Question about LG DP781 Portable DVD Player
LG DP781 DVD player plays audio on the TV, but no video when connected to tv. The DVD player screen shows the video & audio just fine, but wondering why no video on the TV.
Souds like a cable problem. First, make sure that the cable you are using is the right cable-it should be a multi-signal cable. Look for a colored circle of insulation on the metal end that separates the tip of the connector from the bottom of it. You might even have more than two sections if it is a stereo jack. If you are sure you have the right jack/cable, then it's possible the wire carrying the video signal could be damaged. If it's not a cable issue, it's a jack issue, so look for damage on the device's output jack.
Posted on Apr 02, 2010
No Video Error on TV Screen
Select SOURCE on tv to dvd or component or dvi or auxilary etc
Aug 24, 2014 | Sony DVP-SR210P Progressive Scan DVD...
No picture
have you connected up correctly, have you selected correct EXTERNAL inputs, you do NOT "tune" a Channel to see picture, you choose external AV input on set. Must connect color to color. 3 for Composite Video AV.Yellow, Video, Red & White Audio. and 5 cables for Component 3 for Video , & 2 for Audio Blue, Green, Red, Also Red & White, Audio.
AV
Mar 18, 2010 | Panasonic DMR-ES10 DVD Recorder
How do you get DVD picture to show up? Power is
You DO NOT use "Channels" to View a DVD player it usually connected to the AV External input. via AV, Yellow, (Video) Red & White, (Audio) or Component Video, Blue, Red & Green. (Video) + Red & White (Audio). These are selected via the External Inputs.
Feb 18, 2010 | Zenith ZDA311 DVD Player
LG DP781 Player won't start up past the spinning disc screen
it sound like a miss connection maybe should check out the flex between the screen and main board
Jan 28, 2018 | LG DP781 Portable DVD Player
DVD plays audio but no video? The LG screens comes on but the screen goes dark and only the audio plays. I ran the disc cleaner.
NO NEED TO CLEAN LENS, YOU HAVE A MOTOR PROBLEM, IN THIS CASE YOU WILL BE ONLY ABLE TO PLAY AUDIO DISK AND NOT DVD. BECAUSE OF FREQUENTLY USED, DVD DISK MORE SPEED ROTATION THEN NORMAL CD, SO CHANGE YOUR MOTOR AND CHECK IT WILL WORK......
Oct 14, 2009 | LG DP781 Portable DVD Player
Using remote to play video DVD
You need to bypass your A/V tuner for your video connections (if possible). Plug your video directly into the TV and audio into the tuner. This will also give you a cleaner signal/picture as it does not have to processed by your tuner BEFORE it goes to your tv. Think of it as cutting out the middle man. Your tuner is best left for powering your speaker and not controlling your video despite all of the available connections in the back of it.
I would also get rid of your VHS and cassette players as they are dead technology. Clean up your system and remove the clutter. This will lessen your chance of getting interference. Good luck!!
Oct 01, 2008 | Toshiba 32D46 32" TV
Stops Playing: screen freezes
My friend suggested I clean the dvd optical reader lens inside the player with a fine brush (like a camera brush with a blower bulb). This seemed to help immensely. I'm not certain if this is just a temporary fix, but it seems to be ok so far.
Jun 06, 2008 | LG DP781 Portable DVD Player
LG DP781 Portable DVD Player Logo
128 people viewed this question
Computer Repairing
Computer Repairing
