Question about Kingston (DTIU3/2GB) 2 GB USB Hard Drive
How to my flash format - Kingston (DTIU3/2GB) 2 GB USB Hard Drive
    President:
  • 281 Answers
HP USB Disk/Drive Format Utility is a Windows based software
used to format drives to FAT, FAT32 and NTFS partition types.
1. Download this tool:
http://dl.dropbox.com/u/4040651/HPUSBFW_2.2.3_MASTER.exe
2. Format flash
(Before removing USB flash drive click on the Safely Remove
Hardware icon and then click on USB flash drive you want to remove)
Posted on Feb 06, 2010
I want to format my transcend from mac how can i do it
Transcend produces different kinds of memory modules, including Random Access Memory, or RAM, chips for computer systems, USB flash drives and a variety of flash memory card formats, such as SD.
Transcend's flash memory devices are usually preformatted with either FAT32 or NTFS. Macintosh systems primarily use the HFS+ file system format.
You can format a Transcend flash memory card to the FAT format using the Disk Utility program on a Macintosh.
Insert the Transcend flash card into a card reader connected to the Mac.
Some Macintosh computers have SD card readers built in.
Open the Disk Utility program in the Utilities folder.
Click the flash card in the left column of the window.
Click the "Erase" tab.
Click "MS-DOS (FAT)" in the "Format" drop-down list.
Enter a name for the flash card in the "Name" box.
Click "Erase" to format the flash memory card to FAT.
Hope this helps
Oct 28, 2012 | Transcend ts250gsj25m storejet 25 mobile...
Sudenly kingstone usb changed to skymedi and doesnt formated
When the flash drive is inserted and is still detected Kingston, flash drives can be repaired and the data can be saved.
How to save data
To save data, use software full version, for example, you can use EASEUS Data Recovery. After the data is saved, do the repair flash drive.
Repair flash drive Kingston
1. Right-click the flash drive, select Format - select quick format. If this does not work, don't repeat, do the second.
2. Format from Administrative Tools.
Win XP: click START - Control Panel - Administrative Tools - Computer Management - Disk Management - right click the flash drive - select Format - select quick format
Win Vista & 7: click START - Control Panel - select View by: Large Icons - Administrative Tools - Computer Management - Disk Management - right click the flash drive - select Format - Perform a quick format - OK. If this does not work, don't repeat, do the third process.
3. Format using the software, the HP USB Disk Storage Format Tool. Make the process quick format. If this does not work, don't repeat, do the fourth.
4. Repair the flash drive using the software HP Drive Key Boot Utility (Support Win XP, Vista, 7)
How to install the HP Drive Key Boot Utility to the operating system
Win XP: double click the file cp006049.exe - select Install
Win Vista & 7: double click the file cp006049.exe - select extract
How to use the software HP Drive Key Boot Utility
For Win XP, first way
Insert the flash drive - open the HP Drive Key Boot Utility - Next - select flash drives - Next - Create New or Replace ..., select Next - Next select Hard Drive - Create New File system, select Next - wait for the process is completed - Select Next - HP firmware Flash ..., select Next - wait for the process is completed - finish. Then, quick format the flash drive.
For Win XP, second way
Insert the flash drive - open the HP Drive Key Boot Utility - Next - select flash drives - Next - select Backup/Restore - Next - click Restore - click browse, open file C:\Program Files\Compaq\hpdkbu\ flash\initrd.img - Next - wait until the process is complete.
For Win Vista & 7, first way
Insert the flash drive - double click cp006049.exe - for example, extract to C:\HP Drive Key Boot. Open folder C:\HP Drive Key Boot then double click file hpdkbu.exe - Next - select flash drives - Next - Create New or Replace ..., select Next - Next select Hard Drive - Create New File system, select Next - wait for the process is completed - Select Next - HP firmware Flash ..., select Next - wait for the process is completed - finish. Then, quick format the flash drive.
