Question about Samsung Office Equipment & Supplies
The CLX-2160 printer says Outbin Full even though I have made sure there are no paper jams, have tried using the manual feeder and only had 5 pages in the intray. Que? Is there a sensor somewhere that would be defective? Is it worth repairing, the thing only cost $200?
  • claude_imbea Feb 06, 2010
    Tried it and it does not change anything. Any other ideas?
    President:
  • 3,278 Answers
Hello, Claude.
Try removing the paper, opening the front cover and then closing it. Power your printer off, then on. Fan and add the paper, again.
Hope this helps.
Posted on Feb 06, 2010
How do I use my printer as a duplex for making copies on both sides? Thanks Roxanne
The printer does not support duplex coping. If you want to do manual duplex copying, you can make a copy of the first page.
Then reinsert the paper upside down in the manual tray or paper tray, fil the page on the document feeder and make the back copy.
Aug 27, 2010 | Samsung CLX-3170FN All-In-One Laser...
I have a paperjam on my colour laser printer CLX 3170 and I dont know how to get to the paperjam inside the machine
Step 1
Turn the printer off and on to see if it can automatically clear some or all of the jam. Many printers provide an error-code listing on the front panel display for the area where the jam occurred. If your printer shows an error code, be sure and check the printer manual to see if that identifies the area of the printer where the jam occurred.
Step 2
Turn off the printer.
Step 3
Remove any paper trays. Inspect them for wrinkled or damaged paper.
Step 4
Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
Step 5
If necessary, remove the toner or ink cartridge. Place it in a bag or away from light to avoid damaging it.
Step 6
If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
Step 7
If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though.
Step 8
Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
Step 9
If the printer paper jam message still appears, then there is still some paper in the printer. Inspect the paper path once again.
Feb 19, 2010 | Samsung CLX-3175FN Color Laser All-in-One...
Samsung clx-2160 says waste tank is full. What must I do and where is the waste tank?
If you open the front of the printer then you will find a waste tank in the left side - its gray. Take it out and empty it, and put the tank back in place.
This works for Samsung CLX-2160
Jan 31, 2010 | Samsung CLX-2160N All-In-One Printer
Colour printing not working
Hi ,
While printing go to the printer settings nad check if any Black print option is clicked. Also check the color cartridge status.
Jan 26, 2010 | Samsung CLX-3170FN All-In-One Laser...
Samsung clx-2160 - paperjm"0"
remove the cartrige tray to remove the paper that jam
Oct 24, 2009 | Samsung CLX-2160N All-In-One Printer
CLX 2160 - paperjam
There is probably a jam in the paper feed area. Pull the paper tray out and stick your hand in to find and remove any paper stuck there. Then reinstall the paper tray and open and close the front door of the printer. The jam should be cleared.
If it is still showing paper jam, pull the tray out again and look to make sure you didn't miss any paper, then check the other areas of the printer (starting with the exit area) for paper.
Samsung CLX 2160 manual feed ,paper jam 0.help help me
pls check any paper is instered in the printer & refix the catridge.
Aug 20, 2009 | Office Equipment & Supplies
CLX-2160N does not correctly pick up paper from
Hi
If it is new then you should return it for the guaranty if not...
It is a common failure in printers, mostly laser printers which are used more frequently! there is a part underneath the paper feeder roler/drum, which is like sand paper. It stops excessive paper to be dragged in by the feeder, using friction! By the time, this part gets worn out resulting in more papers to be fed by the feeder! you could get the part from a replacement-parts dealer of your printer brand or try to fix it yourself ;)
I myself tried to make it less slippery by scratching it with a nife and/or a screw driver, with temporary positive result. I think you could glue a bit of sandpaper on it which should hold a bit longer!
Your helper!
/SciPhinx
Jul 12, 2009 | Samsung Office Equipment & Supplies
Samsung color laser MFP CLX-3175FW. Paper jams after the first page is printed and continues to jam each subsequent page. This is the third printer we have tried. Using a MAC computer. Suggestions...
clean the pickup roller that feeds the main tray.
This is an ongoing problem with this printer, even in the single function printers.
I used a toothbrush and water, scrubbing horizontally.
Jul 05, 2009 | Samsung CLX-3175FN Color Laser All-in-One...
CLX-2160N Paper Jam?
my printer Samsung CLX-2160 give me the message "paper jam", but I checked a lot of times inside and there is no paper. What's the real problem? How can I solve?
Mar 04, 2009 | Samsung CLX-2160N All-In-One Printer
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
