I'm sure you won't face any such problems.
Hope this solves your problem.
Good day!
Rebel
Sep 17, 2011 | Nikon D3100 Digital Camera
I was using my Nikon coolpix s205. after taking pictures, it went on standby mode and when i was going to use it again, the monitor was just black and i cannot take pictures anymore. i tried to turn it off...
All I can suggest is 1) Fully charge the camera. and 2) Make sure NO cable is attached to the camera when you turn it on.
Background; Lens motors use lots of power and with a dead battery they do not work very well (stuck) When you have a cable attached to the camera the monitor WILL shut OFF.
May 02, 2017 | Nikon S205 Digital Camera
My camera is not working. my camera does not turn on and when it does it turns off
Welcome to FixYa.
For camera's that won't turn on or will turn on but automatically turn off. First thing you need to check if the battery was fully charged.
Second, check if the battery was placed in right direction.
If those two solution was done, You need to removed the battery and re-insert it again.
Also try to install new fully charged battery.
If this issue will continue you need to contact your service center because this might have a camera malfunction.
Feel free to send us your comments or suggestion if this solution was helful.
Thank you for using FixYa.
Apr 07, 2011 | Kodak Easyshare M893 Digital Camera
After charging my battery I installed the battery and turned the camera on. The lens came out and the screen came on. All of a sudden the screen turned solid white and faded to black. Now the camera will...
Hi there please follow the steps and let me know the result.
1. Ensure batteries are fully charged.
2. Look carefully between the lens and the camera body for any sand, dirt or any damaged etc.
3. Try turning the camera with the lens facing down and shake to dislodge anything stuck
4. Try removing batteries and memory card, wait 5 minutes and refit the battery only.
5. turn on camera and see.if working then fix the memory card & again turn on the camera. If working then fine . Otherwise format the memory card and fix back in camera again & try. Make sure before format the memory card take a back up all photos in your computer then format. If no luck then reset or restore the camera setting by pressing Menu key for 2 sec .. in not done the press both Menu & self time key for 2 - 4 sec.
i hope it will gives you success. Thanks & Before you leave, if you have found my information helpful and if you haven't already done so then please press the ACCEPT button, this is how I am paid for helping you today. POSITIVE feedback & bonus is appreciated
Apr 23, 2010 | Sony Cyber-shot DSC-W50 Digital Camera
My lightly used nikon coolpix s570 has developed a power issue. Meaning that with a fully charged battery, the camera won't turn on. sometimes removing and reinserting the battery will get it to turn on....
If you have a second battery, fully charge it and try it. If you do not have a second battery, it make either be a defective battery or a battery that is not properly charging. Try powering on the camera until you get it powered up, either by reinserting the battery or turning it one. Then purposely use the flash and focus until you totally exhaust the battery. Then charge it for the recommended time. Try the battery in the camera once more. Also look into the battery compartment and make sure there is no corrosion. After these actions, the only other thing I could suggest is trying a new battery or sending it in for repair. Usually it is the battery though.
Mar 22, 2010 | Nikon COOLPIX S570 Digital Camera
Can't get the camera to turn on.
It sounds like a repair, therefor I have attached the KODAK contact at the end of the this solution. But before you call, here are a few steps you can try, I hope it will work.
1. Make sure you will install a new or fully charged battery/batteries into your camera.
2. Clean the battery contacts.
a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth.
b. Reinstall the battery/batteries into your camera. Please make sure that you are installing a fresh/ fully charged battery
c. Without the memory card, turn your camera on.
In order to organise your repair or Trade up please Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Dec 07, 2009 | Kodak Easyshare M753 Digital Camera
Should the power light be green or red, when I turn camera on it shows a green light then turns red
Red light indicates that the camera is out of charged., Try to charged your battery for 3-4 hrs if you encounter flashing red on a fully charged battery you need to call kodak 1 800 235 6325 ext 12
You can charged you camera using 5V AC Adaptor or a USB cable taht attached into the computer
Nov 16, 2009 | Kodak EASYSHARE M1063 Digital Camera
I have a sony dcr-dvd108. the battery is fully
it might be battery to used and it's charging quick and loosing power to quick. have tried to change battery for new
Aug 24, 2009 | Sony Handycam DCR-SR300 Camcorder
Rebel XS ERR99
This is something I found when googling your problem.
Thank you for contacting Canon product support. I'm sorry to hear that
your EOS 10D is displaying an "ERR 99" message.
To isolate the cause of the issue, we suggest that you do the
following:
1. Turn off the camera.
2. Remove the lens, battery, and CF card.
3. Allow the camera to sit without power for approximately 20 minutes.
4. Insert a fully charged battery, and turn on the camera.
Does the "ERR 99" message appear? If it does, then the camera should
be serviced. If it does not, then please proceed to the next set of
steps:
2. Insert the CF card.
3. Turn on the camera.
4. Format the CF card in the camera.
Does the "ERR 99" message appear? If so, then the CF card is the most
likely source of the issue. Try using a different card.
If the message does not appear, please complete the following steps:
2. Clean the lens contacts by gently rubbing them with a pencil eraser
or soft cloth. Be careful that you do not let any debris fall into the
camera body.
3. Reattach your lens.
4. Turn on the camera.
If the "ERR 99" message only appears when one particular lens is
attached, then that lens should be examined by a service technician.
If you see the "ERR 99" with a different Canon lens attached, then the
camera should be serviced.
May 25, 2009 | Canon Cameras
Sony handycam video hi8
Take the battery out and turn selection switch to camera and then turn it off. Put the battery back in and its working again.
if that doesn't work try
Try smacking the side of the camera relatively hard with the palm of your hand. Eject the tape and reinsert. You may need to do this a couple of times.
good luck
please mark the post with a fixya
Nov 26, 2007 | Sony Handycam CCD-TRV108 Camcorder
Canon PowerShot SD600 Digital Camera Logo
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
