F 76 appears on the display ...unplugged the unit for several days but F 76 still appears on the display. I've had the unit for 2 years and this is the first time i've had this problem. I need assistance
    President:
  • 4,402 Answers
Need make and model
Posted on Feb 21, 2008
How to set time
Plug in the unit.
First, the month and date appear, then the
year, and then the current Eastern Standard/
Daylight Time appears in the display.
Press
TIME ZONE
Area number "2" appears in the display.
If you live in the Eastern Time zone, you do
not need to adjust the area setting.
Area number
Time zone
Atlantic Standard/
Daylight Time
(default)
Eastern Standard/
Daylight Time
Central Standard/
Daylight Time
Mountain Standard/
Daylight Time
5
Pacific Standard/Daylight
Time
6
Yukon Standard/Daylight
Time
7
Hawaiian Standard/
Daylight Time
Press
TIME ZONE
repeatedly until the
desired number appears.
The display returns to the clock about 4
seconds after the operation is complete.
Note
During the shipment and your first use, a clock
error may occur. In this case, refer to "Setting the
clock and date" to set the correct time.
When daylight saving time
(summer time) begins
This unit employs Automatic Daylight Saving
Time/Summer Time adjustment. The DST
indicator appears in the display at the beginning
of the daylight saving time (summer time), and
disappears at the end of it.
Daylight saving time begins at: 2:00 AM on the
second Sunday of March.
Standard time begins at: 2:00 AM on the first
Sunday of November.
To cancel the automatic DST/summer
time adjustment and to set DST display
manually
The automatic DST/summer time adjustment can
be cancelled.
Press and hold
DST
for at least 3 seconds while
the clock is displayed.
A beep sounds, and "Aut
OFF" appears in the
display to show that the automatic DST/summer
time adjustment is cancelled. The display returns
to the clock.
Notes
Daylight Saving Time depends on the law in
each country/region, and your area may not use
it. In such a case, cancel the automatic DST/
summer time adjustment before using the set
and set the time manually as necessary.
To activate the automatic DST/summer time
adjustment again, press and hold
DST
for at
least 3 seconds. A beep sounds, and "Aut
On" appears in the display to show that the
automatic DST/summer time adjustment is
activated. The display returns to the clock.
To change the display to the daylight saving
time (summer time) manually, see "To change
the display to the daylight saving time (summer
time) indication."
Setting the clock and
date
To change the setting manually, follow the
procedure from step
Press
CLOCK
for at least 2 seconds.
You will hear a beep and the year will start to
flash in the display.
Press
or
until the correct year
Press
CLOCK
Repeat steps
and
to set the month,
day and time.
After setting the time, two short beeps sound
and the clock starts from 0 seconds.
Pressing and holding
or
changes the year,
month or day rapidly.
When setting the current time, time changes
rapidly by 1 minute-increments up to 10
minutes, and then by 10 minute-increments.
While setting the clock, you must perform each
step within 65 seconds, or the clock setting
mode will be cancelled.
To display the year and date
Press
SNOOZE/DATE/SLEEP OFF
once for the
date, and within about 3 seconds press it again for
the year.
The display shows the date or year for about 3
seconds and then changes back to the current
time.
If you connect the AC plug to an AC outlet while
this unit is powered from the backup power
source, the current date and time appears in the
following order (the same as when the unit is
powered on after a power interruption).
"month and date" (about 1 second)
"year"
(about 1 second)
"current time"
saving time (summer time) indication
Change the daylight saving time (summer time)
adjustment setting according to the following
procedures if you have cancelled the automatic
DST/summer time adjustment.
Press
DST
The DST indicator appears in the display and the
time indication changes to the daylight saving
time (summer time).
To deactivate the daylight saving time (summer
time) adjustment, press
DST
again.
May 24, 2015 | Sony SY-ICF-C414 Clock Radio
What does a C4/76 error code mean
I just went through lots of troubleshooting the same problem. Most searches will tell you its a communication error with the remote. After I was able to rule out the wiring, I bought a new remote ($70), hooked it up and immediately got the same error. Called Rheem Tech Support at 866-720-2076. They said code 76 meant I needed a new control board and chip. My unit was out of warranty but they sent the needed parts and detailed install instructions the same day, via FedEx overnight! It was a very simple task to replace. I happen to own 4 different units and am very glad I chose Rheem brand. Its not often I encounter a company willing to stand behind their products, even after the warranty period. Oh, and if you disconnect the remote control wires from the main unit (unplug unit, then remove face panel and they will be labeled, hooked on 2 small phillips head screws, replace panel and plug back in) your unit should still (more often than not) kick on and heat to about 100F by default...a do-able shower temp :) hope this helps!
Sep 28, 2014 | Rheem Paloma PTG-74PVP / RTG-74PVP Liquid...
Why does ac go to 80 degrees when set at 76
Sounds like you need another opinion from another AC man. If you are in an apartment complex, it has been my experience most apartment techs have limited knowledge of what to check. Try this
1. With the unit on, go to you air filter and check for proper air flow. If you are using pleated filters, stop. Use what is called 30 day throwaway filters. Pleated filters block 35 % of the air flow and can cause evaporators to freeze over. Ace hardware still stocks the ones with the blue mesh with cardboard edges. I have used the same filters for over 2 years. All I do is use my vacuum cleaner and clean the dust bunnies collected every 30 days.
