Question about Hitachi 53FDX20B 53" Rear Projection Television
Picture looks 3D,
Hitachmi 43fdx20b The magic focus is not working,tv still look like 3D. Just need someone to show me what parts i need and the schematic on were the parts are located. Than i will do the work my seft.Thanks need help.
BMW Rider
  • 232 Answers
SOURCE: 53UDX10B 53 in. Rear Projection "3D vision"
the convergence IC`s and associated resistors have to be replaced, do not repeatedly push magic focus or the alignment after the parts change out will take longer which of course means higher repair bill, good luck
Posted on Nov 27, 2007
video-tek
  • 150 Answers
SOURCE: Hitachi 43FDX20B 43 in. Rear Projection Television magic focus
Hi, replace the convergence IC`s and any fried resistors and chemical fuses (if any), do not push magic focus anymore it will not correct the prroblem and it will evenntually corrupt the DCU and cause you more problems (and of course more money), questions? ask awayy, video-tek
Posted on Feb 08, 2009
ladywinn
  • 5138 Answers
SOURCE: Looks like the picture is in 3D...magic focus won't adjust green
Replace Both of your STK ICs they are Big Black ICs Also CK and replace these resistors RK42 3.3 /RK46 1.8 /RK50 2.7/ RK54 1.5 RK54 1.5/ RK58 3.9 /RK62 2.2
Posted on Feb 16, 2009
SD Tech
  • 14553 Answers
SOURCE: Hitachi 53FDX20B 3D picture
This set uses two STK--392-110 type convergence chips----You can buy both on Ebay for less than 13 dollars plus shipping. Both chips need to be replaced and any damaged resistors around them located and replaced also--most of the time the set just needs both chips replaced and then adjusted.
If you cannot do this repair yourself--look in your area--most shops TRY to charge 300-400 for this kind of repair----I do lots of them here--did two Hitachi sets with this problem yesterday for 200-250 total.
MAKE SURE WHOEVER you get to do this changes BOTH CHIPS--SOME techs will come out and just replace one--in a short time the set will have the same kind of trouble again---Now is the slow time of year for TV repair shops---shop around for someone who will do this repair IN YOUR HOME--almost any good tech can do it in about 1 hour---if they say it "has to go to the shop" keep looking.
The chips are black(2 1/2 inches wide and about 1 1/2 inches tall with 18 pins) and will have the STK number printed on them in white--they are located on either one large metal heat sink with fins or two smaller heatsinks that are side by side.
If you have ANY questions or need help reply to this post here.
I do this here for free so if this has helped you take a minute and give me a vote here.
SD TECH
Posted on Sep 06, 2009
Ecollier2012
  • 3459 Answers
SOURCE: Hitachi 43fwx20b Convergence Problems
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony,Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit wiith instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Another common problem is dull or washed out video.
Your TV may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find a fix here
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Posted on Apr 03, 2010
My TV is the Hitachi model 51UWX20B and tried using magic focus to line up red color. Picture looks like 3D with red off center. When using magic focus it gets to the red phase and it shows the number 5...
You need to replace the STK ICs which are Convergence ICs STK392-110 use 120s or 150s
also check the small ohm resistors around ICs . They are Big Black ICs and will have part number on them ,should be located on the Right hand side of Chassis .
Mats Eletronics has Parts 1-800-628-1118 Convergence IC Kit.
Jul 04, 2011 | Hitachi 51UWX20B 51" Rear Projection...
I have a Hitachi 53UWX10BA tv. The picture colors are off and blurry. I ran magic focus and it showed a 4 on the bottom of the screen
Ur tv have a problems known as a convergence problems,it dead.Tv have corlors R,G,B lines mis alignments,have colors shadows picture or 3D picture look alike?Yes.The tv convergence board is dead.The convergence board must change 2 STK convergence ICS and some or all of it resistors to fix the convergence board to solved the tv convergence picture problems.The shop will cost u like $300-350 for parts and labors.
Feb 28, 2011 | Hitachi Televison & Video
Won't magic focus
Magic FOCUS button no help all?The tv have a problems known as a convergence problems,it dead 100%.Tv have colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors it dead too.These parts on the tv convergence board must be replaced to solved the tv convergence pictures problems.The shop,will cost u like $300-350 for parts and labors.