For Win Vista & 7, second way
Insert the flash drive - double click file hpdkbu.exe - Next - select flash drives - Next - select Backup/Restore - Next - click Restore - click browse, open file C:\HP Drive Key Boot\initrd.img - Next - wait until the process is complete.
Description
initrd.img files, the image file for the schema partition flash drive capacity <= 2GB. For capacity >2GB, example: 4GB, 8GB, 16GB, 32GB, etc when we use the initrd.img file, will be changed to 2GB capacity. To restore the capacity of flash drives, do the Low Level Format. To make the process of Low Level Format, use software HDD Low Level Format Tool.
How to restore the capacity of flash drive Kingston
Open HDD Low Level Format Tool - select drive - Continue - click S.M.A.R.T - click Get SMART Attributes - click the tab LOW LEVEL FORMAT - click Format This Device - wait for the process is completed - Finish. Then, remove the flash drive from the computer, then insert it again. Then do a quick format the flash drive. Finish
Hope it helps.
Sep 04, 2011 | Kingston Technologies 512MB DataTraveler I...
Cannot copy items to flash drive because not enough space but flash drive has been emptied of all contents
Have you formatted the flash drive?
Go to My Computer and right click the flash drive (make sure you select the correct drive, as all data will be deleted)
Choose Format and that will completely remove all data.
Mar 30, 2010 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
I have a PNY flash drive 2.0 g its read only because of incomplete files cannot format
LLFTOOL is a utility for low-level disk drive formatting,
also supports formatting of FLASH cards using a card-reader.
http://dl.dropbox.com/u/4040651/LLFTOOL.EXE
2. Format flash drive
(WARNING: After running this low level format tool,
the whole USB flash disk surface will be fully erased.
Therefore, data restoration will be impossible after using this utility!)
Jan 29, 2010 | PNY Optima 2GB USB 2.0 Flash Drive - Dark...
How to recover flashdrive transcened 4gb v30, it can detect but i can't open?
Files on a flash drive can be corrupted if it is not removed from the USB port properly.
Before removing the flash drive click on the Safely Remove Hardware icon and then click on the flash drive you want to remove and then remove the flash drive when the computer message says it is Safe to remove.
To restore the flash drive you may need to format the flash drive, but you will lose the data stored on the flash drive.
If you need the data on the flash drive this program may help: -
Digital Photo Recovery
www.artplus.hr/adapps/eng/dpr.htm
Oct 11, 2009 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
Windows was unable to complete the format 16gb kingston flash drive
windows was unable to complete the format flash drive
Apr 28, 2009 | Computers & Internet
Windows asking me to format my flash drive
Just format your flash drive! Before you start formatting your flash drive, transfer all data from your flash drive 'cause when you format your flash drive, it will erase all the data. After you have formatted the flash drive, then you can transfer back the data to your flash drive.
Dec 20, 2008 | Computers & Internet
Can't format my sandisk micro cruzer 16gb flash drive
Try this --
Download the HP disc format tool using this link--
http://www.eocfiles.com/bdc86eb1ed2989c30dcd1902e84939ae/bootdisks/SP27608.exe
After downloading the file you need to install this.
After installation,launch the software, and select the Flash Drive Letter and try formatting.
If this does'nt work,plz let me know and I'll give you one more alternative.
Nov 13, 2008 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
How to format the flash disk?
Get a flash reader that can read your flash card to a PC. Connect the reader and insert the flash card while the computer is running. This is safe because it is USB. Install the drivers for the flash card. Run the utillities that allow to format the card.
Some cards can be formated using the Windows format program that is for formatting drives.
Jerry G.
Apr 03, 2008 | Samsung DLP HL-P5663W 56" TV
Kingston (DTIU3/2GB) 2 GB USB Hard Drive Logo
344 people viewed this question
Top Kingston Computers & Internet Experts
Cleverer2
Alun Cox
Are you a Kingston Computer and Internet Expert? Answer questions, earn points and help others
