Question about HP Compaq Presario F750US
My wireless antenna seems to be broken and wont pick up a signal for the wifi...how can i fix this
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
    Sniper:
  • 81 Answers
Update the BIOS and the drivers for the wifi.
If it doesnt work out the wireless card is the issue, needs to be replaced
Posted on Feb 06, 2010
I only get a wifi connection when I am next to the wifi hub. I lose the signal when I move 4 meters from the hub. Other laptops pick up the wifi without problem. I have tried using the zenbook on main
It's may be the laptops Antenna? Wire broken, pinched, damage, connection loose. The Antenna is usually behind the monitor, wires run from the wireless adapter through the hinges and attach to the antenna, Maybe a loose connection on the Wireless adapter itself? Sometimes you can access through a bay door on the bottom of the laptop, sometimes you have to disassemble the laptop/keyboard, depends on the Asus Model. Have you connected a Ethernet cable?
Jan 08, 2013 | ASUS Computers & Internet
Weak wireless signal
Its the problem with your devices wifi adapter.
Just take your device to an authorised dealer and get it serviced.
Jun 10, 2012 | Computers & Internet
Can you recommend a signal booster for a Thompson st585v6 so I can increase the wireless range? Thank you
WiFi BoosterA wireless USBInternet adapter with a 54Mbps 802.11Gadapter with a powerful antenna,From WorldStart, please click on this link totheir WEB site:- http://store.worldstart.com/product/5412Boost Wireless Network - 2.4GHz DipoleMIMO (multi-input, multi-output) antenna
http://www.jaycar.com.au/productView.asp?ID=AR3280http://www.alibaba.com/product/tw103028965-103211250-100674400/MIMO_ANTENNA.html
May 30, 2012 | D-Link RangeBooster G WBR-2310 Wireless...
Weak Signal
You can buy antenna's that will extend the range of your wifi signal. Go to www.ebay.com Type: wifi extender, wifi antenna, and wifi range one of these should give you what you need.
Apr 23, 2012 | Panasonic SH-FX50
My laptop stopped picking up wifi after a much needed modification. I have a 3 year old hp pavilion dv9000. the hinges broke so I decided to remove the monitor of the laptop and hook it up to a desktop...
That is because the WI-FI antenna wires were on the LCD panel behind the glass.
Currently your laptop base has no signal. The only solution is that you may pick up a signal with the base alone, if it is near the wireless router about 20' (3 meters).
Apr 19, 2011 | HP Computers & Internet
How do i increase wi-fi signal strength
There are only a few ways to increase signal strength ..move closer to the source (the router) , get a bigger antenna or boost the signal...you can boost the signal with foil in the shape of a parabola around the router antenna or make one out of a vegatable strainer that will plug into the laptop(this one works best )especially for picking up your neighbors WIFI
http://www.focus.com/briefs/mobile-wireless/home-made-wifi-antenna/
Dec 27, 2010 | Computers & Internet
Excellent signal low speed transfer
You can boost the signal range of a WiFi computer network in several ways: Answer:
  • reposition your router (or access point) to avoid obstructions and radio interference. Both reduce the range of WiFi network equipment. Common sources of interference in residences include brick or plaster walls, microwave ovens, and cordless phones. Additionally, consider changing the WiFi channel number on your equipment to avoid interference.
  • upgrade the antenna on your router (or access point). WiFi antennas on most wireless base stations can be removed and replaced with more powerful ones.
  • add another access point (or router). Large residences typically require no more than two APs, whereas businesses may employ dozens of APs. In a home, this option requires connecting your primary wireless router (access point) to the second one with Ethernet cable; home wireless routers and/or APs don't normally communicate with each other directly.
  • add a bi-directional WiFi signal amplifier to wireless devices as needed. A WiFi signal amplifier (sometimes called "signal booster") attaches to a router, access point or Wi-Fi client at the place where the antenna connects. Bi-directional antennas amplify the wireless signal in both transmit and receive directions. These should be used as WiFi transmissions are two-way radio communications.
  • add a WiFi repeater. A wireless repeater is a stand-alone unit positioned within range of a wireless router (access point). Repeaters (sometimes called "range expanders") serve as a two-way relay station for WiFi signals. Clients too far away from the original router / AP can instead associate with the WLAN through the repeater.
Nov 19, 2009 | Sony Computers & Internet
Laptop wont pick up wireless signal anywhere
maybe your wifi radio is turn ON. you have to turn it ON manually using a hard switch button found in the laptop's body. or using a key combination in your keyboard. Make sure that the wifi LEDis lit.
Aug 14, 2009 | HP Pavilion dv6000 dv6100 dv6200 dv6300...
My wifi will only work inside buildings
wireless has limited range and can be affected by walls, doors, glass. Some models of routers if they have removable antenna's can be replaced by highgain antenna's which can drastically improve your range.
Apr 16, 2009 | Acer Aspire 3680 Laptop
DI-524 wireless router no signal missing antenna
tat dlink device is a good device i shld techinically still produce signals
but wat happened to antena if it is broken u might as well go for new router
as far i remember u wont get antena seperatly
on ur mac book scan for signal see if u are pick up signal
if yes you are lucky it shld still transmit else go for a new router
Dec 08, 2008 | D-Link Dlink DI-514 Air Wireless 2.4 GHz...
HP Compaq Presario F750US Logo
237 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
