Question about ASUS A8N-VM Motherboard
Is the ASUS A8N-VM PCI Express 2.0 compliant?
    Scholar:
  • 62 Answers
Not that I know. It may support newer pci-express graphic cards, but surely they won't run at full-power with pci express 1.0 lower specs. if you're not satisfied with your motherboard, you should buying a new one that supports pci-express 2.0
Posted on Feb 06, 2010
Lost my motherboard driver disk of asus k8v-vm, where i can downloard it
go= http://support.asus.com/download/download.aspx?SLanguage=en-us
go download>select>mother board>2nd select socket 754>3rd k8v vm and search and download
Name ASUS K8V-VM Description VIA K8M890, VIA VT8237A, DDR RAM, Micro ATX, Graphics card, Sound card, Network card Form factor Micro ATX CPU Type AMD Ahtlon 64/Sempron Number of CPUs Single Socket Socket 754 Front side bus 800 MHz MHz Chipset VIA K8M890, VIA VT8237A Memory type DDR RAM Number of DIMM-Slots 2 Number of RIMM-Slots 0 Max memory 2048 MB Memory speed DDR400, DDR333, DDR266 Serial Attached SCSI (SAS) No Serial ATA (SATA) Yes Serial ATA ports 2 Serial ATA 2 (SATA II) No Serial ATA 2 (SATA II) ports None IDE Ports 2 IDE Speed 33/66/100/133 MB/sec MB/sec Built in SCSI controller No Built in RAID controller Yes Built in graphics card Yes Built in sound card Yes Built in network card Yes Multiple GPU support No Crossfire support No SLI support No RoHS Compliant No AGP interface No AGP-slots 1 PCI-e (PCI-express) Yes PCI-e slots 2 PCI-e type 16x/1x PCI slots 2 PCI-X No CNR-slot 0 AMR-slot 0 eSATA No Bluetooth No WiFi No FireWire (IEEE1394) No Number of FireWire ports 0 USB type USB 2.0 Number of USB-ports 4 Number of parallel ports 1 Number of serial ports 1 RJ-45 (Ethernet) 1 PS/2 Keyboard 1 PS/2 Mouse 1 Line-out 1 Line-in 1 Microphone Yes Bios 4 Mb Flash ROM, AMI BIOS, (TCAV), PnP, DMI2.0, WfM2.0, SM BIOS 2.3, PXE Boot BIOS Miscellaneous Audio:- Realtek ALC660 6-Channel Codec, LAN:- Realtek RTL8201CL 10/100M LAN PHY
Nov 22, 2010 | ASUS K8V-VM (K8V-VM GREEN) Motherboard
Is nvidia 9600gt graphic card compatible with asus p5rd2vm motherboard
Yes.
1) The Asus P5RD2-VM motherboard has a PCI Express x16 slot.
The Nvidia 9600GT uses a PCI Express x16 slot.
2) The PCI Express version used on the Nvidia 9600GT is PCI Express 2.0
The PCI Express technology used on the Asus P5RD2-VM motherboard is PCI Express 1.1
The motherboard chipset used on the Asus P5RD2-VM shows us this.
The motherboard chipset is an ATI RD480. (Before AMD bought ATI out)
The ATI RD480 chipset came out September 27, 2005.
http://en.wikipedia.org/wiki/Comparison_of_ATI_chipsets#Comparison_of_Northbridges
Scroll down until you come to > RD480 in the left column, then read across.
The PCI Express technology started under another name, then was changed to PCI Express.
The first version was PCI Express 1.0
Then PCI Express 1.1
In 2007 (January 15) the PCI Express 2.0 technology was brought out.
The PCI Express 2.0 technology is Backward Compatible with the PCI Express 1.1 technology.
(With PCI Express 1.0 also, but it depends on the graphics card being used)
In otherwords, a graphics card that has been based upon the PCI Express 2.0 technology, will work on a motherboard based on the PCI Express 1.1 technology.
You won't get the full capability of the PCI Express 2.0 graphics card.
Will you notice?
NO.
[ If I had my choice I would run an Nvidia 9800GT instead.
Depends on the price, and availability of the 9600GT I would assume, though.
You may also need a more powerful Power supply.
Example, not advertising,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=6391081&CatId=3670 ]
Nov 03, 2010 | ASUS P5RD2-VM Motherboard
Is there any video card compatible to my ASUS p5rd1-vm ?
You ASUS mother board has 2 PCI slots.
1 PCI Express x16 <- this 1 is for video expansion
1 PCI Express x1
Jan 08, 2010 | ASUS P5RD1-VM Motherboard
A display problem of monitor comes with geforce 9400 gt pci ex. card. how can i solv it? when i insert cart the display of monitor out. how can i solv it?
According to the specs of the MSI 9400gt 512mb HDMI graphics cards, its system requirements are:
1. PCI Express or PCI Express 2.0 - compliant motherboard with one x16 graphics slot.
2. Power supply of 300 (and up) watt is highly recommended for system stability.
Make sure that your power supply meets the or exceeds the system requirements for this graphics card.
Jun 26, 2009 | ASUS COMPUTER INTL P5SD2-VM MBD MATX LGA...
I Want Driver for Asus A8N-VM
Manufacturer drivers for the Asus A8N-VM board can be found here:
http://support.asus.com/download/download_item.aspx?product=1&model=A8N-VM
Jan 19, 2009 | ASUS A8N-VM CSM (00610839133826)...
No display after installing 9500 gt 1gb graphic card on a8n-vm
install the driver... then install the card. you may have to manual set which video source the computer is using.... ideally you want it to boot to pci first
Jan 10, 2009 | ASUS A8N-VM Motherboard
Version of PCI Express
my motherboard has a PCI-E 1.0 it's an Asus Commando graphics is 9600GT which is PCI-E 2.0 and it runs fine till now no prob about that mate PCI-E 1.0 and 2.0 is backwards compatible so it should work fine make sure your graphics card is working @ x16 coz when I first plug my graphics it runs only @ x2 then I reset the bios and re-seat the graphics now fully functional x16 of PCI-E lanes.
May 15, 2008 | ASUS A8N-VM CSM (00610839133826)...
Installing NVidia 8500GT XFX 256MB graphics to A8N-VM Motherboard
The chances are that you have an old motherboard which is not compatable with the new graphic card. Or you may be running windows 98 and are downloading the driver for xp or visa versa. The probable solution, will be to sell the new card on ebay and buy the best old card you can off ebay. Or just make do with the card you already had in your computer. If you are determined to have a better graphics card. A motherboard upgrade with better graphic card may be the best answer or buy a better spec pc second hand if you don't have much money. You'll probably waiste a lot of time trying to get the new card to work and it probably never will.
Jan 28, 2008 | ASUS A8N-VM Motherboard
ASUS A8N-VM Motherboard Logo
465 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
