Start button yields a partial "start-up sound". The mechanical calibration sweep doesn't happen - the orange belt moves only a few notches. The "TA" & "Ready" lights continue blinking . . .
    President:
  • 4,070 Answers
Good day, have you tried re installing your driver? if not please do so. if it still doesnt fix the problem then you may have a mechanical problem that needs to be replaced or repaired by a professional tech. hope this helps, have a nice day
Posted on Feb 06, 2010
I have a Proform 1026 EXP treadmill that began running at full speed whenever it is turned on. The incline controls function normally but the belt speed is incredibly high. When set to 1.5 MPH (the slowest...
please run the Software calibration see the instruction.
GOD BLESS you
The Steps for Newer Style Console Calibration
1. Locate the calibration area on the rear or underside of the console (a hole, near the console's center, that goes through to the electronics board. (This hole should not have a screw in it.)
2. Insert a pencil (eraser end), into the hole and feel around for the cal button (will click when pressed).
3. Press the button 2 times (with the pencil eraser). The first click should show CL11 in the console, the second click should show CL21.
4. If the process was done correctly, and CL21 appears in the console, you are in "calibration mode." The next few steps consists of pressing buttons on the console and observing settings. This will not require any other tools.
5. Press ENTER. CL22 should display in the TIME window and (??) in the SPEED window.
6. Press ENTER. CL23 should display in the TIME window and (??) in the SPEED window.
7. Press ENTER. CL24 should display in the TIME window and (??) in the SPEED window.
8. Press ENTER. CL25 should display in the TIME window and (??) in the SPEED window.
9. Press ENTER. CL26 should display in the TIME window. You should then see the letter "E."
10. Press ENTER. You should see "SS" or "55" in the console.
11.Push the STOP/START button. For safety, at this point, you should step off, or be off, the treadmill.
12. Push the ENTER button. The walking belt should start to move, accelerate to maximum speed, then stop on its own.
13. When the belt stops, the incline should self test by raising to its highest incline position, then lowering back down to its lowest position.
14. Once the incline test is complete, push the POWER button 2 times. The unit should shut off and the console should go completely blank. If this happens, the treadmill is done calibrating and is ready for use.
If the letter "F" appears in the SPEED or INCLINE window when the power button is pressed 2 times, the treadmill is indicating a failure somewhere either in the SPEED or INCLINE (depending on the window the "F" appeared in). Troubleshooting the failure would be the next step.
Sep 18, 2013 | Proform 1026 Exp Treadmill Motor Control...
I have a Proform Treadmill XP550 that will not decline. I have tried all of the recalibration solutions on here, and reset and unplugged it several times. I opened up the cover and nothing seems to be...
use the software calibration for easy diagnostic and fix it. God bless you
Sep 17, 2013 | Proform Quick Burn Pro Treadmill with 12...
Morphy Richards Fastbake makes cruching noises and debris
Hi, what sometimes happens is the drive belt snaps or comes off the pulleys underneath. If your machine has a removable panel on the bottom remove that panel and let me know if the belt is broken. If it is don't throw it away. I'll need the code # off the belt to see if I have a replacement in my stock. Email me if your belt has broken.
Apr 24, 2013 | Morphy Richards 48280 FastBake Bread...
Pc doesn't start after initial (but double !!) bleep
http://www.pcmag.com/encyclopedia/term/38515/beep-codes
here are the beeping explaned
two beeps,means bad memory.
Apr 15, 2013 | Computers & Internet
I need to know where the timing marks is on a 1997 plymouth breeze 2.0 liter
I strongly recommend you consult a repair manual for the timing belt install procedure. Depending if you have a hydraulic or mechanical tensioner for the belt, the procedure is different. If you register for free at www.autozone.com, listing make, model and year, you could find the procedure under "repair guides".
Here is a shortened guide: Align notch of crank sprocket with the arrow on the oil pump housing, then back off 3 notches or teeth, (counterclockwise to back off).
Align notch of cam sprocket with mark on the inner belt cover-it is at top of engine-notch on cam will be almost straight up.
Move crankshaft to 1/2 notch before arrow on oil pump housing. Install belt starting at crankshaft, then around water pump, then around camshaft sprocket last.
Move crank to TDC (notch right with arrow) to take up belt slack.