Dec 08, 2010 | Hitachi 53SBX59B 53" Rear Projection...
I HAVE A HITACHI 53WX10B TV AND THE SCREEN IS BLURRED. I HAVE TRIED THE MAGIC FOCUS BUTTON AND THE SHARPNESS BUTTON. ANY OTHER IDEAS?
Magic focus button don't work or datas never reaches 100%.Tv have a problems,known as a convergence problems,it dead.Tv have colors lines R,G,B mis alingments,have colors shadows pictures or a 3D pictures look alike?The tv have a dead convergence board.The tv convergence board have 2 STK convergence ICS and some or all of it resistors are dead too.These parts on the tv convergence board,must be replaced to solved the tv convergence pictures problems.The shop,will cost like $300-350 for parts and labors.
Dec 04, 2010 | Hitachi 53SWX10B 53" Rear Projection...
The magic focus does'nt seem to reset the auto convergence on the tv. Do you have any sugestions
The Magic focus button,not in effective anymore.The tv is 100% have convergence problems,it dead.The tv colors lines R,G,B mis alignment,have colors shadows pictures or 3D pictures look alike.The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors are dead too.These parts on the tv convergence board,must replaced these parts on the tv convergence board to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Nov 07, 2010 | Hitachi 46F500 46" Rear Projection...
I need to line up my colors and magic focus does not work.
If picture looks 3d in some way you have a convergence problem.
This set should use two of the STK-392-150 CHIPS FOR THIS.
The repair can be a do it yourself one if you have some skill. Magic focus only attempts to adjust at about 18 points on the screen.
Parts cost will be under 25 dollars. The repair consists of getting at the chips (2) and replacing both--on EBAY they will cost under 15 dollars (I fix sets and use a seller there).
If I can help make a comment here and if this told you something you did not know, rate this solution as very helpful as I do this here for free.
SD TECH
Sep 15, 2010 | Hitachi 51F500 51" Rear Projection...
Hitachi rear projection tv. picture is shadowy/3D
This set uses two convergence chips--both need to be replaced and the set adjusted----If you know how to do good soldering I can tell you where to look and what usually needs to be replaced---Parts cost should be less than 20 dollars if you buy the parts on Ebay---
Most shops charge 300 or more for this type of repair---I just returned home from a set with this type of problem---in home total repair 250 total---If you cannot do the repair I suggest you shop around and find someone who can do it in your home---any good repair person can do this in about 1 hour---I am getting ready right now to do another one near where I live.
IF YOU HAVE ANY QUESTIONS OR NEED ADVICE FEEL FREE TO ASK ME...I am here to help people.
REGARDS, SD TECH
Oct 05, 2009 | Hitachi 53UWX10B 53" Rear Projection...
What dose a convergence board look like?
This is what the convergence PWB looks like. Its located on the extreme right side of the chassis looking in from the rear of the set.9cc0c04.jpg
Nov 27, 2008 | Hitachi 43FDX20B 43" Rear Projection...
Hitachi 57SWX20B 3D Effect due to green light convergence problem
I'm trying to fix the issue on my 43FDX20B. So far, I'm able to move the lines up and down, but can't get the left/right motion to fix it. The attached link has the dynamic mode instructions, so you can correct this issue yourself.
http://home.comcast.net/~leebailey00/Hitachi_DCAM_Manual.pdf
The only thing I didn't have was the screen overlay jig the manual talks about. I decided to create one myself and use the screen as a beginning template. I went to our local hardware store and picked up some home window weather covering. The roll cost about $15, is a clear strong plastic and the template was very easy to create. I used a straight edge after I put dots on the plastic and measured the lines for being square and equal after I took it off my tv. Good thing is that if you don't like what you make the first time, you have a 25' roll to use to try again (ha).
Mar 01, 2008 | Hitachi 57SWX20B 57" Rear Projection...
Nov 10, 2007 | Hitachi 53SDX01B 53" Rear Projection...
Hitachi 53FDX20B 53" Rear Projection Television Logo
24 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
