Question about Humidifiers
I have a moist air ma08000 humidifier and have replace the filter and still get a error code of CF. How do I get the code to go away
5 Suggested Answers
SOURCE: Kenmore 15408 Humidifier How to Reset CF
Per the owner's manual, you simply unplug your device for 30 seconds. Upon plugging it back in, the CF notification should be cleared.
This assumes you have also changed the filter, of course.
Posted on Sep 13, 2008
SOURCE: tanks not draining
You may be over-tightening the caps. It's tempting to over-tighten because it's a big tank of water that you're about to turn upside down! I had the same problem and the fix turned out to be just that - take the tank(s) back out, loosen the caps (hear the Ssszzzzz as the vacuum breaks), now tighten the caps again, but just enough that the water doesn't leak, and no tighter. Get the cap snug, but not so tight that you couldn't turn it some more. Do it over a sink the first couple of times until you get the feel of it.
Posted on Dec 09, 2008
  • 189 Answers
SOURCE: Not using water, filters are dry, doesn't humidify air.
Check your water supply. Make sure the valves are open and/or not blocked. You could have a blocked orifice in the water line by the solenoid valve. Check to see if your humidistat is set high enough. When you replace the water panel could you have accidentally disconnected a wire. Is the door on good. Some humidifiers must have the door closed properly to maintain a proper low voltage connection.
Good luck
Posted on Mar 29, 2009
  • 52 Answers
SOURCE: humidifier
No.
Posted on Mar 07, 2010
I have an essick humidifier and it keeps flashing CF but it continues to run. What does the CF mean.
Check Filter Indicator The ability of any humidifier to efficiently supply humidity output relies heavily on the condition of the filter. As the filter loads with impurities it gradually loses its wicking capability. When this happens, moisture output is reduced and the humidifier has to work longer to satisfy the selected setting. This humidifier has a check filter reminder timed to appear after 720 hours of operation. When the Check Filter (CF) message is displayed, disconnect the power cord and check the condition of the filter. If a build-up of deposits or severe discoloration is evident replace the filter to restore maximum efficiency. The CF message is reset when the humidifier is plugged back in.
Dec 03, 2017 | Humidifiers
What does the code CF mean?
read the manual but cf sounds like clean filter to me
Feb 21, 2015 | Essick Air Humidifiers
How do you reset the cf on essick humidifier
I just changed the filter and it started flashing CF. How do you reset this other than changing the filter?
Feb 04, 2013 | Essick Air Humidifiers
Have a MA0800, have changed the filter but can't clear the flashing CF display.
You have to unplug the unit from the electrical outlet. Just shutting it off won't clear the CF code.
Jan 12, 2013 | Essick Air MA0800 Humidifier
Humidifier what does CF stand for
It may mean "Change Filter." After you replace the filter, unplug the humidifier for 30 seconds, and then you plug it back in, the CF code should be gone.
Dec 04, 2011 | Kenmore 14410 Humidifier
Our machine is flashing CF. We've put a new filter in, but cannot get it to reset. Do you know how to reset the machine?
Mar 11, 2011 | Essick Air MA0800 Humidifier
CF is displayed on my humidifier...what is that?
Mar 05, 2011 | Bemis 826 800 Humidifier
I have the MA0800 and I have a CF flashing on the display. How do I get rid of this code? If it requires a clean filter, then how do I reset this code once I have a clean filter?
Change the filter then unplug the unit from the electrical outlet and the code will be cleared. Just shutting the humidifier off won't clear the code, it has to be unplugged from the power to clear the flashing CF.
Jan 21, 2011 | Essick Air MA0800 Humidifier
What does the cf stand for
Found the answer in the original manual. CF means check filter, this displays every 7200 hours of operation. If the filter is OK just unplug the unit for 2 minutes and the display will reset.
Dec 26, 2010 | Essick Air Humidifiers
Humidifiers Logo
403 people viewed this question
Top Humidifiers Experts
Paul Carew
Dennis
Are you a Humidifier Expert? Answer questions, earn points and help others
