WT960 first door won't open now get error f01 i think the motor is broken?
  • 15,935 Answers
The F1 error code on this washer indicates a Primary Control Board failure.
It is likely that the machine control board will need to be replaced to correct this problem.
The part number for the machine control board is undetermineable because you have not provided me with the exact model # of your washer.
The procedure for replacing the machine control board is provided HERE
LINK: http://media.fotki.com/1_p,wfgstgtftbtkrrdxgtqsskgwtqkq,vi/gfsfgfsgqxgfqtqtgwf/1/1303472/5961857/image55806img-or.gif
NOTE: Be sure to unplug the washer to disconnect electrical power before accessing internal components.
There is a slight possibility that a problem with the pressure switch hose could be causing this problem.
A pinched or twisted air hose can cause this fault code.
When you open the console, check the air hose connected to the pressure switch on the machine control board.
If it is pinched or crimped, I recommend rerouting the hose to resolve this problem.
This may fix your problem without replacing the control board.
NOTE: You may want to check for this condition before ordering the control board. Most electronic control boards cannot be returned for a refund or credit.
If you find no apparent problems with the air hose on the pressure switch, then replacing the machine control board on this washer should correct your problem. There is a risk involved in replacing this part yourself.
As noted above, you could have a problem with the air pressure hose that is not apparent upon your initial inspection. A service technician would normally need to properly and thoroughly diagnose this problem before replacing the control board.
This advice is for Kenmore Elite and Whirlpool Duet model front loading washers. If you experience a problem where the door becomes jammed and will not unlock or open, here's an easy way to gain access inside your washer WITHOUT calling the repairman.
1. Remove the lower panel under the door by loosening the three screws under the bottom edge on the front of the washer. HINT: If you prop up the front feet of the washer with some small blocks of wood, this will make access to the screws much easier.
2. With the screws removed, the lower panel should drop down then come off. If the panel sticks, a light tap on either side will knock it loose.
3. Reach your hand up inside the washer behind the front casing on the right-hand side. This is where the door latch assembly is located.
4. At the bottom of the door latch assembly is a small pull tab. This is the manual release for the door. Pull the tab straight down and the door will come open.
Sometimes these doors will not unlock for whatever reason. If there are no error codes being generated, this could have just been a momentary glitch. If you see "Fdl" or "Fdu" error codes, these are usually indications of a failed door latch assembly and will require replacement.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 10, 2010
Bosch shx36l05uc/21: After running diagnostics the 'wash' button keeps flashing, can someone tell me what the problem is?
Hi Jeff, As you can see there's 3 different Bosh washing machine models, Hope you can find your error code.... CHEERS..
Bosch Washing Machine Fault Codes
F16 - Door lock error
F17 - Inlet valve error detected
F18 - Drain error detected
F23 - Anti flood device has been activated
F34 - Door lock error
F42 - Motor fault
F43 - Motor fault
F44 - Motor fault
Bosch WAE Range Washing Machine Fault Codes
F16 - Door lock problem
F17 - Inlet valve
F18 - Drain pump
F21 - Motor
F23 - Anti flood system activated
Bosch WFP Range Washing Machine Fault Codes
F01 - Water intake timeout
F02 - Heating timeout
F03 - Draining timeout
F04 - Motor fault
F05 - Uncontrolled motor startup
F06 - Short on NTC Detected on hot water intake
F07 - Open circuit NTC Open circuit wiring
F08 - Door open when program started
F09 - Unexpected heating
F10 - Communication error
F11 - Overheating
F12 - Short circuit
F13 - Mains voltage too high
F14 - Mains voltage too low
F15 - Faulty temperature sensor on motor PCB
F16 - Faulty rinse sensor Displayed only in test
Mar 30, 2016 | Bosch Dishwashers
WT960 hotpoit washing machine shows F10 and stops
* F01 - Short circuit motor traic - Book a service engineer.
* F02 - Motor jammed or fan blocked - Book a service engineer.
* F03 - Front thermistor open/short circuit - Book a service engineer.
* F04 - No pump piloting - Book a service engineer.
* F05 - No feedback from the pump - Book a service engineer.
* F08 - Static heater relay with contact welded closed - Book a service engineer.
* F09 - Eeprom is not programmed or not functioning - Book a service engineer.
* F10 - Common of heater open or one shot open - Book a service engineer.
* F11 - No pump connection - Book a service engineer.
* F12 - Communication error between boards - Book a service engineer.
* F13 - Rear thermistor open/short circuit - Book a service engineer.
