Question about Whirlpool Duet GHW9150P Front Load Washer
HELP! I have a whirlpool HE3 frontload washer and it is stuck on "Control Locked". I did try holding "end of cycle" button for 3-5 sec. and I also unplugged washer for at least 30 min. as suggested with no luck. I have always repaired my owen washer/dryer with the assistance of this sight...thank you! but this one has me baffled. Any suggestions? I'd rather not pay the big bucks.
    President:
  • 2,468 Answers
You can manually open the door by first unplugging unit from power,then remove lower toe kick panel under door,reach up to find the door latch assembly and feel for a small tear-shaped plastic tab located on bottom of door latch and pull downwards 1/4" till you hear a click and door should open manually
Posted on Feb 06, 2010
Duet ht washer control locked. How do I unlock it? Really need your help
Hello & Welcome to FixYa
This is a common issue with Whirlpool Duet washers however, your whirlpool duet washer can be reset to resolve the control lock problem. Press and hold the END OF CYCLE/CYCLE SIGNAL button for 15 seconds to reset the control. Please get back to me if you have any other questions.
Kevin
Apr 25, 2011 | Whirlpool Duet GHW9150P Front Load Washer
I have a whilrpool frontloader and it is stuck on "control locked" how do I unlock it?
Look for the End of Cycle button on the control panel then press and hold it for 3 seconds or until the Control Locked indicator turns off. There's actually a marking under the button saying "Hold for 3 Seconds to Lock/Unlock Control". Unplug the machine for at least 30 minutes to forcibly reset the control and to eliminate the possibility of an electronic glitch if pressing and holding the End of Cycle button does not work. Replace the control if unplugging and the pressing the End of Cycle button fails to unlock it.
Mar 04, 2011 | Whirlpool Washing Machines
My control panel is stuck on locked.
hold *end of cycle signal* button for 3-5 sec.....
Jan 17, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet washer stuck in "control locked"
Press and hold the end of cycle button for 15 seconds this should clear it.
Control locked
Nov 26, 2010 | Whirlpool Washing Machines
Whirlpool Duet Dryer is stuck on "Control Lock" and no other controls will work. This happened when plumber had to move it to install new hot water heater. Please help! Thank you
Press and hold the End of Cycle button for 3 seconds or until the Control Locked indicator turns off. Unplug the machine for at least 30 minutes to forcibly reset the control and to eliminate the possibility of an electronic glitch if pressing and holding the End of Cycle button does not work. Replace the control if unplugging and the pressing the End of Cycle button fails to unlock it.
Nov 14, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Front loadin washer says control locked!
The Control Lock is a designed safety feature that enables the us to lock the control panel to prevent small children from manipulating the controls and accidentally starting the appliance.
The controls can be easily locked or unlocked by pressing and holding the following button on the front panel:
Whirlpool Duet Washer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds to 10 seconds.
Please do refer this link for a detailed explanation for your knowledge.
http://www.fixya.com/support/t4186517-control_lock_light_machine
Apr 11, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I was doing a load of laundry and the washer "froze" i tried to cancel the load but it wont stop.... i ended up unpluging it and even when i plugged it back in its still stuck!!!
Locking controls
The Control Lock prevents unintended use of the washer. You
can also use the control lock feature to prevent unintended cycle
or option changes during a cycle. When CONTROL LOCKED is
lit, all buttons are disabled. You can lock the washer while it is
operating.
To lock the controls
Select and hold END OF CYCLE SIGNAL for 3 seconds.
The CONTROL LOCKED status light glows.
To unlock the controls
Select and hold END OF CYCLE SIGNAL for 3 seconds until the
CONTROL LOCKED Status light turns off.
Nov 10, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washer is stuck on control locked
Press & hold 'end of cycle' at right of panel for 3 seconds. The light will come off.
And rate me plz....................
Mar 27, 2009 | Whirlpool GHW9100L Front Load Washer
Whirlpool Duet dryer
look for a button with lock symbol beside it press and hold button 3-5 secs lock light should go out and control resume operating
Aug 12, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
209 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
