Xerox phaser 77600n
Imaging unit is detected (replace the imaging unit 108R00713) error massage appier on screen. any solutions?
  • 19,396 Answers
First try disconnecting your pc from power cable for 10 minutes and disconnecting scanner from pc. Then connect back everything and see if it works (this is called hard start). If this does not work then disconnect 77600 from pc. Uninstall and re-install all xerox drivers and software.
good luck
Posted on Feb 21, 2008
Replace drum in xerox phaser
asic technical parameters forToner cartridge chip of Xerox Phaser 3450B:
chip-b.jpg" ]
Version: No area limited
Yield: 5,000-10,000.
Printers Model compatible: Xerox Phaser 3450B
Toner cartridge Model: Xerox 106R00687-BK and Xerox 106R00688-BK.
Manufacturer regulations pages yield ofToner cartridge chip for Xerox Phaser 3450Bis 5,000-10,000 then printer do not print andDrum chip for Xerox Phaser 3450Bhas mission paper pages count.You should resetDrum chip for Xerox Phaser 3450Bcaused by following reasons:
And then, you can choose one in three following plans: replace Toner cartridge, replace Drum chip or reset Toner cartridge chip.
1.Replace new Toner cartridge for Xerox Phaser 3450B:
- If you choose plan replace Toner cartridge then cost is too high. Each Toner cartridge for Xerox Phaser 3450B (Xerox 106R00687-BK and Xerox 106R00688-BK Toner cartridge) costs about $150 - $200
- With replace new Toner cartridge solution is not optimal, because the price is quite expensive.
- When Xerox Phaser 3450B shows errors about computing limits of Toner cartridge chip, you continue to replace new unit.
2.Replace new Toner cartridge chip for Xerox Phaser 3450B :
khe-chip-b.jpg" ]
- If you choose plan replace Drum chip then cost higher than reset chip. EachToner cartridge chip for Xerox Phaser 3450Bcosts about $6 - $10/color.
- With replace new Toner cartridge chip solution is cheaper replace new Toner cartridge.
- When Xerox Phaser 3450B shows errors about computing limits of Toner cartridge chip, you continue to replace new Toner cartridge chip.
3. Reset Toner cartridge chip for Xerox Phaser 3450B
If you choose plan resetToner cartridge chip for Xerox Phaser 3450Bthen that is best plan. It cheaper than replace Toner cartridge or replace Drum chip
The phenomenonToner cartridge chip for Xerox Phaser 3450Bout of count are printer do not print and display error on the LCD monitor:
-"Drum low", "Drum eppty", on monitor laptop or desktop appear yellow exclamation mark corresponding color, on monitor printer report Drum empty.
-"Tone life end", "Replace new unit"
- "The x unit an error". In that "x" is color of Toner cartridge or code of Toner cartridge
How to fix the errors:"Drum low", "Drum eppty", on monitor appear yellow exclamation mark corresponding color,"Tone life end", "Replace new unit", "The x unit an error"? cheaper, the most effective.
We use unismart device toreset Drum chip for Xerox Phaser 3450B
Unismart is a device reset Drum chip. Unismart can reset for many Drum chip of manufacturers: Samsung, Hp, Canon, Epson, OKI, Xerox ...
Unismart system is designed to offer a complete solution for writing, resetting, testing various chips with the combination of Unismart Box and Unismart chips. Unismart include: unismart box and test head, power adapter, Data wire, flat writer.
unismart1.jpg" ]
Test head is used for data transmission between Unismart Box and Unismart chips. There are 20 types of test heads designed according to different chip shape, which can be used for operation on all chip models that
current Unismart system supports. Please choose the right test head in accordance with the PCB code. Some PCBs share a same test head, which is clearly indicated in the chip compatible list.
In Case You Still Having Problem Then Follow Us For On :Xerox Printer Support
Jan 23, 2014 | Xerox Phaser® 860, 8200 Standard Capacity...
I have a Xerox Phaser 6360 with a ram error what could the problem be?
Are you sure it is not a NVRAM error you are recieving?
If yes, remove the IMAGING UNIT.
Close the door and Power On.
Msg gone? If yes, replace IMAGING UNIT.
If no, remove the FUSER unit.
Close the door and Power On,
Msg gone? If yes, replace FUSER.
If not, it is the ENGINE BOARD.
Oct 24, 2012 | Xerox Phaser 6360 Laser Printer
Xerox phaser 7400 giving error - replace imaging unit- what solution now?
Did it specify a color you should replace? The machine has 4 image units (CMYK) each with a different part#. Replacing them is easy, no tools required. Open the top door, lift out the entire image unit, move the toner over to the new unit, and lower the image unit. Here are the part #'s for the 7400 for each color. Iteminc.com has these online.
C - 108R00647
M - 108R00648
Y - 108R00649
K - 108R00650
Good luck, hope this helps. Thanks for using FixYa!
Aug 05, 2011 | Xerox Phaser 6350/YDT Laser Printer
Xerox phaser 7760 saying "non-phaser imaging unit"
There is a snippet on the Xerox website to solve imaging unit recognition problems, link below. http://www.support.xerox.com/support/phaser-7760/downloads/engb.html?operatingSystem=winxp&fileLanguage=en_GB Usually this problem only occurs if the NVRAM has been reset or the engine board has been replaced without backing up the NVRAM. You can download the snippet to your printer through Centreware or by downloading the 'File Downloader' utility from the same page above.
Hope this helps.
Jan 09, 2011 | Xerox Phaser 7760DN Laser Printer
What is error code 941 on a Xerox Phaser 7400?
www.support.xerox.com -phaser 7400- support -fault code-941 says cyan or magenta toner failure, but the solution says to
1. remove & reinsert the cyan or magenta imaging units.
2. replace imaging units .
check out the site to see if helpful
Jul 01, 2010 | Xerox Phaser 7400DN Laser Printer
Xerox phaser 6265 displays engine service 8300
From the service manual:
Code 83: Engine NVRAM is corrupted or receiving wrong data from a CRUM.
1 Cycle power to the printer. Does the error still appear? If so, go to step 2.
2 Remove and reinstall the Imaging Unit and Fuser Assembly. Does the error recur
after the power has been turned off and then on? If so, go to step 3.
3 Replace the imaging unit. Does the error still occur? If so, go to step 4.
4 Replace the fuser assembly. Does the error still occur? If so, to to step 5
5 Replace the EEPROM board. Does the error still occur? If so, replace the Engine Control Board.
Jun 23, 2009 | Xerox Phaser 6250 Laser Printer
Phaser 7300 asking for Imaging Unit
There is a spring on the waste section of the imaging unit that often pops off. When that happens it will not clear the replace imaging unit message. There is also a software patch on Xerox.com. Takes some searching to find.
Aug 11, 2008 | Xerox Phaser 7300DN Laser Printer
Xerox Phaser 7300 Error U20
1. Contaminated or damaged Imaging unit contacts. - Remove and clean the contacts and inspect for damage.
TROUBLESHOOTING TIPS AND HINTS:
Imaging Unit Failure message occurs because the printer cannot detect imaging unit motion, up-and-down. The Transfer Belt drives this motion, and the Drum Contact Assembly detects it. 1. Swap the Imaging Unit Cotact blocks between two imaging unit positions. If the problem follows the Contact block, it should be replaced. 2. Open the Top Cover and defete the top cover interlock switch. The color imaging units should raise in succession, cyan, magenta, then yellow, and then all lower at once. If one or more imaging units do not raise smoothly or drop prematurely then replace the Transfer Belt assembly.
Apr 29, 2008 | Office Equipment & Supplies
181 people viewed this question
jasbo
jasbo
