Question about Apple iPhone Smartphone
I tried to enable mms on my 2g. I installed Native MMS2g and I reset the phone. Now it will not turn on. The little apple icon comes up but the phone never turns on.
    President:
  • 8 Answers
To enable MMS on your iPhone 3G you just need to go to
Settings >> General >> Network >> Cellular Data Network
I tried to enable mms on my 2g. I installed Native - enable-mms-iphone-3g-os-30-t-mobile-01-166x241.jpg
enable-mms-iphone-3g-os-30-t-mobile-04-166x241.jpgenable-mms-iphone-3g-os-30-t-mobile-05-166x241.jpg
Then Under MMS, enter the following details:
  • APN: wap.voicestream.com
  • Username: leave blank
  • Password: leave blank
  • MMSC: 216.155.174.84/servlets/mms
  • MMS Proxy: 216.155.165.50:8080
  • MMS Max Message Size: leave blank
  • MMS UA Prof URL: leave blank
Once entered, reboot your iPhone.
Go to Messages. There you will find the sweet liI tried to enable mms on my 2g. I installed Native - enable-mms-iphone-3g-os-30-t-mobile-06.jpg text input box.
Congratz you have enabled MMS on iPhone 3G OS 3.0 for T-Mobile. You can use that icon to send Pictures, Audios and Videos to your loved ones at the same price as of a Text Message means NO additional charges for MMS on T-Mobile Network.
Cheers!
Posted on Feb 07, 2010
Yes I have the camera now but icant receive no picture or send
Posted on Dec 12, 2011
Can not send photo in texting box because camera icon is not working
iMessage or MMS needs to be enabled and activated to send photos.
Apr 04, 2015 | Apple iPhone Cell Phones
I can't make calls nor receive
Check to make sure phone is registering in network. Check a network is selected. Try the following.
APN & data settings To set the Access Point Name (APN) and turn on data settings, follow these steps:
  1. From any Home screen, tap the Menu key.
  2. Tap Settings.
  3. Tap the Connections tab.
  4. Tap More networks.
  5. Tap Mobile networks.
  6. Tap Access Point Names.
  7. If available, tap the T-Mobile US APN (the bullet point fills with green). If not available, tap the Menu key, and then tap New APN.
    Note: To reset your APN settings, tap the Menu key and then tap Reset to default.
  8. Verify and update the following settings for the Data APN:
    • Name: T-Mobile US LTE
    • APN: fast.t-mobile.com
    • Proxy: <Not set>
    • Port: <Not set>
    • Username: <Not set>
    • Password: <Not set>
    • Server: <Not set>
    • MMSC: http://mms.msg.eng.t-mobile.com/mms/wapenc
    • MMS proxy: <Not set>
    • MMS port: <Not set>
    • MMS protocol: WAP 2.0
    • MCC: 310
    • MNC: 260
    • Authentication type: <Not set>
    • APN type: <Not set> OR Internet+MMS
    • APN protocol: IPv4/IPv6
    • APN roaming protocol: IPv4
    • Enable/disable APN: <greyed out unless there are multiple APN's>
    • Bearer: Unspecified
  9. Tap the Menu key.
  10. Tap Save.
  11. Tap the desired APN profile you want to use. The bullet point fills with green next to the APN profile.
Manual network selection To manually select the wireless network the device connects to, follow these steps:
  2. Tap Settings.
  6. Tap Network operators.
  7. Tap Search now.
The device detects and registers on wireless networks inside T-Mobile's calling area, but roaming networks are usually restricted to T-Mobile SIM cards. You can manually select a network only in areas where T-Mobile does not own GSM spectrum.
Switch 2G / 4G To change the band between 2G and 4G, follow these steps:
  2. Tap Settings.
  6. Tap Network mode.
  7. Tap one of the following desired band settings:
    • GSM / WCDMA (auto connect)
    • GSM only (2G only setting)
    • WCDMA only
Turn on / off Airplane mode Airplane mode turns off wireless connections. This allows you to use apps and menus, but not make calls or use the internet.
To turn on or turn off airplane mode, follow these steps:
  2. Tap Settings.
  5. To turn on, tap Airplane mode to select the check box. Tap OK.
  6. To turn off, tap Airplane mode to clear the check box. Tap OK.
Jul 06, 2014 | Cell Phones
I can't send picture messages on my iphone 4
The easiest if your phone is jailbroken is to install the EditAPN package from repository http://beta.leimobile.com/repo/, and configure the MMS proxy settings according to Net10's directions for non-iPhone smartphones. This tweak re-enables the "Cellular Network" options under Settings/General/Cellular (you need to scroll down to see the option)
Note that Net10 specifically does not support MMS on iPhones, probably because AT&T has the MMS settings editing turned off.If your iPhone is not jailbroken and you do not wish to jailbreak it, it's supposedly possible to enable the "Cellular Data Network" option using a different SIM card, but I haven't been able to do this -- so I recommend jailbreaking.
Feb 21, 2013 | Apple iPhone 4 Black Smartphone
Hi to all my Iphone 2G stays on a thin red battery icon, blinks 3 times and goes black. By repushing sleep same process. The apple logo never comes up. DFU modus not possible. I opend the phone and...
try restoring the phone back to factory settings but hold down home button while plugging it in to itunes it should hopefully kickstart it into recovery mode..you cant get it to restore it may just been down to hardware issues in the phone, after all it is a 2g...you could also try getting an appointment in an apple store if you have no luck restoring and resolving problem but make sure you dont say youve opened the phone up.
Jan 01, 2011 | Apple iPhone Smartphone
Hi, i jailbreaked and unlocked my husbands iphone 2g. It was working fine until he try to install native mms, it froze. I don't know what he did but iphone reads sim card but itunes does not recognize it....
when u jailbreak and use itunes u have to get app sync or u will leave ur iphone frozen in a state that u cant restore no only other way is if u uninstall itunes and then reinstall
Oct 22, 2009 | Apple iPhone Smartphone
I want to send picture texts on my apple iphone, how do i do this? i know i can email them but the other persons phone only has picture texts not email and i still want to send pxts.
Depends what Iphone you have, they can only be sent if you have OS 3.0, and only on Iphone 3G or 3GS.
To enable MMS go to settings/messages then turn MMS messaging on.
You compose mms from the same program (messaging) but there are options there to add pictures and audio
Jul 14, 2009 | Apple iPhone Smartphone
Ipod touch: 50 blank icons and i cant get rid of them
you could try erasing it and start over again ?
Jun 21, 2009 | Apple iPod touch
IPhone will not switch on
hi, i'm using a 3G 3.0 version. while downloading an application from cydia which was for a 2G(MMS application) and when it tried rebooting.. it just dint switch back on.. all i saw was the apple logo.. Any solution?
Jun 07, 2009 | Apple iPhone Smartphone
Iphone 2g only apple icon on the screen
Ok, what you need to do is a full restore and unlock again. First you need to get it in Recovery Mode so the computer can read it. Press power and home buttons while connected VIA USB till you get the message in the Itunes that you need to restore, then restore and unlock.
If you dont know how to unlock www.iclarified.com, they have really good tutorials step by step.
Best regards,
Julio de la Cruz
Feb 12, 2009 | Cell Phones
Apple iPhone Smartphone Logo
262 people viewed this question
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
Lesley Cameron
Lesley Cameron
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