* F15 - Dynamic heater relay with contact welded closed - Book a service engineer.
* F-17 - Master relay welded closed - Book a service engineer.
Apr 06, 2015 | Washing Machines
Wt960
  • F01 - Short circuit motor triac
Nov 04, 2012 | Hotpoint Washing Machines
Error f01 flashing on machine
F01 on a Washer Dryer means you have a motor fault.
I suggest check the motor and associated wiring. You may just have a broken wire.
Hope this helps.
Oct 08, 2011 | Hotpoint Aquarius WD640 Front Load...
Bosch washing machine WVT 126S, error F01 on the start. Please help
F01 means the machine thinks that you have pressed start and the door is still open, so, either the door is not completely shut or you will need a new door interlock (part number 182154) you can get the part by calling 0844 892 8979 (UK) or http://www.bosch-home.co.uk/customer-service/spare-parts-accessories.html. Or the connection to the door lock is not loose or detached.Hope this helps
Aug 28, 2011 | Bosch Exxcel WVT 2850 Front Load Washer /...
The display just keeps blinking F05 and the key won`t go away so I can`t open the door..... please help me
  • Check the Water Temperature Sensor, Heating Element and Element Relay
  • Check connections to the Sensor, Heating Element and Relay
  • Dec 23, 2010 | Washing Machines
    F28 continues to show on display.
    Comunication error between motor control unit and Central control unit. Broken wire in the harness.
    F01 power glitch: disconnect power for 2 mins verify correct CCU operation
    F11 Motor control unit internal failure MCU board failure or broken wire.
    F20 No water detected entering machine, pressure switch hose clogged
    F21 Long drain Possible cause: Clogged filter, clogged/failed pump
    F22 Door lock error Failed lock. corrosion,or broken wires.
    F23 Heater Failure Bad heater
    F24 Water temp sensor error Failed sensor or heater
    F25 Motor Tach error Bad MCU (motor control unit) or broken wire
    F26 Door switch error Door not opened after 3 cycles. Note: suds errors cause the machine to try 3 times to fix a problem with wrong detergent too much detergent , and this error could be associated with that, my opinion
    F27 Overflow condition Clogged drain, pump, kinked hose.
    F28 Com error between MCU and CCU (central control unit) Broken wire
    F29 Door unlock error bad switch,broken wire,corrosion
    F30 Dispenser system error Bad or jammed motor, broken wire
    F31 MCU failure due to motor overheating.
    F33 Pump drive system error, broken wire, corrosion
    rL (prewash)Clothes detect. Remove clothes and retry.
    5d Suds lock detergent overdose(hay I ain't making this up, too much detergent, the wrong stuff, added to the wrong compartment, etc
    The technicial data sheet along with that pesky clogged pump is located behind the toe kick panel; remove the screws under the bottom front edge of the washer. Tip the appliance back to get to them screws. With the screws removed, the panel will comes down and off.
    For diagnostics and further info refer to this handy dandy:
    DUET SERVICE MANUAL My tip:
    http://www.fixya.com/support/r4232744-duet_sport_washer_error_codes
    Mar 21, 2010 | Whirlpool Duet Sport HT WFW8400TE Washer
    What does a fault F01 signify on a Hotpoint Ultima 7kg washing machine?
    Error code F01 indicates a short circuit motor triac.
    Thoroughly check all connections on the motor, the motor plug, and the electronic module board..
    Look for a broken wire, or a bad connection.
    Please rate my solution.
    Thankyou.
    Jan 22, 2010 | Hotpoint Ultima WF860 Front Load Washer
    I have a Hotpoint ultima wt960 with f01 error can I fit the part
    Hi
    f01 means motor fault. remove motor and check the brushes. if ok then fault could either be motor or pcb which is faulty.
    regards
    Mar 21, 2009 | Hotpoint Ultima WF860 Front Load Washer
    HOW TO FIX A F01 ERROR ON MY DUET HLT WIRLPOOL WASHER
    hi my name is joyce
    Did you try to unplug the unit for 60 secounds and replug it back up?
    do this and see if this works. then reset the machine's cycle, you are in the middle of cycle I usually push pause cancel and wait till the door beeps and then I can open it. but if this does not open the machine do the unplug and reset method. if this does not work please let me know.
    thanks,
    joyce
    Feb 05, 2009 | Whirlpool Duet GHW9150P Front Load Washer
    Washing Machines Logo
    104 people viewed this question
    Top Washing Machines Experts
    Gerry Harvey
    Gerry Harvey