2. Perform an sight inspection of your duct system. I have had several customers whose duct have fallen off and they were air conditioning the attic space and/or crawl space.
3. Have your AC man determine your superheat and subcooling value for your airconditioning unit. If your AC man does not know what these are then he really isn't an AC man. A typical value for most superheat (SH) and subcool (SC) is 12 to 15 degrees. These values are typically normal values but can change due to design criteria established among manufactures. If your AC man does not know what these are or can not measure these you need to get someone that know how to obtain them. These values are typical value for a normally charged equipment and does not vary from refrigerant to refrigerant.
Hope this helps.
Jun 26, 2014 | Goodman Heating & Cooling
Password reset
Procedure 2.3 - Accessing the User Parameter Program
This procedure allows you to change the following settings:
• Set Measurement Units
• Enable/Disable Password
• Set User Name
Procedure
1. Plug the power cord into the wall outlet, then turn on the treadmill with the circuit breaker.
2. Press keys STOP,5,6,7,1 sequentially.
3. The display will momentarily read SELECT UNITS
4. The currently selected measurement unit will then be displayed.
5. Use the UP, DOWN arrow keys to toggle between U.S. STANDARD and METRIC.
6. Press the ENTER key to select the currently displayed measurement unit.
7. The display will momentarily read, PASSWORD
8. Use the UP, DOWN arrow keys to select either PASSWORD ENABLED or PASSWORD DISABLED
9. Press the STOP or ENTER key to exit the program.
Aug 24, 2012 | Precor 9.31 Treadmill
The unit runs but does not collect water...it just runs. I've left it on for several hours. In the meantime, my basement is very moist with a lot of humidity from all the rain we've had. Even my...
the units low on refrigerant or freon,its normal for these to lose their charge after 2-3 years of use,i repaired a lot of these over the years,a couple of B.P.V.'s and about 9 ozs. of whatever type of refrigerant or freon and they will go another couple of years, all for about $50.00
Jun 01, 2011 | Kenmore 54501 Dehumidifier
I need to hack the region of the Sony DVD SR500H
Hi there
Follow these steps and your dvd will be able to play discs from any region.
*With the player in stand-by mode (take out any discs and leave it alone for several minutes) press on the remote, in this order: TOP MENU, CLEAR, POWER.
*A menu will appear with several options. Choose Option 2 and then Option 4.
*Type 12450, press enter, then type 00000.
  • Step 4 After the tray opens and closes repeatedly (this is normal), unplug the unit, then plug it back in and turn it on.
  • Read more: How to Change a Sony DVD Player Dvp-Ns50p to Multi Zone | eHow.com http://www.ehow.com/how_5708383_change-player-dvp_ns50p-multi-zone.html#ixzz0uvIMQI5i
    *After the tray opens and closes repeatedly (this is normal), unplug the unit, then plug it back in and turn it on.
    Thank you for visiting
  • Step 2 A menu will appear with several options. Choose Option 2 and then Option 4.
  • Step 3 Type 12450, press enter, then type 00000.
  • Read more: How to Change a Sony DVD Player Dvp-Ns50p to Multi Zone | eHow.com http://www.ehow.com/how_5708383_change-player-dvp_ns50p-multi-zone.html#ixzz0uvI1JPoD
    Jul 27, 2010 | Televison & Video
    Rheem Tankless wh model rtg-74pvn shuts off error code c4 76
    Contact Rheem; the Burner control unit has lost comm with the remote...the part is warranteed for up to five years.
    Nov 01, 2009 | Rheem RTG-74PVN-2 Natural Gas Pronto Whole...
    FLASHING C4 76
    Had a Ploma unit - same as Rheem. Not sure what C4 is...but code 76 is lost comm between the remote control and the burner control module. Unplug unit = take front cover off...their should be a square circuit card assemble in front of you. Top blow capacitors are typically used in todays electronics, and they have an obvious curve if the capacitor is blown. If the caps appear swolen on the top they are blown. STOP! If your unit is less than 5 years old..contact manufacturer for defective power supply. This particular problem is known to the MF...If you have a Poloma/Rheem they send you step by step instructions on how to replace this board yourself...if you're slightly technical you can do this repair yourself.
    Oct 26, 2009 | Rheem Paloma PTG-74PVN / RTG-74PVN...
    Error code 76 C4 heater shuts off every 5 mins while in shower
    Remove power source from the unit. If remote control2.gif is installed; remove cover and lift the control wires on the terminal...can be accomplished from either end.
    Restore power and see if unit functions normally.
    Contact Paloma/Rheem customer (800-432-8373) support and notify them IF you are getting a code "76" error. Rheem has recently extended the warranty on the "Burner Control Assm."; which is your problem. The C4-C8 portion of the error code, is where the unit stops the ignition process...burner fails to light, or gives you intermittent hot water. In either case, contact customer support2.gif.
    If this helps, please indicate so.
    Mike//
    jzklipper@aol.com
    Oct 01, 2009 | Rheem RTG-53PVN Indoor Natural Gas...
    Just under two year old C-4 76 CODE SOME WATER
    the 76 code is a code for the remote control. if you have a remote installed check for loose wiring or it could be a fried remote disconnect it and see if it runs then
    Jul 08, 2009 | Rheem Tankless Hot Water Heater...
    Televison & Video Logo
    32 people viewed this question
    Top Televison & Video Experts
    Marvin
    Marvin
