Question about Refrigerators
Making intermittent clicking noice and now makes a humming noise now and then sounding like it is trying start a motor
    Sergeant:
    Champion:
  • 263 Answers
Most likely your compressor and/or compressor starter need replacing.
refrigerator repair in orange county, ca
Posted on Feb 06, 2010
Testimonial: "thank you; guess i'll call someone in :)"
I bought 2 of these timers about one month ago. After two weeks, they started to make a rattle type noice. Is this OK? Is it just the timer spinning or is there a electrical short inside? I tried...
59200 is analog timer with moving parts including motor, switch and contacts.
http://waterheatertimer.org/Woods-timers-and-manuals.html#59200
I test timers. Some timers make noise, and some are quieter.
When a timer goes bad that I bought from local store, I buy another one and return defective one in new package.
Digital timers make no noise, except humming sound, and click when contacts are activated sometimes.
Add a comment with your experience so others with same-similar problem can benefit.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Mar 29, 2011 | Woods 59200 Lamp and Appliance Timer with...
GE electric Dryer model GDX8060SW will not start, makes a humming noice only. Exhaust duct was clogged with lint, which I removed. Still only humming noice when trying to start Dryer. Is there a reset...
could have a jam still in the blower wheel and all...sounds like unit is getting power and trying to start if your getting a hmm but something is keeping it from turning...gain access to the blower area and check a little deeper for more obstruction...aso make sure belt did not come off of motor maybe motor is humming but not turning unit....
Jan 03, 2011 | Dryers
My dishwasher is an MDBH955AWW. It was perfect
If the water pump inside is stuck, this will happen. Do not run unless you are clear. The pump coil may get burnt if left to hum.
Humming noise will be some times due to the the relay coil also. If you can check your self it's fine. Otherwise take the help of a service provider.
May 24, 2010 | Dishwashers
Speed Queed Dryer Motor makes humming noise when starting.
motor is no longer strong enough to turn drum,soory-mike
Jan 24, 2010 | Speed Queen AES28AWF Electric Dryer
My whirlpool top load washer will not start when I pull the knob. It makes a humming noise.
Motor sounds like its not starting up strong
May need a motor....
Jun 02, 2009 | Washing Machines
Kenmore washing machine fills with water then stops
turn the motor to see if it moves it sound like the motor
May 02, 2009 | Kenmore 24032\24036 Top Load Washer
Dryer makes a buzzing noise when I push the start switch.
Sounds like a bad motor, The buzzing noise is probably the motor humming then nothing because the thermal over load switch inside the motor opened. Timer will still be energized. Good Luck
The Squirrel
Mar 26, 2009 | Dryers
Dryer makes a loud buzzing noise then quits working.
Sounds like the motor's done. That thing is probably the start-run switch. Not worth trying to fix on an old motor. I've found dryer motors to be fairly generic, you should be able to find a replacement. I use Repairclinic.com when I can't get parts locally.
Nov 26, 2008 | Magic Chef CYE4000AWW Electric Dryer
Kenmore Dryer
sounds like it may be overheating.. Might try to take apart and see how much lint you got built up on the motor... may be causing overheating Is this the ONLY time it makes the humming noise when you go to start it??? May also be the early warning of bad start winding or start relay on the motor
Sep 02, 2007 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Refrigerators Logo
118 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
