Question about Dishwashers
The top does not wash and the bottom some what works. no water pressure
  • 1,531 Answers
First thing to check is your in coming water pressure and temp.The internal water temp has to be at least 120 degrees to properly clean the dishes.
Second after the machine has stopped filling with water open the door and look at the water level in side you should have 1/2" to 1" of water and it should be hot.
Third if there is not that much water add a few cup fulls off water unit the whole bottom of dishwasher is covered in water. Then start your machine and let it go through a cycle.
If your unit cleans the dishes then you may need to replace the water fill valve,if it does not clean the dishes and the results are the same you need to replace your main wash motor.Remember water temp has to be 120 degrees.
I hope this helps with your dishwasher and you get it fixed fast.
Posted on Feb 06, 2010
My Samsung 7.5kg top load washing machine is over filling..is there a sensor or something to correct this
yes
it is connected to the bottom of the tub by a small hose
it sits up top and as the tub fills , air pressure acts against a preset spring tension and switches the water solenoids off at the same time it starts the wash
the problem is probably the water inlet solenoid / valve that is not working or the diaphragm is split
to test , change over the cold and hot water hoses at the taps and press the hot water button
if the flow stops at the required setting it is the cold water valve unit
Apr 06, 2017 | Samsung Washing Machines
Water intake does not stop
there is a pressure sensitive control that is activated by a small tube running from the bottom of the tub up to the top of the machine
as the water in the tub rises ,air that is trapped exerts pressure on a diaphragm in the sensor
the pressure is set by your selection of the wash load /level
when that pressure is reached the sensor pressure is overcome and the switch is activated . as a result the inlet water solenoid is shut off and the wash program starts
now knowing how it works , check for the small hose is not full of water when the tub is empty, the hose is intact and not cracked or broken and the pressure switch is operational ( disconnecting the hose at the tub and blowing air into it ( like blowing up a balloon) will activate the switch
if that is working ,the next point ti check is the solenoid that switches of the tap water with the machine on as if you are doing a wash the water will start to flow . blow into the tube and the switch should shut off the water flowing into the tub and start the wash cycle
if the machine starts to wash but the water still flows then it is the solenoid that is faulty
fix is a replacement unit
Sep 24, 2015 | Samsung Washing Machines
Dishes on top drawer not washing fully,appears hi pressure going to bottom rotar and not top. is there a somthing that sends pressure to different cleaning heads during wash cycle
There is a connector under the top draw from the rotor top the pressure at the back of the inside. This connect at the bottom where the main pump directs the water upward and into the bottom of the rotor. Also, check that rotor is freely moving and nothing is blocking it.
Aug 15, 2011 | Bosch Dishwashers
Hardly any water is coming into the machine on start of wash
hello, make sure the water pressure is not low and theres no kinks in the pipe also check the water inlet valves see if there they are blocked do this with the power off also the check the pressure switch this usually located at the top of the machine. it's idenified as large circular switch that has several wires and a plastic tube this plastic tube.this sits at the bottom of the washer hope it helps ps if it's still not working get back to me
regards
shaun
Jan 02, 2011 | Washing Machines
Top wash arm does NOT spin, but is not blocked or hard to move by hand. Does this run off water pressure? Whatshould Itry next. I have already removed the filters and cleraned around the pump. The bottom...
Remove the dishwasher from the cabinet and look at the hose going up to the top. Make sure it isn't clogged and that there is nothing in the port where it comes out of the pump. The top arm is powered by water pressure from the pump.
Jun 14, 2010 | Frigidaire 24 in. FDB750RCC Stainless...
Dirt left on dishes on top tray; bottom tray washes fine
The broken bottom arm is probably preventing any water / water under pressure to get to the upper arm.
After you replace the lower arm, you should have much better cleaning in the top shelf.
While you are in there replacing the lower arm, recommend you remove the filter under it and clean the filter and any debris you find. Be careful of broken glass!
Good Luck!
Apr 03, 2009 | Dishwashers
Not much water pressure
At this point, your motor that drives the wash pump is beginning to fail. Replacing it will fix your problem with it having water pressure and cleaning properly.
As you replace the motor, the impeller should be provided as well.
Good Luck!
Mar 14, 2009 | Whirlpool 24 in. DU1055XTP Built-in...
Top arm not spinning
only the top rack isnt getting clean?
there is a little plastic circle in the middle of the bottom of the upper spray arm. turn it counter clock wise to pull the upper spray arm from the upper rack. make sure that isnt clogged and the spray holes are not clogged. otherwise....
the piece that the bottem spray arm plugs into and runs along the back wall of the tank to the top is called a feed tube. pull the bottom spray arm out. now you can see the part of the feed tube that feeds the upper spray arm water. does it pop out freely and easily? if so then you need a new feed tube, if not then its most likely your not achieving the right water level or your impeller connected to your circulation pump(motor) is clogged not supplying enough water pressure to travel up the feed tube to spin the upper spray arm.
Jul 13, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Overflowing water
If the water comes out when filling, check your water valve by unplugging the washer when it is filling. If the water still runs, replace the valve. If the water stops, check the small tube that goes from the water pressure switch (in the consul) to the bottom of the tub. This must be connected without any holes or obstructions. If this is ok, replace the water pressure switch.
Jan 03, 2008 | GE WBSE3120B Top Load Washer
Water fill problem
The pressure switch is close next to the timer switch. There is a thin tube going to the bottom into the outlet pump. Check to see if this tube is free from any blockage, by disconnecting from top and blowing into it. The tube shd be free, and your water will cease to overflow. Refix tube carefully.
Jun 11, 2007 | GE WDSR2080D Top Load Washer
Dishwashers Logo
53 people viewed this question
Top Dishwashers Experts
Owen Barnes
