Question about Microsoft Windows XP Home Edition
Hard drive not opening
When I try to open my hard drives(C,D,E)it asks to select a programme from a list to ''open with''.
  • 2,427 Answers
Can you say virus ???
try a system restore to a previous date in the time which it was working
download and use avg free anti virus
download and run super anti spyware (free edition)
download and run TuneUp Utilities 2008
if after you follow the above instructions and it fails
Please format your harddrive and reinstall everything..
Posted on Feb 21, 2008
My iomega 1tb hard drive stopped working and is not being recognized, how do i get my data ?
You must do quick format, no full format, then, after it , you can us ,,Recuva,, or ,,Easy undelate ,., programms, for recover your files,
or it http://www.diskinternals.com/fat-recovery/, its too very good programm.
Apr 24, 2012 | Iomega Computers & Internet
I purchased a Toshiba Canvio 3.0 500 GB portable hard drive, and plugged it into my MacBook with Mac OS X Tiger. The icon for Toshiba EXT came up on the desktop but wouldn't do anything. The box came...
1 . Open the system drive, usually titled "Macintosh HD." Open Applications, then Utilities and double click the "Disk Utility" program to open it. A window will open giving a list of all the drives currently mounted on the computer.
2. Select the disk that needs to be formatted on the left. It is not possible to format the startup disk unless the system has booted from the Install Disk. It is important to note that formatting the startup disk will permanently erase the data stored on the disk. If you are planning on erasing the startup disk, back up all important files and applications.
3.
Click on the "Erase" tab to the right of the list of drives. The window will now display the options for erasing the hard drive and formatting it to work on the Macintosh computer.
4. Select the Volume Format from the pop-up list. In most cases it's best to leave it at "Mac OS Extended (Journaled)" as this is the default. This setting is the best option for running Mac OS X. If there are other requirements for the disk, then select the format that best suits your needs.
  • 5. Name the hard drive. Type a name for the disk in the field where it asks for the name. This name will always appear when the disk is mounted on a Macintosh computer.
  • 6. Click the erase button. A window will open asking to verify the erase procedure. Click the erase button in this window to start the process of erasing the disk. Once the process is complete, the drive will appear with the name it was given on the left side of the window with the list of drives and on the desktop of the Macintosh computer.
    Aug 30, 2011 | Toshiba Canvio 500 GB USB 20 Portable...
    My flashdisk APACER cannot save may document , please Help me...!!
    click start all programs accessories open windows explorer my computer you should see your drive click to open it from there you select the files right click on the file/s right click copy navigate back to the drive right click select paste or hold the mouse cursor the file/s drag them to your usb drive then drop them in
    if you are using a word document open it up select file from the dropdown list select safe as a browse option will open navigate to your 2 gb Kingston usb drive
    or if its a web page right click in the top toolbar (top of screen) you should see a list of options select menu tab this will add file edit view favorites tools and a help tab
    hope this helps
    Aug 21, 2011 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
    Mac G5, what is pin set up. my computer doesn't see my new hard disq WD1002FAEX
    If it is not seeing it then you will need to format it properly for Mac's most hard Drives are pre-formatted for PC's.
    You also need to make sure the SATA cable is plugged into the right place on the board.
    SATA Hard Drives do not need a pin out. Only IDE drive's have that function.
    If this is an addon drive then
  • Select the disk that needs to be formatted on the left. It is not possible to format the startup disk unless the system has booted from the Install Disk. It is important to note that formatting the startup disk will permanently erase the data stored on the disk. If you are planning on erasing the startup disk, back up all important files and applications.
  • Click on the "Erase" tab to the right of the list of drives. The window will now display the options for erasing the hard drive and formatting it to work on the Macintosh computer.
  • Select the Volume Format from the pop-up list. In most cases it's best to leave it at "Mac OS Extended (Journaled)" as this is the default. This setting is the best option for running Mac OS X. If there are other requirements for the disk, then select the format that best suits your needs. If you have questions about the formats, refer to the Apple user's manual.
  • Name the hard drive. Type a name for the disk in the field where it asks for the name. This name will always appear when the disk is mounted on a Macintosh computer.
  • Click the erase button. A window will open asking to verify the erase procedure. Click the erase button in this window to start the process of erasing the disk. Once the process is complete, the drive will appear with the name it was given on the left side of the window with the list of drives and on the desktop of the Macintosh computer.
  • I got these instructions off ehow.com
    Jul 02, 2011 | Western Digital WD Caviar Black WD1002FAEX...
    Reformatting toshiba portable hard drive for mac, since the one i have says for windows pc
    Note: I'm assuming you have a working mac; if you don't, then post back to this solution with that information.
