Question about Dyson DC07 All Floors Bagless Upright Cyclonic Vacuum
Will not lock into the upright position and has lost suction from the brushes
  • 4 Answers
Upright Lock Assembly has broken
Posted on Feb 07, 2010
Dyson DC 25 power shuts off in upright position
To clarify, do you mean the suction and brush motion shut off in the upright position, or that the entire unit shuts off?
If the latter, most Dyson uprights shut off the brush unit in the full upright position and shunt the suction into the handle for use with the accessories. There is also an on/off for the brush, next to the main power button for the DC25. If it's off ( or stuck that way), no brush motion. The manual also notes, 'for use, turn on power and click the foot pedal in back to recline the unit.' (Link to manual here:
http://www.dyson.com/medialibrary/files/dyson/support/downloads/uk/floorcare/manuals/DC25_Manual.pdf See Page 8). The
'High Reach Cleaning' section also notes that the brush bar won't rotate when the vacuum is in the full upright position.
If you are completely losing power, the manual notes that the unit will shut off if the bar is jammed, or if there is a significant line blockage that makes the motor overheat. If this is happening, check the accessory line in the handle for blockage.
Good Luck :-)
Jul 11, 2014 | Dyson DC17 Animal Bagless Upright Cyclonic...
Hi, i have a panasonic eco max, the brush has stopped going round, the belt is as new and brushes clean.suction good from hose. Any ideas please? thank you
The brush on this model is controlled by the on/carpet/floor switch and will only work in the carpet position. If the suction motor is running then it could be the roller brush motor, but it's more likely to be the microswitch which stops the brush motor when the handle is returned to the upright position.
Dec 03, 2012 | Panasonic Mc-Ul594 Eco Max - Bagless...
My bissell lost its suction...
My Bissell upright Pet vaccuum lost suction but the brush is still working...help
Dec 29, 2010 | Bissell 1770 Quicksteamer II Upright...
X1.1 model has plenty of suction through the nozzle, but doesn't 'pull' across the floor anymore or pickup dirt when using upright
Assuming that the automatic height adjuster is working properly, most likely your Sebo needs a new brush roll because the bristles on the old one are worn to the limit. To test the height adjuster, put the machine in the normal operating position (with the handle not upright) then switch on - the green "down" light may come on briefly (or may stay on if the brush is worn). Then, leaving the machine switched on, move the handle to the locked upright position - the green "up" light should come on, and you may be able to see the whole machine tilt backwards slightly as it lifts the brush off the floor. If that happens, the adjuster is working properly and you definitely need a new brush roll.
I hope this helps. If you need more guidance, just post a reply here and I'll get back to you soon. Please remember to rate this answer as I do value feedback. Good luck!
Mar 19, 2010 | Sebo Automatic X1 Bagged Upright Vacuum
My wind tunnelhas no suction when using the beater brush. Something is stuck. Can I fix it?
If the hose has suction in the upright position, and the floor has no suction in the normal use position, check for obstruction in the dirt path from the agitator cavity, thru the short hose, into the lower handle.
Oct 03, 2009 | Hoover U5753-900 WindTunnel Bagless...
I have good suction at brush, but no suction in hose connection.
Please unscrew the hose connection to the back panel. Is there suction there while in the upright locked position? If so, visually check the hose inside for obstructions.
Jul 12, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
Proheat Plus turbo brush does not work.
No water or soap is coming through, what do I do?
Jan 02, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
No suction, brushes move
Well you did not provide make and model either. If a Hoover, there is a valve on some that depending which position the handle is in, will be open or closed. It may not be working, so when in the upright, there is suction for the hose, but when you tip the handle back, the valve doesn't move and blocks suction from below. You will have to remove the top cover to check it out.
Aug 09, 2008 | Vacuums
Dyson Brush Bar Always Spins
Take off the brush cover and check that the suction orifice is clear. Also check the rubber flaps at the bottom of the hose/handle holder is correctly positioned.
Feb 06, 2008 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Lost suction
Hi.
Remove the sole plate turn the 3 plastic screws to unlock & lift off.
Now remove the blockages that have accumilated from the oppening of short clear hose.
Check you can turn brush roller & check belt.
Now reassemble switch on pull handle back & look under machine is brush spinning ?
If not check the knob on side of machine is in drive (D) position.
http://dysonmanuals.llc.nu
Chris..
Dec 27, 2007 | Dyson DC07 Animal Bagless Upright Cyclonic...
Dyson DC07 All Floors Bagless Upright Cyclonic Vacuum Logo
117 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Nick Olsen
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
