Question about PC Chips M825G Motherboard
Problem is no sound on M825g motherboard (on-board sound or added sound card). In both cases Windows says device working, no irq conflicts, etc. Seems answer may be re-flash bios. My board says version 9.2c I only see bios download for V9.2a. Will it work on V 9.2c?
5 Suggested Answers
  • 68 Answers
SOURCE: problems with m825g
STOP!! Don't do it!
The M825G uses the KM266 Pro and , if the BIOS is correct, auto detect the CPU and its speed. That BIOS has a built-in OC utility, and that is why the jumpers are disabled.
The odds are you have an incompatible core. Just because the CPU fits the socket, doesn't mean it can work with the MB/chipset.
Check this link for that MB just to make sure.
http://www.cpu-upgrade.com/mb-PC_CHIPS/M825G(v9.2a).html
Posted on Jun 09, 2008
SOURCE: Audio Devices
on borad one proably no good i would get new x fi sound card use latest driver from web site those onbord ones dont last buddie thats nothing u can do erther come sup or it dont in device manger
Posted on Jun 16, 2008
  • 14 Answers
SOURCE: Help me
www.pcchips.com
Posted on May 14, 2009
  • 617 Answers
SOURCE: PCChips m825g motherboard. No on-board sound or
no 9.2c is newer then yours. So your sound card isn't working, do you know name and model of sound card to make sure have right drivers installed for it?
Posted on Feb 07, 2010
Communication port is not working properly
COM1 and COM2 refer to a computer's communications, or serial, ports. COM1 ports are often used on older PCs to connect network devices, digital cameras and mice. Faulty drivers software that enables the hardware to communicate with the operating system or incorrect hardware configuration can influence COM1 behavior. In rare cases, the expansion card that adds the serial ports to the PC can fail, rendering both COM1 and COM2 ports useless. To repair a COM1 port, you must determine what is preventing the port from working before attempting a solution.
Click "Start." Go to "Control Panel" and then click "Hardware & Sound." Select "Device Manager" from the submenu. Expand "Ports (COM & LPT)." Double-click "COM1." Review Device Status on the General tab to check for problems with the software driver. If the message "The Device Is Working Properly" appears, click "OK" to close the window; otherwise, look up the error message on Microsoft Support. Follow the directions in the Knowledge Base to correct the issue. Press "Alt" and "V" to open View. Scroll to "Resources by Type." Press "Enter." Double-click "Interrupt Request (IRQ)" to see a list of devices. Double-click "Communications Port (COM1)." Check the term to the left of COM1 to see if the card uses an ISA or PCI interface. If the card uses a PCI interface, it can use the same IRQ as another PCI device without producing a hardware conflict. If the device is ISA, it needs its own IRQ. Go to the "Resources" tab. If "No Conflicts" appears in the Conflicting Device List, close the window; otherwise, uncheck "Use Automatic Settings." Click the drop-down menu and select each configuration until the port no longer interferes with another device. If conflicts occur with each configuration, double-click "IRQ"; you may need to try different configurations before Windows gives you permission to edit the interrupt request. Click the up or down arrow to change the IRQ until the message "No Devices Are Conflicting" appears in the Conflict Information field. Click "OK" to close each window. Click "Yes" when prompted. Connect a device to the COM1 port to test the port. If the device doesn't respond, shut down the computer and then unplug the power cable. Disconnect all devices from the back of the PC. Remove the case cover and touch the computer's chassis. Set the computer on its side so that the PCI and ISA cards sit at a 90-degree angle to the floor. Find the serial ports on the back of the PC. Look on the opposite side of the case to find the associated card. Shine a flashlight onto the card and make sure that the copper contacts are not visible. If you can see the contacts, reseat the card in its slot so that it's fully installed to the motherboard. Reassemble the case and boot into Windows to test the COM1 port. If the port still fails to work, you may need to replace the serial port card.
Jan 16, 2013 | Computers & Internet
I installed the magic jack since this time no other sound device is working except skypke and the magic jac
What it sounds like is a very rare (these days) occurance of an IRQ conflict. This is called an Interupt Request. An interrupt request is a service in the operating system which dedicates resources to devices. Obviously, Magic Jack has swiped an IRQ for itself (which is probably in conflict with your sound device). This kind of thing was very common in Windows 98, but XP and above pretty much fixed IRQ conflicts...however, they can occur if a device is a real resource hog.
There is a fix for this problem.
First of all, if you have XP, go into Accessories, System Tools, System Information.Click on the Hardware Resources. Then, Click on IRQ. Note the IRQ being used my Magic Jack and the IRQ being used by the sound device. Write down the IRQ number for each. I am betting both devices are on the same IRQ. Note, in XP, you will have IRQ 0 thru 23. Do NOT disturb IRQ's 0 thru 10! Leave these alone. Now, take note and see if there is an IRQ that is SKIPPED. Or there is an IRQ that is FREE (not being used). Write this down.
Now what you want to do, is you want to re-assign your sound device to a different IRQ. In order to do this, see this article:
http://www.helpwithpcs.com/upgrading/cha...
After resetting the IRQ's involved, reboot the computer for the changes to take effect. If the IRQ's you set do not result in a conflict resolution, try a different IRQ. It may take a couple of two or three times, before the operating system accepts your choices.
