Question about Nintendo DS Lite Console
My Action Replay nds refuses to be detected by the PC no matter what I do!
I tripped over the charging cord in my bedroom and the DS fell off my bed and hit the ground hard. It worked fine for a while (the AR) but then I went to modify a code and it screwed up and erased all of my games! I figured it had gotten a problem with modifying codes when I dropped it and I would have to add codes through the PC from now on. At the time I only had a mac so I had to wait until we got a PC. But when we finally got a PC I tried and tried to hook up my action replay but it never got past "waiting for DS." I fully charged the DS and updated and re-installed the software but nothing seems to work! :-(
  • james_273 Mar 19, 2009
    I Loaded the software onto PC and put the AR into the DS all worked fine, with the PC seeing the DS. I pressed to update as instructed the system deleted all files on the AR, then started to write the updated files. The system then locked out with an ERROR Code 0 and the PC locked out. Rebooted the whole lot. switched the DS on, plugged in the AR. and guess what NOTHING !. The DS won't even recognise the AR
    the PC says its not conected. so I have lost eveything. Tried the AR on 3 other DS units, same thing , nothing at all. Can the AR thing be reset in some way? It seems like you just bin it when there software screws it up.
  • 25 Answers
First, insert your Action Replay Installation disc into your CD Drive
Next, plug in your DS through the USB cord, your computer should prompt you to install the NDS link (If it's a USB port, say yes anyways because it will install the NDS Link O.o)
Afterwards your DS should be seen by the code manager
Now after you have that all sorted out:
First, Reset your DS by doing the following:
Hold A+B+SELECT+START When the white screen shows up (The white screen will remain there for a while longer than normal)
Release the four buttons when the menu shows up
Lastly, connect your DS to the computer, you should now be able to enter codes/games again
There really is no need to buy a new or used Action Replay for these two problems, then you just hit the quick-update button and your Code Manager will load as many games as it can onto your Action Replay
Posted on Aug 22, 2008
  • Teriki Tora
    Teriki Tora Aug 22, 2008
    When I said DS for resetting, I mean Action Replay, after you start it up (after that DS warning screen)
  • 4 Answers
Try to get action replay and it has all the code in usa through 2006 to 2007
Posted on Feb 21, 2008
Ds frez "this product is not licenced or endorsed by nintendo"
The action replay might have a couple of loose wires, or was used too many times. Try getting it repaired professionally
Jun 12, 2009 | Nintendo Action Replay DS for DS and NDS...
Action Replay code manager wont read me action replay
Your replay needs re-setting....
  1. With your console powered off insert the Action Replay DS
  2. Hold down buttons A+B
  3. Turn your console on
  4. With A+B still held down, as soon as you see the Action Replay DS license screen press and hold down buttons START+SELECT so that you now have 4 buttons held down
  5. Hold all 4 buttons down for around 10 seconds until the Action Replay DS loads to it`s home screen
  6. If Action Replay DS doesn’t hold on the license screen for around 10 seconds when you do this, you may need to turn off and try again
You can tell if it needs re-setting by...;
* Code Manager PC software is reporting that Action Replay DS does not contain enough free space when it actually contains no codes.
* Code Manager PC software is reporting the console`s battery is low when it’s actually fully charged.
* Multicoloured bars are shown on the screen after you confirm the entry of a game ID when trying to manually enter codes. * You can use the Code Manager PC software without any problems until the Action Replay DS is connected via USB set to the update mode on the console, at which point Windows shows a run time error.
If you are experiencing any of these problems, please follow the steps below to reset the Action Replay DS hardware. Please beware that resetting the Action Replay DS hardware will not restore a default codelist, and any codes which are stored on the Action Replay DS will be erased.
Jun 08, 2009 | Nintendo DS Lite Console
I want cheats for Ridge racers5
I'm not sure if you're asking for cheat codes for use with Ridge Racer DS for the Nintendo DS, or Ridge Racer V for the Playstation 2 - Unfortunately, neither game has actual cheats built into them. You can, however, use a hex editor tool (also referred to as a Trainer, Gameshark, or Action Replay), which would allow you to cheat.
Intec Action Replay for the Nintendo DS: http://us.codejunkies.com/Products/NDS-Action-Replay---USA__EF000142.aspx
Action Replay codes for Ridge Racer DS for the Nintendo DS: http://us.codejunkies.com/search/codes/Ridge-Racer-DS_Nintendo-DS_17825879-17___.aspx
Intec Action Replay for the Playstation 2: http://us.codejunkies.com/Products/PS2-Action-Replay-MAX---USA__EF000306.aspx
Action Replay codes for Ridge Racer V for the Playstation 2: http://us.codejunkies.com/search/codes/Ridge-Racer-V_PlayStation2_1048770-1___.aspx
Mar 03, 2009 | Nintendo DS Console
Running Windows Vista 64x and my nds link driver won't install
If you bought the action replay, plug in the cord and a screen will pop up asking you if you want to search for NDS drivers. It will then say no drivers can be found but if you have the disc that came with your NDS to insert it into the computer. You put the small disc that came with the action replay into the cd rom and it will detect the driver. Then you can install the driver.
Jan 01, 2009 | Nintendo DS Lite Console
Nintendo DS Lite Console Logo
770 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