    1. Connect the external hard drive to your mac.
    2. Open the system drive, usually titled "Macintosh HD." Open Applications, then Utilities and double click the "Disk Utility" program to open it. A window will open giving a list of all the drives currently mounted on the computer.
    3. Select the external hard drive that needs to be formatted on the left.
    4. Click on the "Erase" tab to the right of the list of drives. The window will now display the options for erasing the hard drive and formatting it to work on the Macintosh computer.
    5. Select the Volume Format from the pop-up list. In most cases it's best to leave it at "Mac OS Extended (Journaled)" as this is the default. This setting is the best option for running Mac OS X.
    6. Name the hard drive. Type a name for the disk in the field where it asks for the name. This name will always appear when the disk is mounted on a Macintosh computer.
    7. Click the erase button. A window will open asking to verify the erase procedure. Click the erase button in this window to start the process of erasing the disk. Once the process is complete, the drive will appear with the name it was given on the left side of the window with the list of drives and on the desktop of the Macintosh computer.
    Good luck, please post back to this solution if you have any difficulties, and thanks for using FixYa.
    Apr 28, 2011 | Computers & Internet
    How do I format my new WD Elements SE 500GB for Mac OS Snow Leopard
    hi.
    follow instructions below
    1> Open the system drive, usually titled "Macintosh HD." Open Applications, then Utilities and double click the "Disk Utility" program to open it. A window will open giving a list of all the drives currently mounted on the computer.
    2> Select the disk that needs to be formatted on the left. It is not possible to format the startup disk unless the system has booted from the Install Disk. It is important to note that formatting the startup disk will permanently erase the data stored on the disk. If you are planning on erasing the startup disk, back up all important files and applications.
    3> Click on the "Erase" tab to the right of the list of drives. The window will now display the options for erasing the hard drive and formatting it to work on the Macintosh computer.
    4> Select the Volume Format from the pop-up list. In most cases it's best to leave it at "Mac OS Extended (Journaled)" as this is the default. This setting is the best option for running Mac OS X. If there are other requirements for the disk, then select the format that best suits your needs. If you have questions about the formats, refer to the Apple user's manual.
    5> Name the hard drive. Type a name for the disk in the field where it asks for the name. This name will always appear when the disk is mounted on a Macintosh computer.
    6> Click the erase button. A window will open asking to verify the erase procedure. Click the erase button in this window to start the process of erasing the disk. Once the process is complete, the drive will appear with the name it was given on the left side of the window with the list of drives and on the desktop of the Macintosh computer.
    regards
    Apr 23, 2011 | Western Digital Wd Elements Se 1tb...
    How do I reformat my Iomega eGo hard drive so that it is compatible with my Mac? OSX 10.6.6 The current IOmega format is FAT
    First of all, connect the Iomega to you mac, make sure it powers up and is detected by the Mac. Now follow these steps: ( It's important to note the Drive before you begin this task so that you may not make any mistakes.)
    • Open the system drive, usually titled "Macintosh HD." Open Applications, then Utilities and double click the "Disk Utility" program to open it. A window will open giving a list of all the drives currently mounted on the computer.
    • Select the Volume Format from the pop-up list. In most cases it's best to leave it at "Mac OS Extended (Journaled)" as this is the default. This setting is the best option for running Mac OS X. If there are other requirements for the disk, then select the format that best suits your needs. If you have questions about the formats, refer to your Apple user's manual.
    Let me know if you need further help.
    Good Luck.
    Thanks for using FixYa.
    Feb 08, 2011 | Iomega 500GB eGo Helium Portable USB 2.0...
    I cant open my attatchment on yahoo mail it just keeps saving them but wont open them or let me read them
    To read the attachment associatedn programm must be installed on your Laptop. Also please check Antivirus setting. I think Antivirus may be blocking attachement file to be open.
    Mar 09, 2010 | Toshiba Satellite A100-S8111TD Notebook
    Unable to open drive d by double clicking
    your drive is most probably infect by a virus,
    to fix this problem go to this link below.
    http://tinyurl.com/ytatdl
    it will give you an option to save file,
    save it
    then install it
    then run that program called "COMBOFIX"
    IT WILL REMOVE THE VIRUS AND YOUR PROBLEM WILL BE FIXED.
    Jun 09, 2009 | Microsoft Windows XP Home Edition
    Hard disk Problem
    Some application has modified the default action that windows should take when opening the disk drives, by the moment, you can access the disks right clicking and selecting OPEN in the menu.
    You have to reinstall windows to restore the default open action or look and try to restore it manually from "Folder Options" > "File Types".
    Feb 10, 2008 | Acer Aspire™ T180 PC Desktop
    Microsoft Windows XP Home Edition Logo
    35 people viewed this question
    Top Microsoft Computers & Internet Experts
    micky dee
    Alun Cox
    Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
