Question about Dell Inspiron 1501 Notebook
Gets stuck on boot up, Shows Dell logo but red line only goes about half way. Will eventually turn on after several tries and if I hold F2 at the same time (not sure if holding F2 makes the difference). Recent history compute turns itself off at random times....thought it might be over heating...did a little inside dusting but afraid to take it apart...now isn't doing that but I am not leaving it on too long. I did try a diagnostics test but it turned itself off in the middle of it and I didn't try again...maybe that might be the reason for the half boot?
    Novelist:
    Scholar:
  • 85 Answers
WARNING (if you do not feel comfortable disassembling laptops then the procedure below might not be a good idea and you might possibly want to have someone that is do the solution below (but from what you have said this is most likely what has to be done
NOTE: If the warranty on your dell laptop has not yet expired then you can call into tech support and tell them you need a new fan and they will send a technician from your area to you to replace it which will result in the completion of the procedure below at the same time)
To properly remove ALL of the dust build up from the system you will need to access the internal fan completely
To get the proper access to the fan and heatsink you need to remove the following: (blowing compressed air through the vents will not remove the dust buildup described here)
•Remove the battery.
•Remove the hard drive.
•Remove the hinge cover.
•Remove the keyboard.
•Remove the Mini-Card.
•Remove the LCD.
•Remove the palm rest.
To do the above follow these steps in this order:
  1. Remove the 11 palm rest screws from the bottom of the system
  2. Using a flathead screw driver, pry up the hinge cover to remove it.
  3. Remove the two screws securing the keyboard to the chassis
  4. Rotate and lift the keyboard from the chassis
  5. carefully Rotate (lift) the keyboard cable lock, and then remove the keyboard from the chassis
  6. Disconnect the two antenna cables from the Mini-Card
  7. Press the two securing levers towards each other to release the Mini-Card.
  8. Lift the Mini-Card to a 45-degree angle and remove it from the system
  9. Remove the four securing screws on the back and bottom of the system for the LCD
  10. Turn the system over and open the LCD.
  11. Remove the video securing screw (from wire connected to end of vid cable plug) and reroute the diversity cables
  12. Pull up on the video cable to disconnect it
  13. Remove the two securing screws (1 by each hinge) and lift up the LCD to remove it.
  14. Disconnect the palm rest cable.
  15. Release the captive screw and lift the palm rest from the system
Now you should have total access to the fan
  1. Disconnect the fan cable from the system.
  2. Remove the two securing screws from the fan and lift it from the system
When removing the fan you should see a "layer of dust" almost like a blanket between the fan and the heatsink
This layer of dust is preventing the air from the fan from making contact with the heatsink resulting in crashing and overheating and so on
NOTE: You will notice two heatsinks there one is for the video card the other for the cpu i would recommend cleaning any dust build up from both of them since the video card on that model can go out pretty easy if it gets to hot.
18. Repeat the procedure in reverse order to reassemble
Hope this info helps
Posted on Feb 06, 2010
  • Darren Kessinger
    Darren Kessinger Feb 06, 2010
    Let me know if you need more detailed info here and i can send you a zip file with pictures and all for your model..
    Here is a pic i forgot to include in the solution above
    Scholar:
  • 47 Answers
Typically these symptoms are caused by one of the following. There may be more reasons, but just covering the most common here.
- Old worn out or malfunctioning batteries can cause this issue. Remove the power and battery, then plug in just the power, leaving the battery off. Try using the laptop without battery. If the problems go away, purchasing a new battery should do the trick.
- Overheating due to diminished (wearing out or plugged with dust or even dead cooling fan). First purchase a can of "canned-air" or other brand forced-air duster available in any electroncs store for a couple dollars. Use this to force air though all air vents etc. in an attempt to dislodge any dust and debris that can plug the cooling fan and vents. If it is still having the heat issue after the cleaning, purchasing an inexpensive laptop cooling platform should do the trick in leiu of having the fan repaired at a repair shop. It is a platform that you place your laptop on that has fans in it that cool it down. These usually cost less than $20 at most electronics stores.
Hope this helps.
