Question about Nikon 18-70mm f/3.5-4.5G ED-IF AF-S DX Zoom Nikkor Lens
The zoom ring has stucked
This sounds interesting! I do have some experience in fixing analog lenses, so I think I'm willing to give it a try!
If I do according to your description, how do I find the screws or whatever that have come loose? What parts inside the lens could have come loose, causing the zoom ring to lock?
Are there any parts in particular that are very sensitive that I should avoid touching, or are there any parts that could be really tricky to get back in place once I have fixed the problem?
Considering facts like wintertime and static electricity here in Sweden, and all the electronics for the autofocus etc. this has made me decice not to try to fix the problem myself. I'm afraid that I'll only cause more damage.
I would like to thank you though for all your efforts in trying to help me.
Charlie
Posted on Feb 28, 2008
  • 667 Answers
The fact that you have been in older lenses make this a bit easier. These newer ones are modular.
The circuitry is the most sensitive part, make notes or take a picture of how all the connections are made. Most of the flexible connections are fairly straight forward.
Once you get the lens down to removing the outer barrels, you'll likely find that a zoom guide or two have come undone or are damaged. These are small nylon rollers with a fat screw in the center.
Being that it is winter, static may be a problem. Don't zap the brains of the lens
I'll keep an eye on my email notices, I cannot do live chat since I use a Macintosh most of the time.
Kevin
Posted on Feb 21, 2008
Nikon lens 35-70 af zoom ring stuck
This is not a do-it-yourself type of repair. If you try to do any disassembly of the lens yourself, you will end up with a table full of parts you will not be able to properly reassemble and it will cost twice as much to have it fixed. Send the lens to Nikon or a professional camera repair man.
Feb 09, 2014 | Nikon Cameras
The focusing ring on my quantaray 28-200 lense will not turn on my d80 nikon camera
If the lens is made for Nikon, it should go on the camera. I just put a zoom lens from the analog days (80-200 f1:2.8) on my D80 and it works fine. Don't forget to put the aperture ring to the highest setting (f 1:22) and lock it.
Jan 27, 2014 | Cameras
The zoom ring has limited use...maybe something stuck inside lens
If you are unable to maximize the zoom capabalities of your lens, the mechanical gears might have been jammed and or broken. Do not push it if it won't let you as you might break the lense. What you can do is to bring it to your local camera shop or service center to have it fixed.
Jun 09, 2010 | Nikon 18-70mm f/3.5-4.5G ED-IF AF-S DX...
Nikon24-120 vr 1 aperture blade kock zoom ring
These lenses are highly complicated, and require adjustment after reassembly. Even if you do get it fixed, you do not have the necessary adjustment software to get it working properly. Try sending it to PhotoTech Repair Service in NYC. They are Nikon authorized, and factory trained with all the necessary equipment. Also if you join they're facebook page, they will give you a 10% discount.
Here is the facebook page link, it has everything you need to send it in.
http://www.facebook.com/pages/New-York-NY/PhotoTech-Repair-Service-Inc/102527215194
Mar 12, 2010 | Nikon 80-200mm f/2.8D AFED Lens
Hi my sigma 18 200 has stuck at full zoom how difficult is this to repair ?any advice would be welcome.
Some Sigma lenses feature a "zoom lock" to protect the lens when not in use, so just make absolutely sure that this hasn't accidentally been left engaged nor that the switch is being obstructed from unlocking somehow, such as by dirt/debris. It's also worth giving the lens a few sharp taps down onto a table in case it's just a bit of sand or other debris.
Otherwise, it's not a DIY fix due to the complexity of modern autofocus zoom lenses. If you try to force the lens or attempt an incompetent repair you'll ruin a £300 lens.
The best option is to send it to Sigma for a repair estimate, if you're in the UK then there's a fixed fee of £93.99 (tariff no.6). The link I've provided is for the UK but if you're elsewhere different fees and procedures probably apply. If it helps, my experiences of getting similar repairs done in the north America is that they're usually a bit cheaper and in Aus/NZ they're a bit more expensive.
If your lens has failed under warranty then the repair is free if the lens has not been misused, there is no evidence of any unauthorised repair attempt, and you have proof of purchase.
Feb 12, 2010 | Sigma 18-200mm f/3.5-6.3 for Nikon
Zoom ring is loose and drops/slides on its own
Yes, this happens even when the lens is brand new. Some other lenses have a Zoom lock to prevent it. What I did was to slip a flat rubber band around the black area just behind the zoom ring, the area where there is s white mark or line, with the band ring just touching the zoom ring. The rubber band should be fairly tight, but not too tight. When the zoom ring revolves, the rubber band touching it gives it just enough friction to prevent it from turning. You can adjust it to give as much friction as you want. Hope this helps. Jay
Oct 02, 2008 | Canon EF-S 17-85MM F/4-5.6 IS USM Lens
Zoom won't work
wow alot of people have gotten this problem with the lense in this camera.
Well to cure this problem , firstly turn on the camera, ensure the lense is out ,Then GENTLY tapp on the lense in the direction that the lense feels uneven or unequal length to the outer ring (place that looks uneven).This should hopefully get the gears aligned once more.
Nov 22, 2007 | Sony Cyber-shot DSC-W70 Digital Camera
Quantaray 28-90 for Nikon N65 zoom ring locked up
There is no secret locking switch. If a little gentle jiggling doesn't free the zoom ring, then I can only suggest you take it in to a reputable camera shop for a Clean-Lubricate-Adjust (CLA).
Sep 03, 2007 | Quantaray 28-90mm f/3.5-5.6 for Pentax
Nikon 18-70mm f/3.5-4.5G ED-IF AF-S DX Zoom Nikkor Lens Logo
153 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
