Question about Tomtom ONE GPS Receiver
Unable to connect device to computor, and my sd card has been erased.tried to do back up but no success please help
  • 518 Answers
First, do you have the maps on your computer? in tomtom home? if so reset your device by inserting a clip into the small hole next to the sd card slot and hold for 15 seconds then start your tomtom home programme on your computer and connect your device, click yes when asked and then click manage my device in tomtom tick the map(s) you want to transfer and then click copy too device, hoping this helps
Posted on Feb 08, 2010
I want to recover my moble n95 data
I had success recover files from mobile phone with this mobile data recovery guide, check it out
how to recover deleted files from mobile phone
hope this helps.
Dec 26, 2012 | Nokia N95 Cellular Phone
We have downloaded the software for our MAC X so that we can load the recorded material into the program to convert to wave files. We are using a Swann USB 2.0 card reader. We can't get the computer to...
I found some useful formating instructions at http://osx.tribe.net. Note: FAT 16 only supports 2 GB or less. I had no problems reading FAT 16 formatted SD cards in Leopard. I revised the instructions a bit:
To format the SD card, you will need the path to the SD card device and the SD card device number.
1. Insert the SD Card into a card reader.
2. If you don't know how to find the device number of the SD Card, here is one way to do it:
2b. Open Disk Utility
2c. Highlight the SD Card device (upper icon), not the SD Card volume (lower icon)
2d. Click Erase at the top of the window
2e. Select Volume Format: MS-DOS (FAT) Click Erase... > Click Erase
The SD Card Volume Name will change to the UNIX device number e.g. "disk5s1". Note this number as it will change by itself to "Untitled". It is now formatted in MS-DOS FAT 32. We need to reformat it in FAT 16.
Once you have the device number of the SD Card, you need the path to the SD card device.
3. For my Mac, the path to devices is "/dev". In a terminal window: type "cd /dev" and hit the "Return" key to go to the "dev" directory. Then type "ls" (with a lower case L) and "Return" key. You should see the SD Card device number listed.
Formatting the SD Card in FAT 16:
4. In Disk Utility, highlight the SD Card device and click Unmount at the top, not Eject. The desktop icon of the SD card will disappear.
5. Go to the Terminal window. Be careful to type the following command with the correct letter case and spacing. Again, make sure you type the correct device number and path as you can very easily erase your hard drive in UNIX.
Type the command:
newfs_msdos -F 16 (path to SD Card device)/(SD Card device number)
e.g. newfs_msdos -F 16 /dev/disk5s1
and hit the "Return" key.
6. If you get just a new prompt (or a prompt with some warnings, e.g. below), the command executed successfully. You can remove the SD Card; it is now formatted in FAT 16. You can verify this in Disk Utility after mounting the SD Card.
If you get some instructions on the newfs_msdos command with a new prompt, the command did not execute. Make sure you enter the command with the correct case and spacing. Hint: to re-enter a previous command you typed, hit the up arrow repeatedly. For more information, type: "man newfs_msdos". Scroll with arrow keys. Type "q" to quit and return to prompt.
Apr 21, 2008 | Audio Players & Recorders
Tip
Can't Write to SD Cards Wii allows you to save game progress and other data...
Can't Write to SD Cards Wii allows you to save game progress and other data right to the console's internal memory. An SD card is not required. However, we understand that players may want to use an SD Card to back up their data.
To write to an SD Card, the Wii console requires a downloaded update. To download updates you will need to connect your Wii to the internet.
Please note, without the update, you can still transfer data off an SD card for use in the Photo Channel. This allows you to view your images, movies, and listen to mp3 files.
If you wish to use an SD Card as a storage device, but are unable to connect your Wii console online or have no plans to do so, please call 1-800-255-3700 for available options.
on Mar 04, 2010 | Video Game Consoles & Games
I cannot access my 2GB micro sd card in computer or phone, when i opened it from computer i get message card need to be formated but when i start to format card windows says unable to format this device....
sometimes your need to clean those small connector copper of the sd card.to clean this use a pencil eraser to clean thin copper film.then try it again.if nothing happens need to buy a new sd card.
Jul 13, 2011 | PNY 2GB microSD Memory Card
I PURCHASED A KINGSTON MMC MOBILE SD CARD, AND INSERTED INTO THE SLOT OF MY PHONE AND WAS NOT ABLE STORED ANY DATA ON IT, SUGGESTING THAT MAY BE THERE IS A LITTLE PROBLEM WITH MY PHONE, SO I DECIDED TO...
SD cards allow you to store digital information; you can use SD cards with most electronic devices like digital cameras and computers.
An SD card will become write protected if the switch on the card is placed on the "Lock" position. This prevents any information on the card from being altered or deleted.
If you wish to add, delete or change any of the information, you must remove the write protection.
Remove the SD card from the computer or digital device.
Locate a switch on the bottom or side of the SD card.
Move the switch to the "Unlocked" position to remove the write protection.
If you do not have a switch, you will need to remove the write protection with your computer.
Insert the SD card into your computer's card reader or back into the digital device.
You can now save and change information on the card.
Apr 07, 2011 | Kingston 1 GB microSD Card with USB 20...
I have a 1gb micro sd card whichi is deteted by both phone and computer but unable to open or format. Please help Bijaya Tripathy
Do you mean detected or deleted? Make sure on the side of the card you do not have it locked. Restart both devices and try again. Clean the contacts of the card with a pencil eraser. If none of these ideas work you may have a defective card. It happens sometimes. Let me know more details as the last thing you did at the time or if this helps and thanks for using FixYa.
Jan 27, 2011 | SanDisk 1GB microSD Memory Card
i cannot access my 2GB micro sd card in computer or phone, when i opened it from computer i get message card need to be formated but when i start to format card windows says unable to format this device. please help me.
from kapil sharma
Sep 19, 2010 | PNY 2GB microSD Memory Card
How to recover erased images from sd card
It is quite possible to recover the photos no matter deleted, formatted, lost or inaccessible from your sd card. All you need to do first is by trying SD card data recovery software tools.
Note: before those files are recovered, never should you attempt to save more data to the card. better stop using it for a moment. Regards.
Jun 18, 2010 | Vivitar DVR-550 DV Camcorder
G1 SD
if reemoving and reinserting the card doesnt help, youll need to have it reformatted....
do this by connecting your phone to the pc and opening your MY COMPUTER icon > right click REMOVABLE STORAGE/DISK > select FORMAT
**if your computer says something like 'no disk available' try disconnecting the device and select MENU > SETTINGS > SD CARD AND PHONE STORAGE > make sure the check bos for 'USE FOR USB STORAGE' is checked****
after that, set the 'file systems' as FAT32 > select START > read the warning > press OK > once complete, disconnect from the pc and try again!
IF that doesnt work, try to test the sd card in another phone to see if the sd card itself is the problem. if you still have the issue but the sd card works, go ahead and reset the phone.
MENU > SETTINGS > SD CARD AND PHONE STORAGE > FACTORY DATA RESET > RESET PHONE > ERASE EVERYTHING
Nov 17, 2008 | HTC G1
Tomtom ONE GPS Receiver Logo
107 people viewed this question
Top Tomtom GPS Experts
Martin Murray
Jon Piercy
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
