Question about Toto Home
Hi I have a Toto toilet seat, soft close seat on skirted one piece toilet. The area where it is screwed in has lots of rust and black stuff coming out of the screw in area. I've tried to tighten screw which helps a little, but I think I need to replace parts here. Can you help?
    Problem Solver:
  • 5 Answers
Just get a new seat. You may find a replacement bolt kit but they are rare. happy hunting.
Posted on Feb 20, 2010
How to remove a parisi nahm soft close toilet seat
there is 1 of two ways.
easy way is have a look where the seat mounts to the toilet and see if there is a cover that you can lift up and find a screw under it. there might be 2 pins on each side of the toilet seat hinge that you depress for you to remove the seat from the hinges to access the screws.
failing the above method the toilet has to be removed to access the screws / wingnuts from under neath. send closer picture of hinge on seat if you like.
Jul 12, 2014 | Toto Aquia II Dual Flush Toilet
I have a Toto toilet and am trying to replace the old seat. BUT the bottom is a solid piece and makes it impossible to access the seat bolt for tightening. I began loosening the seat bolts. now I have a...
hi there
this type of seat has rubber gromits that squeeze up when you tighten the screw.if it wont tighten up the gromit may have failed and would need to be replaced.
good luck
Dec 18, 2010 | Toto Carrollton Toilet Tank - ST774S-01 -...
The toilet see is not tight. How can I tighten the seat? I have an elongated seat with the soft closing lid.
Right behind the bowl on the underside there is a nut on either side that holds the seat on...tighten those nuts and it will tighten down the seat...
heatman101
Aug 29, 2010 | Toto Aquia II Dual Flush Toilet
Toilet seat cover became loose on one side
I have a Toto Dorian 1.6 Gpf where the right side of the cover separated from the seat frame. I fixed it by removing the seat from the toilet base and driving the stainless steel shaft back into the cover hibge holes.
To remove the toilet seat, use a large phillips head screw drive and unscrew the two long screws that hole the seat to the base.
Then you will see the two steel rods about 1/4 inch in diameter that have worked there way out of the seat hinge. Use a hammer and a screw driver to drive these two hinge pins back out into the toilet seat cover hinge holes.
Replace the toilet seat and screw in the two seat screws being careful to not over tighten them. The seat should now work correctly.
Apr 02, 2010 | Toto Promenade, 1.6 GPF, Elongated...
The close coupled toilet seat keeps coming loose. The two phillips screws keep turning and won't tighten. There seems no way to get to the captive nuts...???
I too could not figure out how to get to the nuts since the skirt completely encloses the base. Nor could my plumber until he called his plumbing supply store. They told him they use a type of rubber piece that can be pushed through the hole from the top and acts as a nut. I didn't see it replaced so I don't know the details but I do recall that when I tried to turn those phillips screws that there was a squishy feeling. I don't know how to tighten under those conditions. I recommend you call a plumbing supply store.
Feb 11, 2010 | Toto Drake ADA Compliant Toilet with...
The Toto elongated seat is shifting from left to right--
They are designed to have a little movement to prevent breakage if it is a lot then replace they is no way to adjust
Nov 01, 2009 | Toto Carlyle 1-piece Elongated Bowl Toilet
I have a Toto saftclose toilet seat but it doesnt close softly!!!
If it is something you can adjust, there will be an area on the hing. There also may be a small cover over the adjustment screw.
Apr 01, 2009 | Toto Round Maple SoftClose Toilet Seat...
Home Logo
396 people viewed this question
Top Toto Home Experts
john h
Robert McCall
Robert McCall
Mike
Are you a Toto Home Expert? Answer questions, earn points and help others