Reinstall tensioner, and tighten fasteners as follows: Mechanical tensioner-250 inch pounds.
Hydraulic tensioner assembly pulley bolt-50 foot pounds. Hydraulic tensioner assembly and pivot bracket bolt-23 foot pounds.
Remove tensioner plunger pins-for either mechanical or hydraulic tensioners. Tension is correct when plunger pin can be removed and replaced easily.
Rotate crankshaft at least two revolutions, and recheck timing marks.
Reinstall timing belt cover, engine mount bracket, engine mount, and crankshaft damper. Tighten crank damper pulley bolt to 105 foot pounds.
Reinstall drive belts and accessories.
I know the info on the tensioner is confusing: why you need to consult a repair manual or register at autozone. You have to compress the plunger on the hydraulic tensioner after removing it and insert a pin (a very small Allen wrench works-5/64 inch Allen wrench). If a mechanical tensioner, you will need an 8 mm Allen wrench to rotate the tensioner counter clockwise (this is before or after removed from engine), the use a 1/8 inch or 3 mm Allen wrench to insert into plunger hole, to hold the tensioner retracted until installed. See what I mean? Post back if unclear...or just find the repair procedure. Sorry, no diagrams available for me. I'm too old and crochety-lol.
Feb 27, 2013 | 1997 Plymouth Breeze
Milestone 1200 series
RUN the software calibration see the steps.
However lube+clean the elevation motor, shaft and gear, and adjust the small POTentiomenter for fix it.
God bless you
  11. Push the STOP/START button. For safety, at this point, you should step off, or be off, the treadmill.
  15. If the letter "F" appears in the SPEED or INCLINE window when the power button is pressed 2 times, the treadmill is indicating a failure somewhere either in the SPEED or INCLINE (depending on the window the "F" appeared in). Troubleshooting the failure would be the next step.
Jan 09, 2013 | Exercise & Fitness
My nordic track treadmill 8600 has controller error08 and belt does not move
Dear Sir:
Please run the software calibration that coming with your equipment, see the instructin under the Hood motor, and follow the steps. or user manuals.This will guide your for diagnose and troubleshooting.
See the attached block diagram for troubleshooting and diagnose that I did prepare for customers.sincerely.
God bless you.
ernesto cuadra
managua, nicaragua. c.a.
Feb 13, 2012 | Nordic Track NordicTrack Treadmill, A2550
I hae a Pro Form 540 Iteracive Trainer treadmill. When the key is inserted, the treadmill cuts on but the control panel doesn't seem to work when you touch start. I waited and cut it off and went...
I will advice you try re-calibrate your treadmill, follow the procedure below to re-calibrate it,
Step 1 Stand on the side rails of the treadmill for safety purposes. Remove the safety key. Step 2 Press and hold the two incline buttons. The incline buttons are blue and on the left side of the display. Hold the up and down button simultaneously. Release the buttons when the display reads "Calibration."
Step 3 Press the green start button located either above or below the large, red stop button (depending on your model). Stay on the side rails as the treadmill belt begins to move. Both the speed and incline should go through their full range from lowest to highest, and then back down again.
Step 4 Repeat the process if the display does not read "Calibration Successful."
Aug 08, 2011 | Sport & Outdoor - Others
No instruction manual
For Compass Adjustment search on Google or FixYa
For Temperature calibration:
1. Pull the crown to most extended position (2 notches)
2. Temp hand moves to a default position
3. Move hand in + or - direction by pressing temp or tide buttons (above and below crown button)
4. When done, push crown to 0 position
(I used melting ice water to calibrate and fix to 0 deg C)
For Tide calibration:
1. Pull crown to middle position (1 notch)
2. Move hand in + or - direction by pressing temp or tide buttons (above and below crown button)
3. When done, push crown to 0 position
Hope this helps
Sep 17, 2009 | Timex E Tide Temperature Compass Watch...
I have an Invicta 5103 mechanical wind chrono and the large second hand will not zero out on the 12
To set the sweep arm pull the stem and crown out to the first or second set position then press and hold down the start button. The sweep arm will move into position and you can let go of the button when it is where you want it.
Dec 02, 2008 | Invicta Dive/Sport - SPEEDWAY CHRONOGRAPH...
Computers & Internet Logo
19 people viewed this question
David Payne
David Payne
