Turns on then shuts off right away - Televison & Video
Hoover bagged wind tunnel 2 vacuum turns its self off after about 10 min. of normal vacuuming I can press the power button right away and the vacuum will turn back on and vacuum for sometime as long as 5...
There is a thermal sensor in the motor which shuts power off if it gets too hot but usually it won't turn back on until it cools down. It seems you might have a defective switch
Oct 06, 2013 | Hoover U6437-900 / U6439-900 Windtunnel...
Microwave turns on then shuts down right away
This an overload situation probably from a failed transformer or a fault in the control board or magnatron Have an appliance electrician check it out .
Aug 07, 2013 | Kenmore 62702 Microwave Oven
I turn on my polaroid t1035 and it automatically shuts down right away
Oct 08, 2010 | Polaroid i1035 Digital Camera
TURNS ON AND POWER TURNS OFF RIGHT AWAY.
Is the battery fully charged? If so unplug the device before turning it on. My roomates HP will shut off if plugged in while powered on it is most likely due to the compound on the heatsink.
Feb 13, 2010 | HP Compaq Presario V6000T Notebook
Runs good shuts down for no reason then starts right away cad happen at any time it is like some one shuts off but it will restart right away really annoying
my dad had this problem with his ram. it started having problems like yours, starting right back up. but after a few month of this, it woudn't start back up and the display read "no bus". it turned out to be a bad computer. he had to replace it.
Jun 29, 2009 | 1997 Dodge Dakota
1996 sony projection tv model kp46s17
does the tv realy shut off or does the pic go away sounds like bad tube
Nov 03, 2007 | Sony KP-61V75 61" Rear Projection...
Televison & Video Logo
24 people viewed this question
Top Televison & Video Experts
