Connect VCR without tuner to record from television
I have a DVD Recorder/VCR Recorder combo, but it does not have coaxial connection TV tuner. Is there any way or anything I can buy to hook this up to cable TV to record from television
  • Televison & ... Master
  • 5,056 Answers
If it has a scart, you can get a scart lead to connect it to your TV. You would need to set the VCR to the Scart socket, IE: AV1 etc.. to record. You wouldn't be able to change channel on the TV, to watch another channel while recording though. If you had a set-top box, you could connect that up to the scart of the video then record, while you watched another channel on your TV.
Posted on Feb 06, 2010
I have a Magnavox ZV427MG9 DVD Recorder VCR Combo. Do I need a separate tuner? If so what kind? Thanks
Hello
Ofcourse you need an external tuner to receive any RF signals. Your Magnavox is not equipped with internal tuner with it. OK.
Apr 21, 2011 | Magnavox ZV427MG9 DVD Recorder VCR
My jvc dvd /vcr combo will not record. I have the cable from my wall to the input in and the inout out coaxial goes into my tv. however it does not record anything
From the explanation, it looks like you are trying to record TV channel, correct? Some of these DVD VCR combos may not have built-in tuner. Do you have the instruction book? If not, you can download from jvc.com website. If you find it difficult, tell me the model number.
Nov 14, 2009 | JVC DR-MV7 DVD Recorder/VCR
Hi just got a LG dvd/vcr Model RC897T. I have it hocked up right, but i can't get it to switch over so that it would be seen on the TV. can you help
If a cable box is not required for cable signal reception, connect the cable line to the ANT. IN connector on the recorder.
If a cable box is required for cable signal reception, connect the cable line to the IN connector of the cable box. Connect a coaxial cable from the OUT connector of the cable box to the ANT. IN connector of the recorder.
To view or record a CATV channel:
  1. Tune the TV to the Recorder output channel (CH 3 or 4).
  2. Set the Recorder channel selector to the cable output channel. (Example: CH3).
  3. Select a channel using the cable converter.
With this connection, you cannot record one program while viewing another.If you are using a cable box to tune channels, it is not necessary to do Auto Channel Set.
Oct 20, 2009 | LG RC897T DVD Recorder/VCR Combo
Must hookup DVD-VR375to tv,cablevision box & MSNtv2.
Here's How:
  1. The first step to connecting a DVD Recorder to your TV is to determine what type of connection you want to make between the TV source (Cable, Satellite, Antenna), the DVD Recorder and the TV. This is usually determined by the outputs and inputs available on the DVD Recorder and the TV.
  2. If you have an older TV that only accepts RF (Coaxial) input, then you would connect the RF output (a coaxial cable) from your TV source (in my case a Cable Box) to the RF input on the DVD Recorder. Then connect the RF output from the DVD Recorder to the RF input on the TV. This is the most basic (and lowest quality) option for connecting a DVD Recorder to any TV.
  3. If you want to use higher quality cables, then you may want to connect the TV Source (Cable and Satellite only, not Antenna) to the DVD Recorder using Composite, S-Video or Component video and audio cables.
  4. To use composite cables (also known as RCA, the yellow plug is video, the red and white plugs, audio): Plug in the composite cables to the RCA outputs on the back of your TV source and then plug in the composite cables to the RCA inputs of the DVD Recorder. Then connect the RCA outputs from the DVD Recorder to RCA inputs on the TV.
  5. To use S-Video and RCA audio cables: Plug in the S-Video cable to the S-Video output of the TV source. Plug in the S-Video cable to the S-Video input on the DVD Recorder. Next, connect the RCA audio cable to the output on the TV source and the input on the DVD Recorder. Finally, connect the S-Video cable and the RCA audio cable to the output on the DVD Recorder and the input on the TV.
  6. To use Component Video cables and RCA audio cables: Connect the Component Video cable and the red and white RCA audio cables to the outputs on the TV source and the inputs on the DVD Recorder. Next, connect the Component Video cable and RCA audio cable to the outputs on the DVD Recorder and the inputs on the TV.
  7. Now that the TV source (either Cable, Satellite or Antenna), the DVD Recorder and the TV are all connected, you need to configure everything to make sure that TV is coming through the DVD Recorder, for recording and viewing.
  8. Turn on the Cable Box or Satellite Receiver, TV and DVD Recorder.
  9. If you connected everything using the RF connections then the TV should be passing through the DVD Recorder and displaying Television on the TV screen. To record in this mode, you would need to tune to either channel 3 or 4 on the TV and then use the DVD Recorder TV Tuner to change channels and record.