Jun 07, 2011 | Computers & Internet
PCChips m825g motherboard. No on-board sound or with sound card. In both cases Windows (win98se) says ''device working, no irq conflicts etc etc''. The answer seems to be to re-flash bios. I only see a...
Feb 06, 2010 | Computers & Internet
System unable to boot and showing signs of motherboard audio device conflicts(device type realtek)
hi iasmeer,
-to just boot up without any sound device,
remove any soundcards from the PCI- slots, disable the onboard sound device in the BIOS!
It looks like you are facing IRQ conflicts, your computer cannot handle all the hardware devices installed.
to solve this,
in BIOS set IRQ management so that the BIOS handles the PCI devices(set everything to auto),
disable the plug'n'play-operation system option to prevent windows from doing the same thing again( it'll then just take the IRQ information provided by the BIOS)
now enable the onboard sound device and make sure you have all
the drivers for the onboard devices(sound, LAN-card etc.) fitting your operation system on CD or thumb-drive, boot up and install the drivers.
Restart and by chance everthing isO.K. by now.
if not, please come back with more information on the sound device(onboard or not) and the winversion, so we perhaps can find you the appropriate driver(if you don't have it on the CD you purchased together with the mainboard..?)
Good luck
Sep 07, 2009 | ASUS P5GC-MX FSB1066 Motherboard
Video Capture card interrupt conflict
Under the properties for that device in device manager, you can override the default settings for the device. Change the IRQ setting for the device until you find a setting that is not conflicting with anything else.
Aug 27, 2009 | Intel Motherboard
Dell laptop 8200 usb failed to work
go to dell web site and download the chipset update.
chance are the connection on the motherboard is bad or the chipset software is out of date.
if the software for the chipset can't fix the problem. the next alternative is to replace the mother board.
Mar 18, 2009 | Dell Inspiron 8200 ATI 64MB Video Card -...
Irq dma err
IRQ's (Interrupt Request) LinesIRQ's are hotlines to the main computer (CPU) that allow devices connected to the computer to signal the CPU that they need immediate attention. If you're a Batman fan, think of IRQ's as the Batphone - getting his attention immediately.
Not all devices require IRQ lines, which is good news because in modern (post IBM XT) computers, we only have 16 of them. Of those, 3 are already dedicated to the main system board itself - the system timer, keyboard, and memory parity error signal. That leaves only 13 for all the other devices connected to your computer. This is why IRQ conflicts are probably the #1 problem faced by computer users when they add hardware to their computer.
Its a general rule for ISA-type systems (the standard computer architecture used in most IBM compatible systems) that IRQ lines CANNOT by shared with multiple devices except under special circumstances. For this reason, a good understanding of what IRQ's are assigned to what devices is essential in avoiding conflicts. The table below is a general outline for standard IRQ assignments.IRQ DEVICE USED in AT, 386, 486, and Pentium Computers
0 System Timer
1 Keyboard Controller
2 Tied to IRQs 8-15
3 COM 2
4 COM 1
5 LPT2 or Sound Card
6 Floppy Diskette Controller
7 LPT 1
8 Real Time Clock
9 Substitutes for IRQ 2
10 Not Assigned
11 Not Assigned
12 PS/2 Mouse Port
13 NPU (Numerical Processing Unit)
14 Primary Hard Disk Controller
15 Secondary Hard Disk Controller
Depending on the computer's configuration, add-in devices such as SCSI controllers, sound cards, modems, cd-roms, etc. will want an IRQ line that is already used by another device, and thus we have what is commonly referred to as an IRQ Conflict.
The most common IRQ conflicts seem to be between two COM ports, generally a mouse and modem conflict that ends up freezing the mouse whenever the modem is activated. The table below explains each IRQ and the most common devices each may use.
Oct 18, 2008 | Computers & Internet
Lan card
Use a different PCI slot and reinstall the drivers for your LAN card. If this does not fix the problem there may be a compatibility issue between the network card and some other software (eg. irq conflict etc.), or the LAn card may be slightly faulty and have problems on some motherboard.
In this case you can try troubleshooting the problem.
If you cannot find out the problem at a glance, checking in device properties, you may be forced to reinstall Windows. In this case I suggest to just replace the part. The Ethernet (LAN) pci card is quite an inexpensive part, and you can still use this one on a different computer.
Regards
Apr 02, 2008 | Gigabyte Slot 1 GA-6BXC Motherboard
PCI Device Conflict
u can try to change in BIOS, the settings that manages PCI IRQ's. If it is on manual then put it on auto mode. If on auto mode than manualy change the allocations of irq for the pci slot no. 5 ....
Jan 20, 2008 | EPoX EP-9NPA7I (0819366003415) Motherboard
PCI GA-8ID533 V1.1
there is no PCI lock on any retail boards. But there are IRQ sharings and conflicts. Set IRQ to auto, if not, then manualy and if so, then disable a few things, just to free up some IRQs. All depends on the board, best is to consult the manual for the IRQ sharing table and work with that. (disable one SERIAL, IDE port or USB port if you need an extra IRQ) Also check for onboard equivalent to the card you are adding, disable the onboard part...
Dec 27, 2006 | Gigabyte GA-8ID533 Motherboard
PC Chips M825G Motherboard Logo
141 people viewed this question
Top PC Chips Computers & Internet Experts
David
David
Steven Burn
Steven Burn
Jerry Umali
Are you a PC Chips Computer and Internet Expert? Answer questions, earn points and help others
