Neither of my Ruud Achiever Plus furnances are
Neither of my Ruud Achiever 90 Plus furnances are working. We are in the midst of a snow blizzard (30 inches) and I have no heat. I have checked the circuit breaker and turned the furnance switch on and off.  I am not mechanically inclined so I don't know what else to try.
  • 1,252 Answers
First, put the t'stat fan switch into "Fan" position. If fan comes on, it verifys that you have voltage to the motor and you also have low voltage for the controls.
Look for the circuit board on the air handler as in most of the higher end units, they have tights that flash the gives you a trouble code. Table for the codes us usually located on the back side of the cover where the board is located.
Hope this helps.
Posted on Feb 06, 2010
Ruud achiever 90 plus furnace-water leaks from the drain pipe
This furnace should condense, as long as it goes into the drain. If it is leaking inside the furnace, there may be a seal that needs replacing in either the pvc drain pipe or concentric drain trap needs resealed.
Feb 21, 2015 | Ruud Heating & Cooling
Ruud furnace wiring diagrams
Generally Ruud uses that for a common
Nov 08, 2013 | Heating & Cooling
My Ruud Achiever 90 Plus not blowing cooled air
Look on the condensor, (outdoor unit) at the very bottom of the rear panel and you should find a red reset button. push it. If that does not solve the problem, and the outdoor unit is running (make sure both the fan AND the compressor are running) then you are looking at a low refridgerant issue and possibly dirty coils.
In that case, clean the coils and have refridgerant added.
Sep 23, 2009 | Ruud UBHC Air Conditioner
Ruud Achiever 90 plus not blowing air
the motor is bad or start capicitor
Aug 29, 2009 | Heating & Cooling
Ruud achiever 90 plus won`t start at times
sounds like you have a heat pump heat pumps dont work below 30* temps you should have some type of backup heat
Feb 05, 2009 | Ruud UBHC Air Conditioner
Ruud achiever 90 plus blower not working
does the furnace ignite?? your system may not have been lighting and has gone into ignition lockout count the codes of the led lights then remove panel led diagnostic codes are listed there.
if led codes indicate no problem verify capacitor is good and that mtr is getting 115 volts.
Sep 15, 2008 | Ruud UBHC Air Conditioner
Heating & Cooling Logo
156 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