  10. If you made connections using either Composite, S-Video or Component cables, then to view or record TV, two adjustments need to be made. First, the DVD Recorder needs to be tuned to the appropriate input, typically L1 or L3 for rear inputs and L2 for front inputs. Second, the TV also must be tuned to the proper input, on a TV usually Video 1 or Video 2.
  11. If you have a Dolby Digital 5.1 Surround Sound A/V Receiver you can connect either a Digital Optical Audio cable or Coaxial Digital Audio cable from the DVD Recorder to the receiver to listen to audio through the receiver.
Jan 20, 2009 | Air Tools & Compressors
Tuner free
Magnavox (philips) is one of the cheapiest dvd/vcr combos that offer excellent quality on the market. If you have a cable box or Directv box, simply use the audio/video connections on the back and connect them in the combo, then you can record from the television programs whenever you want.
Nov 19, 2008 | Philips Magnavox DVD/VCR Dual Player
Need directions to install a dch70 box to tv
dear woolifer ,
I am not an expert but i hope i can help you..
is it youmean digital cablebox?
if it is try this-
This is a problem a lot of people have with coaxial-only televisions because DVD players do not have coaxial (RF) outputs, which means they can't be connected directly into a television with only a coaxial (RF) input. The solution is to purchase a RF modulator, which is a small device that will convert the AV output from the DVD player to coaxial (RF).
As for the instructions, I am going to assume the DVD player is not a combo unit with the VCR, and that you want to record TV on your VCR. Step 4 will include connecting your DVD player, but if the DVD player is a combo unit with the VCR, just ignore step 4 part as DVD connection will be included in the VCR set up. Actually, you wouldn't need the RF modulator if it is a VCD/DVD combo unit.
  1. Connect the coaxial cable coming out from the wall to your digital cable box in the ‘video in’ slot. It might also be labeled ‘antenna in’ or ‘cable in’.
  2. From the cable box, connect a coaxial or composite (yellow video cable) and stereo (red-white) RCA audio cables to the VIDEO IN terminal on your VCR.
  3. From the VCR, you will have to connect this to the RF Modulator using a coaxial cable from the VIDEO OUT on the VCR to one of the IN ports on your RF modulator.
  4. You can now connect your DVD player to the RF Modulator by using the yellow-red-white composite/RCA cables from the VIDEO OUT on the DVD player to another port on the RF modulator.
  5. From the RF modulator, connect this unit to your TV by using a coaxial cable. It will be from the VIDEO OUT on the RF modulator to the VIDEO IN or CABLE or ANTENNA IN port on your television.
This should be all you need to get started watching your digital television. In simple terms here is what you did:
Coaxial from wall to cable box
Cable box to VCR
VCR to RF modulator
DVD player to RF Modulator
RF modulator to TV
You will only be able to record what is on channel
Apr 09, 2008 | Computers & Internet
Unable to record one tv channel while watching another tv channel
You CAN record one channel and watch another with satellite service, but it would require two separate DBS receivers. The issue is that all satellite broadcasting is encrypted until it hits the receiver, which decodes it and transmits it outward toward your other AV devices. If it weren't for the receiver, connecting the coax cable to your other devices and trying to tune channels with them would yield no signal and possibly much frustration. You would need to split the signal into each receiver and have one connected to the television via one input and the other to the recorder then to the TV via another input.
With cable, you can split the signal without having to have two boxes - this way the QAM tuner in the cable box is still capable of tuning channels while the recorder can tuner basic cable channels for recording separately. You can also have the cable box connected to the recorder via composite so that you can record premium stations on a DVD recorder input mode anytime you like - but you would have to be watching that channel at the same time unless the DVD recorder had a pass-through RF signal (rather than a composite clone) - meaning you could also use coaxial to your television from the recorder and tune channels separately on your television while the recorder is recording one channel.
A lot of what-ifs there, but it is all quite possible.
Mar 18, 2008 | Panasonic DMR-EZ47V DVD Recorder/VCR
Set up problems
is this a dvd/vcr recorder combo? or is it just a dvd player? if it is only a dvd player, there wouldn't be a rf input. you won't be able to record or burn recordings.just hook up the audio/video cables to your tv to watch dvd's. if it is a recorder combo without a rf input or output, you may need a rf modulater they sell at radio shack for about $25.
good luck.
wg
Feb 11, 2008 | Televison & Video
Connecting VCR/DVD combo to TV
If that is the only input that the tv has it's still usable. Just plug the Cable TV or antenna cable into the DVD/VCR coaxial input labeled "in" (instead of the TV's) and hook one from the DVD/VCR's "out" to the "in" on the tv. Turn the TV to channel 3 or 4 (depends on DVD/VCR settings) and use the built in TV tuner on the DVD/VCR to change channels.
Sep 20, 2007 | Televison & Video
Televison & Video Logo
162 people viewed this question
Top Televison & Video Experts
Electro Med Services...
