Question about RoadPro RPPI-2500W Inverter
My inverter 1000w is not working.
They is no power on my inverter.
  • 714 Answers
Sadly replacement is the best option.
The better inverters are a pure-sine wave would recommend a 1500w it is better quality and will be a better replacement for you 1000w.
Hope this tip helps.
r/
David
Posted on Feb 10, 2010
Just connected my durite 1000w inverter to battery wrongly got a big spark now will not work
Check the fuses . Look inside for a fuse on the circuit board. There may be some burned up components inside too.
Jan 26, 2015 | Electronics - Others
The blue inverter power is 1000w It can't genrate a water pump 300w Or 100w why
to me the watt realy dosent matter in this situation.what you have to do is that you connect the water pump to a breaker fuse which will control the load.not all inverters releases much current to pumping machings to work and even sometimes it ends up burning the inverter
Oct 12, 2012 | Heating & Cooling
I have a auto pro 800 watt inverter that gives 220volt ac **** wont run my kellerman freezer it runs in the house on ac can you help
If your freezer need more than 800 watts to run then your 800 watt inverter will be overloaded and it will shutdown.
Mar 21, 2012 | Vector 1000w Power Inverter
Hi. I plugged a 600w oven grill and a kettle which is 110w into a 1000w Ring power 1024 inverter 24v-240. And now it dont seem to work. The inverter is wired straight to the battery.
Does it work if you plug in just your smallest appliance 110W?. How about just your 600W appliance What size wire are you using to supply power to the inverter? The inverter will draw about 30 amps from the battery with your load. You need to use wires as large as a number 8 from the battery to the inverter. The length should be as short as possible but could be 20 ft away. My inverter is a 2000 Watt continous and I use welding cable size 0 at about 3ft max between the battery and the inverter.
Jan 29, 2012 | Electronics - Others
Bought a Pyle PINV6. Hooked it up to the battery and the unit's light and fan come on, but no power from the two electrical sockets. Too late to return the item.
I had the same trouble with a motomaster Inverter. Just keep turning it on and off slowly and it should come around and start to work.I know sounds stupid but it works.
Apr 05, 2011 | PINV6 1000W DCtoAC Power Inverter
Is my inverter working correctly?
An inverter should work immediately.
Jun 10, 2010 | Electronics - Others
I had my inverter stored and when I connected it today it only had a 30VAC Output it is a power express pure sine 1000W inverter any ideas?
did you check the fuses there should be two one for AC one for DC ( depends on brand and quality) If not then I would suspect a breakdown of the power transistor.
Aug 20, 2009 | Electronics - Others
No power output from my vector 1000w inverter.
Buy a different brand of inverter. Yours has developed a short which the protection circuit is catching. It then tries a restart but fails all over again. Most likely o/p short which looks like an overload to the inverter.
Jan 30, 2009 | Electronics - Others
Sounds like a ground issue,Try this,Take the jumper cables and hook just the neg clamp tho the battery and the other end to the case of the inverter for a direct ground and see if that works..
Please rate this fixya
Jan 26, 2009 | Vector 1000w Power Inverter
RoadPro RPPI-2500W Inverter Logo
298 people viewed this question
Top RoadPro Electronics - Others Experts
jdthefixer
deton8 von Splosion
Are you a RoadPro Electronics - Other Expert? Answer questions, earn points and help others
