Question about Sony VPL-VW100 (Ruby) Multimedia Projector
My sony vpl-vw100 makes a buzzing/humming noise when i turn it on. I have tried to do the reset troubleshooting tip and that has not solved the problem.
SOURCE: Reset Timer Lamp Sony VPL-HS60 projector
To reset the lamp timer:
1) With the projector plugged in and turned off, press the 'ON/STANDBY' button to put the projector in 'STANDBY' mode. NOTE: You have to press the button on the projector itself, you cannot use the remote for this step (this is not clear in manual).
2) Now, using the remote, press the following keys in order: RESET, <--, -->, ENTER.
3) Timer should now read '0'.
Posted on Feb 02, 2008
mistersony
  • 320 Answers
SOURCE: Sony VPL-VW100
OK It SOUNDS like you have problems on one of the two power boards (designated GA and GB). There are a couple of things I need you to do the next time it acts up.
1) if any lights flash, count the number of flashes. It should be a repeating cylce of so many flashes.
2) If it won't come on, unplug it for 3 or 4 minutes (to let the power supplies discharge) and then plug it back it but don't try to power it on. Count the number of clicks you hear right after you plug it in. This is very important and it tells me if one section of the supply is not coming on.
I hope this helps. Feel free to rate this solution and to award the premium solution to whomever you please.
Posted on Oct 31, 2008
  • 4234 Answers
According to the manual, you need access to the RESET button, the left and right arrows and the ENTER button to clear the counter. Press the following in order for less than 5 seconds each:
RESET
Left Arror
Right Arrow
ENTER
The above sequence should clear the counter.
Dan
Posted on Apr 09, 2009
welcomejee
  • 10594 Answers
SOURCE: how to reset lamp on sony lcd projector xga vpl-px20
After replacing lamp, connect projector AC power cord and turn the projector in standby mode.
Press following keys on control panel for less then 5 seconds each..
RESET, <==, ==>, ENTER.
That will reset lamp timer in projector.
Thanks.
Posted on Jun 01, 2009
projdoc
  • 2237 Answers
SOURCE: Lamp timer reset not occurring with the remote control
with the projector in standby (lamp not on), press in order: reset, <-, ->, enter. then turn it on.
Posted on Nov 16, 2009
Transmission buzzing
Click this link below to troubleshoot the buzzing noise problem from transmission:---http://technoanswers.blogspot.in/2012/02/transmission-is-making-buzzing-noise.html
--------This will help.Thanks.
Feb 19, 2012 | 1999 Toyota Camry
Why is it in black and white and not color?
reset the settings to factory default and swap out the cable. if that doesn't work, you have a processor issue on the main board. it'll need to be replaced..
Feb 03, 2010 | Sony VPL-VW100 (Ruby) Multimedia Projector
Nov 12, 2009 | Office Equipment & Supplies
The clean your filter warning sign comes up and then shuts the projector down in 1 min. I have changed the lamp and filter. How do i reset the timer for the Lamp Hours and get rid of the warning?
Once the filter is replaced, plug the projector back in and make sure the projector is in standby mode.  Point the remote control at the projector and press the following buttons in order in less than 3 seconds: reset, ←, →, enter.  This worked for me.  Good luck.
Feb 21, 2009 | Sony VPL-VW100 (Ruby) Multimedia Projector
High pitched sound from my sony VPL-VW100 projector
I have the same problem...did you ever get your high pitched sound fixed?
Nov 29, 2008 | Sony VPL-VW100 (Ruby) Multimedia Projector
Sony Projector
Training manual sent from my Yahoo account: satguy84@yahoo.com
Should be on it's way to you now.
Nov 01, 2008 | Sony VPL-VW100 (Ruby) Multimedia Projector
Sony Projector
Ok we're back to the flashing lamp cover LED. The green flashes you are seeing is the TV trying to start up. After it tries for awhile, it will eventually shut down and display an error code, in this case, the lamp cover LED flashing which means either the lamp cover, filter cover or main cabinet sensing switches are not closed, are intermittent or have some kind of wiring issue. A solid lamp cover light (no flashing) would point to the lamp and lamp drive, but the flashing light points to the switches. Give me an email address and I'll send you the training and troubleshooting manual so you can see for yourself. Any ther help needed, please don't hesitate to ask.
Sony VPL-VW100
Oct 31, 2008 | Sony VPL-VW100 (Ruby) Multimedia Projector
Sony VPL-VW100 (Ruby) Multimedia Projector Logo
155 people viewed this question
Top Sony Office Equipment & Supplies Experts
shaun taylor
Jaime Hernandez
Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
