Question about HP Pavilion dv6000z Notebook
HP laptop acts like keyboard is locked when screen is opened fully? what gives . I get nothing I try to push cap lock key and the light will not illuminate. I think the keys are lock???
  • 30 Answers
Is there a button that says number lock if there is (which a computer should have unless it's from 1987) press it.
Posted on Feb 06, 2010
MY CAPS LOCK KEY ON the HP g62 is inTERMITTENt. please help
Hi
Since you have done a full power recycle - my usual first port of call - then I can see only one real alternative, and that is to replace the keyboard.
A service manual can be downloaded in pdf format from here:
http://www.hp.com/ctg/Manual/c02542102.pdf
which gives full details on how to replace the keyboard.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Mar 01, 2015 | HP Computers & Internet
I have an hp G42 notebook when i hit the power button i hear it turn on but nothing happens only the caps lock key light begins to blink
hp blink error code:
caps lock blink once: cpu error
caps lock blink twice: bios problem
etc,,,,
please, what is the numer of the blink ?
Feb 14, 2014 | Computers & Internet
My led indicators for caps lock num lock etc not workinh in my lenovo G570 laptop
Hi, If you are using a keyboard that is wireless im sure you just have to change the battery on the keyboard.
However if the keyboard is connected to your CPU, then depending on your keyboard model, you may have to turn F LOCK (F Lock Light on) to access system key commands if they are labeled on the front of the keys, such as num lock , scroll lock and print screen.When you click on the Flock, the lights are either supoosed to click on or off.
view the keyboard status lights by using the On Screen Display (OSD) option, Ensure you download the software ,
from your start menu do a search for your keyboard, on th key tabs setting,
its important to make sure that the correct model number is entered,
double click on the light you wish to change, in the Reassign a Key wizard,
clear the Displays (key name) status on the screen check box to disable the on-screen display, or select it so that a check mark is in the box to enable it, and then click Finish.
HOPE THIS HELPS.
Jan 26, 2013 | Computers & Internet
Caps lock light flashing and laptop not responding
Hello.
Disconnect all power. Flip the laptop to unlock and remove the battery. Reinsert and lock the battery. Power on, again.
Hope this helps.
Jan 05, 2012 | Dell Keyboard for Inspiron 1300 B120 B130...
Compaq 6735s notebook pc goes to HP screen, but wont boot
First you need to determine how many blinks you are getting when you try to power on the laptop.
Check the blinking codes below and reason behind that for HP Compaq laptops
Blinking battery power LED Battery Insufficient charge on the battery
Blink: 1 - Caps Lock/Num Lock - CPU CPU not functional
Blink: 2 - Caps Lock/Num Lock - BIOS BIOS corruption failure
Blink: 3 - Caps Lock/Num Lock - Memory Module error not functional
Blink: 4 - Caps Lock/Num Lock - Graphics Graphics controller not functional
Blink: 5 - Caps Lock/Num Lock - System board General system board failure
Blink: 6 - Caps Lock/Num Lock - BIOS BIOS authentication failure
Plz get back so I can suggest you the steps to resolve the issue.
Dreamkam
May 24, 2010 | HP Compaq 6735s Notebook
Meaning of indicator lights on wireless receiver
I concur 2/3's with yooperbud.
1 = System is connected and working
A = Cap locks On= Cap lock is on. Off = Cap lock is off.
F = Function Key usage. On = I'm going to use the alternative fuctions of the F keys as programmed in the Keyboard settings. Off = Your using the standard features of the F keys.
Dec 31, 2008 | Microsoft Wireless Optical Mouse USB...
How do I get a "CAPS LOCK" indicator or light to appear?
Most keyboards now a days usually tell you on screen whether or not the caps lock is on but its possiblbe that when you press the key yowards the left or right hand side a light goes on or possibly in the top center if this is not the case then you may have a faulty keyboard.
Nov 27, 2008 | Microsoft Wireless Laser Desktop 4000...
Laptop will not respond
It sounds to me that you may have an issue with the keyboard itself, as most BIOS will stop on a keyboard error unless told otherwise. But, this could be a malfunctioning keyboard, or a disconnected keyboard. 1 way to test either is to press the caps lock, num lock or scroll lock keys and verifying the corresponding light turns on and off with the button presses. If they do not respond, it's likely the keyboard has become disconnected internally. Other issues may also cause this to happen, but they are harder to test for. If it does respond, then it's more likely to be a keyboard failure, and a replacement of the keyboard may be required.
Hope this helps!
-Backu
Jan 16, 2008 | HP Pavilion ze2000 Notebook
My typing goes uppercase without hitting the caps lock
I have the HP Pavilion and cap locks does the same thing.
THIS WORKS EVERY TIME. Hit both the right and left shift lock simultaneously about 5 to 10 times. It immediately disengages the cap locks. It is a little bit of a hassle, but I'm just used to it. It may happen 3 times per week, but I LOVE the machine, so I just fix it this way!
Oct 20, 2007 | HP Pavilion dv8000z Notebook
HP Pavilion dv6000z Notebook Logo
140 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
