Question about Dryers
MY MATAG #MDE9316AYW RUBBING SOUND NO START WHEN HOT
MY MATAG #MDE9316AYW WILL MAKE A RUBBING SOUND AND WHEN IT IS HOT IT WILL NOT RESTART,IT JUST BUZZES
  • 10,319 Answers
The drum of the dryer that holds the clothes has a seal surrounding the entire front of the drum. once dried out alot of build up is accumulated and will cause your problem. also the belt and tensioner should be looked at as well when opened up for inspection
Posted on Feb 06, 2010
WHEN I DRIVE MY KIA SPORTAGE IT MAKES A RUBING SOUND LIKE REAR BRAKE ?
Are you sure it's the brakes? If brakes are rubbing they'll get hot and the wheel lug bolts will too.
Put on old clothes, drive the car down the freeway on a Saturday or Sunday morning, when there's no traffic, being careful to not touch the brake pedal (except as needed). When you've heard the rubbing noise for fifteen minutes or so, pull way over somewhere safe & park. Turn the engine off & apply the parking brake. Go to each wheel and touch the lug nuts and/or the brake drums or discs the wheels are attached to. If a brake's dragging the disc or drum will be scalding hot. If the brakes are not hot, the rubbing sound isn't brakes.
Nov 25, 2014 | 2007 Kia Sportage 4x4 V6
Mde9316ayw
sounds like u got a bad motor. try holding the lid or door switch in while u press the start button. if u give the tub a little help and it starts going then it is the motor.
Jul 25, 2013 | Dryers
When the dryer gets hot, the tumbler begins to make a continous squeaking noise as if there is metal to metal; not a grinding noise. If you allow it to cool down and restart, it doesn't start until it...
Well ya never mention in your question what brand you have but a GE or Hotpoint dryer has a small plastic insert that wears thin over time. It begins to do a squeak squeak squeak type of noise.And that noise is intermittent, on a Frigidaire model the noise would start out low and gradually get worse. The bearing sometimes gets so bad it gets chopped off and the tub falls into the heating element.
Jun 30, 2011 | Dryers
MATAG DRYER, MAKES A VERY LARGE HIGH PITCH SQUEEL
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
http://www.fixya.com/support/r4416566-dryer_repair_squeaks_grinding_clicking
heatman101
Asker's Testimonial " This should give me an ida of what to look for once I open er up " -
Apr 15, 2010 | Maytag Dryers
I need info for changing the power cord from a 3-wire cord to a 4-wire cord. I have a Maytag Dryer Model MDE9316AYW and I am not sure wher to connect the wires. It looks like they connect (from left to...
The correct way is actually as such...Green (ground) to the frame/chassis. Red, white, then black. See the image I attached for a reference.
Hope that help`s. Good luck.
macmarkus :)
Mar 06, 2010 | Dryers
Matag alantis no cold water
check to see if you have power to the fill valve when the cold water should be going in;(reverse the connectors on the fill valve) i.e. hot now will not go in... replace the fill valve: (buy it at an appliance parts store) (inexpensive) it's an easy replacement job
Jun 12, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Starting dryer
you need to replace the motor
Dec 17, 2007 | Dryers
Starting dryer
the motor needs to be replaced. the bearing are going bad and they are only sold as the whole motor
Nov 28, 2007 | Dryers
Dryers Logo
147 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
