Question about Dewalt DC011 AM/FM Radio
When i switch off dewalt dco11 radio the station memory is lost
Does the clock lose time too? 2 AA batteries under a door inside the battery compartment. Change them, reset time and stations.
Posted on Feb 26, 2010
  • svkehrer Jan 14, 2012
    Mine is always plugged in and still loses station memory.
  • 494 Answers
Backup battery for the memory may be weak.
Posted on Feb 10, 2010
Lock ion a radio station
TO PROGRAM THE MEMORY BUTTONS
Ten FM and five AM radio stations may be independently set. After programming the buttons,
pressing 1, 2, 3, 4 or 5 will instantly change the frequency to the preset station.
1. Turn power on.
2. Set the radio to desired station (see Tune or Seek Function).
3. Press and hold one of the desired memory buttons (F). The station setting begins flashing in
the LCD display (G). Continue to hold the button down until the flashing stops. The memory
button is now set.
4. Repeat steps 2 and 3 to set the other memory buttons.
Please see the attached images for the figure options.
Oct 19, 2014 | Dewalt DCO11 Radio
Dco11 got wet, charges but no radio
HI BVanhook,,
You have probably increased damage by trying to power the unit when it is wet. Any time you get electronics wet, you should not apply power when a chance the circuit is wet. This is becasue a form of Electroplating occurs. Metal from one circuit trace will move to another. Heat will build from short circuiting and the circuit will destroy itself.
Disassemble the Radio and Display, dry it throughly. Do not apply any more power until you have thoroughly inspected the circuitry with a magnifying glass to see if any of the Electroplating occured. Clean it up by scratching the short circuits between the traces to clear the connections made by the Electroplating. Good Luck
Nov 25, 2007 | Dewalt DC011 AM/FM Radio
Dewalt dco11 radio has static on every station tapping on it and tilting it and giving it a tap helps any solutions adjusting antennae doesn't help
Either the antenna connection at the back of the radio or at the antenna (or severed antenna cable) can cause this.
Another possibility is the tuner in the radio is bad. Remove radio to check antenna connection into radio.
Apr 10, 2014 | Cars & Trucks
Have purchased a dewalt radio/charger through sears, was a close out where had no instruction for presetting channels 1-2-3-4 Not able to set, need instructions.
1. Select the Radio Station you want to save.
2. Press and hold the Memory button that you want that station on, 1, 2, 3, 4.
The display will flash the station number, when it stops flashing, the channel is set.
Oct 21, 2010 | Dewalt DC011 AM/FM Radio
Did not recieved operators manual with dewalt dc011 construction radio. need to know how to set the select channels. 1-2-3-4
How do you work the channle preset
Oct 20, 2010 | Dewalt DC011 AM/FM Radio
When I shut the radio off the clock and radio memory goes to How do I set the clock and stations so that when I tur it on I have the clock and stations.
Have you inserted 2 x AA batteries in the back where you charge the Dewalt batteries? there is a cover with a black phillips screw, this is where the AA batteries go for the memory clock & radio presets.
Nov 28, 2009 | Dewalt DC011 AM/FM Radio
Dewalt DCo11 worksite radio W/ charger. Only works with batteries. No 120 V. Checked fuse. OK
Check to see if you have voltage out of transformer, more than likely you won't, if theres no voltage out of your tranny it needs a replcement.
Oct 30, 2009 | Dewalt DC011 AM/FM Radio
The radio is not working on the Dewalt Radio/Charger. I am not sure what the problem is. It was working one day, then the next it wasn't.
Replace the AA batteries they are located inside the battery chager. these batts. control the radio and memory stations.
Aug 28, 2009 | Dewalt DC011 AM/FM Radio
KENWOOD KDC - W312SAY BUTTON MEMORY 1 - 6 NOT WORKING
what is the problem but if you want to memoris your station you just search for the station and press and hold the burton number #you wish to program it on
Dec 10, 2008 | Car Audio & Video
Dewalt DC011 AM/FM Radio Logo
793 people viewed this question
Top Dewalt Audio Players & Recorders Experts
Gyula Lacz
Rob Beech
Are you a Dewalt Audio Player and Recorder Expert? Answer questions, earn points and help others
