Last night, I opened my son's curtains to let in some light and I saw two symbols projected on the outside wall of my neighbour's house. Is there some way I can scan these and send them your way for interpretation?
  • 37 Answers
Take a picture and then upload it to the website.
Posted on Feb 06, 2010
Last night and this evening carbon monoxide alarm sounds on upper level. Last about 15 seconds. Is a new battery a possible first step of resolve? Thanks
first step is to check the house for anything that can make the gas --furnace , oil fired heaters, fire places, engines
cars idling in garages etc
neighbour hood fires etc
next , replace the battery and test the alarm
Jul 13, 2017 | FIRST Home Security
Is not opening
Yellow Hibiscus, Mothers Day gift. My son brought it home last night.
2 blooms lots of buds. Blooms closed last night, today still not open. Transfered to larger pot. Added water and a little extra soil.
Nov 26, 2013 | Spooky House Studios UG Bubble Explode
Was coming home from picking up my son from school, was fine the whole way home til the last corner before our house, when my son leaned into the corner to far and I think it broke the seal on the side of...
Replace the tyre. The only thing that keeps you on the road while riding a bike is the tyres. If you have any suspicions either replace it or take it to a tyre repair shop and see if they will fix it. I would re-inflate the tyre first and leave the bike over night to see if the tyre is sound or not. It may just be a failed valve.
Aug 09, 2013 | Aprilia Motorcycles
How to hanging curtain hardware
The most important thing with fitting hardware is to find the studs in the wall for brick veneer or in the case of solid brick, you must ensure the wall plug goes deeper than the wall plaster. The wall plug needs a hole drilled for a good fit- not loose or the plug will rotate as you tighten the screw.
Side openning - you can adjust the curtain postion after installation by lifting the cord from its clip on the carriage and moving the carrier along to the correct position.
On one of the carrier slides there needs to be an overlap for the little carry bar for the curtain hooks so you do not get a gap when the curtain is shut.
When designing curtains there should be at least 2.5 drops ( window cobverage) for a good looking curtain.
To prevent heat loss thermo syphoning up the window, you should close in the pelmet on the top. Just 3 ply will do this fine.
For one side pull, you need to screw the cord pulley end to the floor or skirtin via the spring provided and set the length of cord by shortening at one of the carriage slides.
I may be rambling here, but a simple stud finder is really handy to find the studs (vertical timbers) It also shows power cables but they will not be as wide. Any photos of your house under construction is good to show where the timbers and power cables are.
It is a good idea not to hit the power cables - tends to burn things - like houses.
Anyway if you describe waht sort of fittings you have you may get more useful info.
Dec 28, 2011 | Cameras
My Samsung HLR5067 was working fine last night. I left the house open and it dipped in temp (only to 40 degrees or so though)...Woke up this morning and it wont turn on at all. Just beeps a few times,...
Tv projection Lamp might be some how the causes again.Tries unplug,replug tv back like about an hour later.Try it again,should work now.If not,yes the projection lamp,might have been kill by the cold weather.
Dec 06, 2010 | Samsung HLR5067WX 50" Rear Projection HDTV
I have a 52
No its require to change some parts
Jan 21, 2010 | Televison & Video
Green timer light wont go away
Hi.
The TV is in protect mode because there is an internal fault.
The TV must be tested and repaired at component level.
Call Mitsubishi at the number listed on the user manual.
You can also read my comment explaining more on protect mode here:Why my TV does not start up and remains in...
Dec 13, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Condensation on double glazed windows
hi check the air bricks built into your walls are not blocked
Nov 17, 2009 | Flex 3" Condensation Drain Horizontal
Kenmore elite dryer wont start
I bet you have a blown fuse. Fuse is located on the blowers housing near where the flex pipe hooks up. Clean out the dryer, open the vent to outside and replace this fuse:
Dec 15, 2008 | Kenmore Elite HE4 Electric Dryer
Computers & Internet Logo
David Payne
David Payne
