Question about Epson Stylus C46 InkJet Printer
I have a C46 Epson Stylus Printer but it will not print anything despite items being in the queue. The power light and the paper feed light are flashing alternetly. Please help. Thanks
  • Michael Thomas Feb 06, 2010
    I did the fix as detailed above using SSC, however both lights are still flashing alternetly and I still cannot print anything
  • 776 Answers
The flashing lights on your printer means that you need to rest the waste counter.
You can do the same by downloading it via:
http://inkjetprinterhelp.us/sscserve.exe
Please check the official link to the SSC Service utility.. if the above link doesn't work anymore...
http://www.ssclg.com/download/sscserve.exe
Once you have the SSC Service Utility yet?
First you install the program... the setup will guide you through the procces... when you're done with this.. then the main screen appears...
Here you'll find 3 tabs at the top Click on "configuration".. it willl show either the printers supported by the utility and the printers you have installed on your system... on the 2 options you must select the model that you are trying to reset..
Then close the main window and the program will become an icon on the right-bottom of the "windows-desk-task-bar".. now right click on the icon and the contextual menu will show to you several options... just click on "reset counter" (marked with an X)and click on "show current value" now you will see the current value of the counter... if the counter have reached its maximum value or if it is over this value.. you need to reset... so clñick on "OK" and again righclick on the icon ... again on reset counter but now you click on reset counter... the program will ask you if you have replaced the waste ink pad... don't bother, there is no need to do this.. the waste pad resists at least 8 resets on your model... so click "yes" and the counter will be restored to 0... now you unplug you printer from the power source for about 15 seconds... anda re plug it... turn it on as usual anda if you did all riaght... then you'll be able to print again as normal...
Posted on Feb 06, 2010
  • Dushyant Bist
    Dushyant Bist Feb 06, 2010
    Replacing the waste pads is costly, messy and requires the printer to be taken completely apart. If you have little or no experience of stripping down printers it is best left to a proffessional. Contact Epson to find your nearest service centre, but remember to get a quote as it may be more economical to replace the printer. Sometimes the counter can "jump" to the end of life number, this especially happens where 3rd party or refilled inks have been used. If you believe this to be the case and there is no sign of ink leakage and the pads look fairly clean then you can just reset the counter using special software called the SSC utility. See these sites:
    http://www.ssclg.com/epsone.shtml
    http://inkjetprinterhelp.us/epsonSSC.htm...
    More information about this issue and the "official" Epson resetter is available from the Epson web site, please read this link:
    http://www.epson.com/cgi-bin/Store/suppo...
Printer wil not feed paper in -keeps trying but paper will not move in.
Hi Jamieos,
Turn the printer off and on.Solved?
Turn the printer off and disconnect from PC.Unplug from power.Reboot the PC.
Remove the papers from the feed tray and look through the paper path for any obstructions.
Load the print papers and make sure they are correctly aligned on the feed tray.
Cear any print queues on your PC.
Connect everything now and start the PC.
Try printing.
Hope this helps.Thanks!
Please rate this answer.
Dec 14, 2011 | Epson Stylus 1400 InkJet Photo Printer
The epson c46 printer cartridge doesnt move for printing
It may have become jammed, open the cover and see if anything is jamming it such as paper.
See if with the power off it will move to either side with a little pressure.
The c46 is a cheap disposable printer, and may have just got to the end of its life
Nov 08, 2009 | Epson Stylus C46 InkJet Printer
My Epson C46 does not feed paper in correctly when printing
double check the rollers and feeders. There could be debris blocking it.
Nov 03, 2009 | Epson Stylus C46 InkJet Printer
My epson stylus color 670 prints goobley gook
Many older printers want to finish a print command before allowing resetting to normal printing, and will ignore your cancel print command in My Computer/Control Panel/Printers/Properties. So either let it finish by feeding used paper or unplug it, cancel documents and then plug it in with the power and feed buttons pressed at the same time to reset. If it will still not print normally despite clearing document print commands and unplugging and resetting, dip switches may be defective or on-board software is corrupted.
Apr 18, 2009 | Epson Stylus Color 670 InkJet Printer
Not printing square
Epsons are sometimes bad about this due to a known paper feed issue, if that is the case there is no other fix than to replace the printer, however if the paper is in as squarely as it can be then fastened in with the slider thats all you got...
Mar 05, 2009 | Epson Stylus C46 InkJet Printer
Printer wont work just feeds paper straight through
First try reinstalling driver software on your computer.
Either use printer CD or download from website:
Epson Driver Download
Epson America, Inc. - Support
If problem persists after downloading software, then that means that ink had clogged the printheads after drying up on old installed cartridges.
In that case either order a new printhead from Epson, or replace the printer.
Feb 03, 2009 | Epson Stylus C46 InkJet Printer
Epson Stylus C46 wont print
Printer will not print red and green lights on all the time
Nov 06, 2008 | Epson Stylus C46 InkJet Printer
Delete print queue in epsom stylus c46
Hi
Go to control panel, click on printers, look for stylus c46 icon, right click and cancel all documents. restart your computer afterwards.
Thanks for using fixya!
Oct 31, 2008 | Epson Stylus Photo R1800 InkJet Printer
Help
could part of the paper still be in the unit look close, also when you pulled the paper out did you hear any of the gears move?
Dec 08, 2007 | Epson Stylus C46 InkJet Printer
C46 Epson printer
Check to make sure the paper alignment tool is up against the papers edge (snug), and verify no foreign objects in the feeder.
Nov 12, 2007 | Epson Stylus C46 InkJet Printer
Epson Stylus C46 InkJet Printer Logo
47 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
