Question about GE Nautilus 24" Built-in Dishwasher
Water is not draining? thank's - GE Nautilus 24" Built-in Dishwasher
  • 1,531 Answers
There are a couple of things that could cause this issue.
1. is the drain pump is faulty
2. the main control board is faulty
3.there is some kind of object stopping the pump from turning
4 the wiring to the pump has become dislodge or loose.
5 there is a blockage in the drain hose from the pump
6 if you have a wet dry shop vac disconnect the drain hose from under the sink and attach the shop vac to the hose and try and remove the water.
If the water drain easy then check in the pump for something that could be stopping the impellar wheel or faulty pump.
If no water comes out then there could be a grease plug blocking the hose you can use a hair dryer and heat the area of hose the grease plug may be in to remove it. good luck i hope this was helpful for you
Posted on Feb 06, 2010
Bosch Dishwasher won't drain.
Is there a hi-loop in the drain line, is water siphoning back in after a drain cycle?
Jul 08, 2016 | Bosch Dishwashers
Dishwasher not draining
Thanks for writing to Fixya.com.
To fix a dishwasher that will not drain, remove any clogs that are blocking the drain line by pouring a paste of baking soda, vinegar and water down the drain, and then pouring boiling water to clear the clog. Repeat the process several times to remove a severely clogged dishwasher drain. Thanks for contacting Fixya and please accept the solution if it has helped you.
May 15, 2010 | GE 24 in. Profile PDW7800 Built-in...
Will not drain water out of tub
Hi
Thanks for using FixYa. Dishwasher not draining properly or not draining at all issues can arise due to different reasons. Usually, these issues are related to kinked hoses, knocked out disposer unit (if connected with the dishwasher drain hose) & clogged drain pump & filter.
Also note that dishwashers do not drain completely after a finished cycle and this is normal. Dishwashers are designed to leave some water in the unit to ensure that the heating element doesn’t overheat. If you suddenly begin to experience a large amount of water being retained in your dishwasher, you have a problem. Some of the most common reasons include that the drain hose isn’t working properly, the drain pump isn’t working correctly, or possibly there is a plumbing problem in your home’s drain lines.
First check whether the drain is not clogged or blocked and the line is not kinked. Check all the hoses for blockages & also clean the air gap. Has the disposer been replaced recently? If so, chances are the knockout is still in place. Simply remove the drain hose from the disposer, and knock out the plug. If the disposer has not been replaced, try removing the drain hose from the disposer and use a wet-dry vacuum (prepared for water, of course) to **** any water (and hopefully anything else) from the drain line. Then reconnect the hose, and test the unit. If you have checked the air gap and the drain hose and can’t locate the problem, then it is an issue with the drain pump of the dishwasher.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Oct 26, 2009 | Kenmore Dishwashers
After rinse drain, there is no spinning happening...
de stands for drain error... the sensor has gone or the torque motor
Jul 12, 2009 | Whirlpool Washing Machines
Will not fill with water goes right down the drain,works sometimes
Your drain line is too low or there is a air gap blockage.
Remove the drain line from the drain and hold it up high while filling with water and see if it fills and stops.
If so, correct the drain line problem.The drain hose should be 36 inches from the floor.
Apr 12, 2009 | Kenmore 22422 Top Load Washer
Kenmore # 63142 Fridge -- Water in Freezer
If water drains out, then there is always a blockage somewhere on drain line.
Defrost the unit completely to get rid of ice building inside drain lines.
If that does not work , then the drain line must be unlocked using a flexible shaft.
Apr 04, 2009 | Kenmore 63142 / 63144 Top Freezer...
Water Leaking
HI thanks for your question. the drain tube in the freezer is clogged, not allowing the defrost water to go down to the drain tray. to repair. turn fridge off , for 24 hrs. remove back panel from fridge clean all coils. locate the drain tube by the drain tray. use a small hose to shove up the drain tube And blow , to clear the debris from the drain tube. thanks the appliance doc. please rate my answer. thanks
Oct 14, 2008 | Frigidaire FRS26R4C Side by Side...
Drain old water
hi thanks for the question. to drain washer.put hose on floor in bucket. this will drain your washer thanks. for the question the appliance doc
Oct 04, 2008 | Kenmore 22062 Top Load Washer
GE Nautilus 24" Built-in Dishwasher Logo
170 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
