I have a kingston dt101 and use windows XP. When I put the device into the usb port and check properties of the device, it says that the disc space is full. This is a brand new 8gb unit and it shows no free space available. Can someone tell me what drivers I might need to install into my computer so my computer recognizes this flash drive. thanks Dave
Here is the website that i think has the drivers http://www.fileguru.com/apps/kingston_dt101_driver
Posted on Feb 06, 2010
16gb pendrive
try to format it using this program http://www.softpedia.com/get/System/Hard-Disk-Utils/HP-USB-Disk-Storage-Format-Tool.shtml
May 22, 2013 | Kingston 16GB 16G 16 GB DataTraveler...
Please insert disk into removable disk
have you tried other a different flash drive of something like a usb charger etc? If it works then then the problem is with the flash drive, if not them its with your USB port
Apr 28, 2013 | Kingston 16GB 16G 16 GB DataTraveler...
Kingston DT101 32GB Not showing/detecting the device in system windows7?
click start right click on computer select properties then on device manager scroll to universal serial bus controllers you might see a yellow question exclamation mark ? ! or a red X
this will mean the driver needs to be updated
right click to update driver
if your computer came with a motherboard disk the drivers could be on it
hope it helps
Mar 03, 2012 | Kingston Computers & Internet
DataTraveler 101 (DT101) 8gb write protection cant read or write on it what can i do
You will have to be the computer administrator to change any values on any hard drive
click start control panel user accounts you should see a box with the administrator and the guest account if you have made one click on the administrator this may vary depending on which operating system you have
click start click to open on my computer you should see your hard drive usually C: right click select properties there will be an array of options select the security tab option then advanced make sure you have full control in windows 7
click start control panel user accounts click on the administrators account if you have made one or you will have to create one in windows XP
USB drives can be write-protected by modifying the StoreageDevicePolicies Registry key and WriteProtect Registry value.
click Start>run>regedit to open Registry Editor. and press control+F to open the find dialogue box and type "usb device" or "driverdesc" to open usb mass storage device or type "usb mass storage device" in the search windows. And right click on it and delete. This will set the policy value to 0. then insert your usb device. It will work fine.
# Remember: do not delete any unknow files in the registry as this will make some programes not work as usual.
also
If you are running a Windows XP OS then you might be able to:
- click start right click on my computer select open
- Right click the icon of your Flash Drive (It should be F:/ or something)
- Click Properties in the menu that comes up
- Click the Sharing tab
- Click permissions
- And finally, click Allow next to Full Control.
hope this helps
Aug 06, 2011 | Kingston (DX100-SWC)
Kingston Data Traveller DT101 16 GB. Plug it in, no LED flicker as it usually had. PC assigns a drive letter as removable disk. Clicking drive letter results in "please insert disk". Second Data...
click start control panel administrive tools computer management device manager scroll down universal serial bus controllers you should see a yellow question mark?
right click to reinstall drivers
if you can see your usb drive but its not working
ports(com&lpt)right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts also
scroll to disk drives if you can see your drive + to expand right click you should see options update driver disable uninstall scan for hardware changes
select properties you should see options in the general tab to troubleshoot policies volumes driver and details under the driver tab you will have the options to check the driver details update driver rollback driver or uninstall
hope this helps
Apr 11, 2011 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
My problem: I have Kingston DT101 G2 64 GB. When I put it in USBhub Windows explorer notice "Isert Disc". Formatting from MMC doesn`t work. Please, give me advice what software can help to solve...
hope this helps
Apr 06, 2011 | Computers & Internet
System is not detecting
To determine if your system is detecting the USB drive or not
Windows XP Right click "My Computer" >> Properties >> Hardware Tab >> Device Manager
Windows Vista/7 Right click "Computer" >> Properties >> Device Manager
If your USB drive is not detected at all either the drive is bad or the usb port is bad, I would try another USB port to rule out the issue being a port
If you see a ? or ! then your operating system had trouble installing a driver for it uninstalling and reinstalling the driver should resolve the issue
Please comment if you need further assistance or clarification
Thanks
If
Nov 21, 2009 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Formatting (FAT) 2g drive left drive with only 735Mb. How do I format for the full 2g? Thanks
what device did you use to format your flash drive? is it a camera or PC?
now try to insert your flash drive in a usb port of a PC running windows vista since it has a better disk management tools. now format it from there using FAT32 file system to regain your disk space. you can also try windows xp
Oct 14, 2009 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Kingston USB 2g DT101
Hi
Are you trying to format it in ntfs version or fat 32.
Check the allocation unit.
Make it default dont put any value.
Try this and tell me if it helps.
Regards
Faraz
Oct 15, 2008 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Computers & Internet Logo
185 people viewed this question
David Payne
David Payne
