Question about LG Refrigerators
How do I change the light bulb in the fridge as I can't find how to remove the panel. Model GWB227YUQA. Hope you can help. Thanks very much
3 Suggested Answers
Just_Bobz
  • 448 Answers
SOURCE: Light won't light in fridge, circuit is buzzing
Pull the switch at the front door. Take off the 2 wires and put them together. No light then, Live chat me. If this has proven help, please list as fixya
Posted on Jan 10, 2009
motor1258
  • 6674 Answers
SOURCE: 1996 Komfort trailer, model 9182
The electrode that ignites the burner,also senses flame to keep burner going. Sounds like it's defective. I'd replace it, but take old one with you to match it up.
Posted on Jun 11, 2011
Lightbulb not working in fridge freezer.How do I remove panel to get to bulb
Try pushing the sides of the plastic to remove it. Then you can access the bulb. Do not remove the bulb with your bare hand. Use a dry towel because if the bulb breaks in your hand, you have a problem. Unplug the fridge when you do this.
Feb 02, 2014 | Refrigerators
I need to change the interior light bulb in my Frigidaire over the counter microwave. The model # is FMV156DCA.
Good Morning Evelyn, thank you for allowing me to assist you!
Here are some simple troubleshooting tips to help replace the light bulb on your Frigidaire microwave, FMV156DCA.
    ·First, disconnect power to your microwave. This can be done by either unplugging it or at the circuit breaker panel.
    ·To release cover, remove the screw on the light cover (light cover may become very hot, do not touch glass when light is on).
    ·Remove old light bulb and replace only with equivalent watt bulb available from parts distributor or the manufacturer directly. Bulbs are also available at most hardware stores or lighting centers. Bulbs larger than 30 watts are NOT recommended.
    ·Close light cover and secure with screw removed in step 2.
    I hope this information proves to be helpful. If you have further questions, please do not hesitate to reconnect.
Nov 25, 2013 | Frigidaire FMV156DC Microwave Oven
On sub zero 690 like to change bulb in lighted electronic control panel
you will have to remove the light shield, remove the plastic trim that says the model number in front of the light shield, then the 2 screws holding the side cover on the left side of the fridge section. Then the cover will need to be pushed towards the rear of the fridge then tipped out at the front. It has springs holding it in the back.That should access the bulb you need to change
Nov 07, 2013 | Sub-Zero 690 Side by Side Refrigerator
How to replace fridge lite bub
Fridge light bulbs unscrew just like the ones in the back of your stove. Depending on make and model you may have to remove some light covers to access the bulb to unscrew it. Can you locate the model of the fridge and post it here so I can help you better with a percise answer?
Sep 23, 2012 | Refrigerators
REPLACE LIGHT IN FRIDGE
- Unplug the refrigerator from the electrical outlet.
- Locate the bulb on the inside of the refrigerator.
- Remove the light cover. Usually these just snap off, but, on some models, they may need to be unscrewed. Use your screwdriver to unscrew the light cover retaining screws (if required).
- Unscrew the old light bulb.
- Screw in the new light bulb.
- Replace the light cover. Plug the refrigerator back in. Test your new light bulb.
Hope this helps, please rate if the solution was helpful, thanks!
Oct 08, 2011 | Refrigerators
How do change the ref bulb on sharp ref model sj p43n - sl
Unplug the refrigerator. Remove the lamp cover by lifting up at the bottom of the cover. Then unscrew the old bulb and replace with an identical appliance bulb (Base E12, 240V, MAX 15W, T-20). This bulb is at the top center of the fridge.
The manual is available here: http://safemanuals.com/414159.php?ID=1286636&k=3942fa3f433aa4c53ff8bcb7d07ae8e8&q=SHARP%20SJ-P43N/P47N/43N/47N . You will need to review the fridge or enter a code to download the PDF. The light replacement instructions are on page 6.
I hope this helps.
Feb 25, 2011 | Refrigerators
Model JVM1790SK 01 Where/how do you change the
This is a pretty bad design, sometimes you can just remove the upper grill and access the light assy. If the panel is to tight to work in to change the light,you get to take the whole micowave down and remove the outer wrapper to change the light bulb. This is also not a standard bulb (part #WB25X10019). You may be able to get one from Lowes or Home Depot actually Sears would be a better bet, otherwise you will need to order one from an appliance parts outlet. Hope this helps and sorry I didn't design the thing I just fix them.
Jan 24, 2010 | GE Advantium 120 Convection/Microwave Oven
The light bulb needs replacing but..
It would have been really helpful if you could have provided the model number. You can always find it at the back of your freezer. Here are some links to videos which should be useful for you.
Jul 22, 2017 | Refrigerators
GE microwave interior light bulb replacement.
Your post has two distinct model numbers shown, so it's hard to be precise, but I'll try my best.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
I have a diagram at my site which helps you find & replace many GE cooktop and cavity light bulbs. Other models are similar. It's at
http://207.234.249.73/mwd/ge_lamp_replacement.jpg
Always unplug a microwave before removing or installing any bulbs!
If it's an over the range type, remove the vent grille across the top and see if bulbs can be accessed there.
There may be a panel on the bottom covering the light(s), too.
If not, chances are you'll have to remove it from the wall, then remove the outer cover.
Many models use halogen lamps. You must not touch the new one with your bare skin, as the oils will shorten the bulb life.
If yours is an Advantium type, the following instructable should help: http://www.instructables.com/id/SZFF4WSF44XYT8X/?comments=all
We're happy to help and we appreciate your thoughtful rating of our answer.
Jun 03, 2008 | GE JES1289SK Microwave Oven
Whirlpool gold refridgerator light not working and is making funny noise
I had the same problem. Model Number GS5SHAXNL00 Light wouldn't work on the fridge side and the led's wouldn't light up. Ended up being a blown circuit path on the control board.
All I did was soder a wire between the 2 points that path was connecting and *BINGO* the lights are back on!
Hope this helps someone. To find the burned out spot just look for a little black smudge on the white plastic case when you remove the board.
Feb 16, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Refrigerators Logo
81 people viewed this question
Top LG Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
christian nielsen
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
