Question about Saeco Odea Giro Plus Coffee Maker
Coffee is dripping from the side and not from the two hoses
  • Saeco Master
  • 1,711 Answers
Behind the coffe tap their is special teflon hose which is secure on the tap with a special pressure conection easy secured. This migh be lose or even the hose to be bend with hole or even cut and you will need to replace it or just to put it back together very easily.
Posted on Feb 13, 2010
The water in my Nespresso does not come through the from where the pod is, but fill the drip tray! what is wrong?
I had a coffee machine that was letting out the water instead of making the coffee it turned out the hose that leads the water was disconnected from the source if you can get to the hose you may find the problem good luck
Jan 03, 2015 | Nespresso Coffee Makers & Espresso...
Coffee coming one side only of spout
There are two ways to overcome this uneven drip of coffee into the cup.
1- Make sure the machine is placed on a level counter top. The coffee drips as a gravity flow. Machine placed on a tilted surface will allow coffee flow more on the tilted side.
2- It appears the coffee faucet outlet has not been cleaned/flushed with any coffee cleaners or descaling solution. Clean the coffee outlet as following:
* Prepare two or four cups of Baking soda solution.Fill the Baking soda in water tank and make few espresso, using the preground cycle.
** Then use two to 4 cups of descaling solution and repeat the process making several espresso.
Oct 14, 2014 | Gaggia 74845 Platinum vision coffee maker...
Coffee maker won't turn on.
The problem is often that the machine develops a leak in the hose that is rightover the transformer...the water drips onto the transformer and kills that...then you have no power to run the machine.
Here is a tip that I wrote about this problem...
Keurig OneCup Coffee Brewer will not turn on
heatman101
Jun 25, 2011 | Keurig Elite B40 Coffee Maker
The coffee side has started leaking profusely from the top, back of the water area when brewing.
There is a red hose that connects at the back and top of the unit. Make sure the hose has not come undone and also check that the top lid with the holes is not blocked with coffee grounds. However, the most probable problems will be the hose otherwise you will mostly have steam coming out the back.
Hope this helps!
Dec 07, 2009 | Krups XP2070 10 cup Coffee Maker/15 bar...
Doesn't drip through. Don't know where the coffee water went to?
When setting up a new machine, it requires 2 full decanters of water to be poured into the machine. After you have done this, then you plug the machine in and turn on the vacation switch on the side of the machine. After 15 min, then you will pour in 4-10 cups of water and it will force out the hot water from the tank in the back and brew the coffee. If this doesn't correct the problem, then please call customer service with the model and date code.
Sep 11, 2009 | Bunn NHB Coffee Maker
Baby Gaggia Dose leaks
On the gaggia clascic there are 2 hoses in the back above the drain tray, are those in the water reservoir? If yes then there is a broken hose on the in side of the machine.
Aug 12, 2009 | Gaggia Baby Espresso Machine
Saeco Odea Giro Plus Coffee Maker Logo
148 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
83bj60
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