-Tor
I tried to clean the dell vostro 1014 fan, after i assembled the fan and turned on the laptop it appear black screen with dim image on my laptop screen, When I plug in external monitor it shows boot s
It sounsd like your GPU may be BGA chip and would require a re-flow/re-ball if your laptop shows graphical distortion on both monitors.
However I would first try taking the laptop apart again and double check you have connected everything properly.
Mar 20, 2014 | Dell Vostro 1014 Laptop Computer
My System Fujitsu Siemens Scaleo P cannot boot windows and doesn't proceed after display of Fujitsu Siemens Logo (Where it says Press F2 to Enter Setup).
I would take it back to the place of purchase, it is clear the window installation was not completed, a manufacture oversight.
Jun 18, 2012 | Fujitsu LifeBook AH531
Have a Dell Studio. When I power up the Dell Logo appears with loading bar below that. The bar stops about 2/3 of the way, it freezes up and starts beeping. Nothing I've tried works.
this is often related to a possible motherboard problem. Try these steps: turn it off, remove the battery, and AC adapter, then press and hold the power button for about 5 to 10 seconds. Once done, reconnect at least the adapter , turn on the laptop and as soon as the Dell logo shows up, tap F2 a few times to enter System Setup (BIOS screen). From there, go to the Maintenance category, and select Load Defaults, press Enter. Press ESC, then select Save/Exit, restart the computer and see how it goes.
Sep 27, 2010 | Dell Studio 15 Laptop
The screen goes very dark within a minute after booting up = I can just barely see the menu page
When you say screen goes very dark when it booted to windows so it means that when you turned on the laptop when the dell logo flashes the screen was fine? if thats the case could you please try this. after turning on the laptop you will see the dell logo flashes immediately keep tapping on F2 and then it will show you the BIOS setup utility, please check if in BIOS setup display goes dark as well. If yes then try this, after turning on the computer when dell logo flashes keep tapping on F12 to boot menu then select utility partition to run the diagnostics. Please run test on the LCD check if display goes black when running the LCD test. Then try this when you sees the dell logo keep tapping on F8 to boot in safe mode check if in safe mode display goes very dark. Try this too, boot in F8 then select last known good configuration check if the settings on your display will be fix. If you can boot to safe mode no problem then uninstall the display or video driver. then restart computer.
You can also try to connect an external monitor if you have one just try to isolate if issue is on the LCD or the video card. If the display is dark as well in external monitor then video card needs to be reseated if fails then replaced. In situation like this most video cards is integrated to the motherboards. So replace motherboard.
Dec 08, 2009 | Dell Inspiron 2200 Notebook
Lap boots up, shows dell logo then screen goes black but runs.
ur unit is overheating turn off and unplug and let cool down,clean vents around fan intake (under unit) and around top each side of keyboard when cool enough plug back in and listen for fan operation while booting up if no fan it may be stuck or burnt up and may need replacement but ur biggest problem will be the hard drive if it was overheated for to long could or is damaged good luck hope ur lucky and that it just got hot
Dec 05, 2009 | Dell Inspiron B130 Notebook
My dell inspiron 1501 is stuck in bios about 75%
operating system isnt loading....try booting with a windows boot cd
Nov 21, 2009 | Dell Inspiron 1501 Notebook
Dell inspron 8100 laptap with windows xp
Try booting with your windows xp installation cd in the drive. See if it will give you a repair or restore option when doing this. If it does not then it's possible your computer has a virus. You can check this by booting up with your anti virus cd in the drive and let it do a system scan. Hope this helps & please remember to rate my answer. Thanks.
Dec 27, 2008 | Dell Inspiron 8000, 8100, 8200 Series...
Dell OptiPlex GX150 won't do anything.
try going to the bios by pressing f2 or delete key on the keyboard at the dell logo.
if you are able to enter the system setup screen, reset the bios.
to reset the bios, press num lock, caps lock and scroll lock so that all 3 lights on the keyboard are on.
press alt + e and alt + f keys.
press esc twice
then select save changes and exit.
also try booting through the safe mode by hiiting f8 on the dell logo.
you can also try booting through the dell resource cd or win xp cd.
Aug 06, 2008 | Dell OptiPlex GX150 SFF (GX150BLACK) PC...
Dell Inspiron 1501 Notebook Logo
147 people viewed this question
Alun Cox
