Question about Bosch Dishwashers
Dishwasher not draining E25 error code (Bosch exxcel) . I have cleaned filters & removed pump inspection cover to check / clean debris I have also checked the waste water pipe is not kinked, it runs for 1hr 15 mins last time and then cut out with the error code displayed.
  • Gurjit Heer Lalli
    Gurjit Heer Lalli Jun 19, 2017
    I am having this problem now. Checked pipes and filters etc. runs for about an hour and displays error code.
Gr8 stuff klaudi & Nypmh - rocking it back 45% worked a treat.
Bloody Bonza
Shell XX
Posted on Dec 03, 2012
  • Trip
    Trip Mar 09, 2014
    Thanks again guys - just helped me out too... same problem, same fix! One less thing to worry about :o)
5 Suggested Answers
  • 117 Answers
SOURCE: water is not going into the machine - and yes the water is on
There is a heating element in the dishwasher that heats the water to about 155F at which point a thermostat closes and sends power to the timer to advance. If the water does not reach this temp, the dishwasher will not advance. Often the problem lies in a faulty part in the heating circuit like the heating element or the thermostat but you will need a technician to verify.
http://tclaundryrepair.com/
Posted on Feb 20, 2009
SOURCE: Just installed bosch exxcel and light on saying
noavatar_s.gif Nzimpofu
Rank: Apprentice
Rating: 100%, 1 votes
Have been struggling with the same problem. Tipping the machine backwards worked. Many thanks.
Was this helpful? Yes No2 people thought this was helpful
noavatar_s.gif klaudiatombo
Rank: Apprentice
Rating: 100%, 2 votes
I solved the problem, by tipping the dishwasher back about 45degrees, I think this re-adjusted the flood sensor, and it is now working fine. Thank you
Posted on Jan 29, 2010
rylee_smith
  • 8619 Answers
SOURCE: after wash cylce waste water reains in bottom of
Hi
If the water doesn't drain from your dishwasher, check these:
Drain line/air gap A clog in the drain line or air gap (if there is one) is the usual reason that a dishwasher won't drain. Often the problem is at the point where the drain line attaches to the garbage disposer or household drain line. If you remove this line, you can clear any debris from the hose or hose connection. Be sure to reattach the hose before starting the dishwasher again.
Pump Your dishwasher pump ejects the water. The pump is usually mounted directly to the motor, then attached to the bottom of the dishwasher. You can reach the pump from inside the dishwasher, but first you need to remove the lower rack, the spray arm, and the spray arm support.
Look for an impeller--a round plastic fan blade-type of device that spins around. This is the wash impeller, which forces the water through the spray arm. Beneath the wash impeller is the drain impeller, which is similar in size and shape to the wash impeller. The drain impeller pushes the water toward the drain port. These components make up the pump. If any of the pump components are defective, you need to replace them.
Drain valve and/or solenoid Many dishwashers use a drain valve with an electric solenoid. When electricity flows to the solenoid, the valve opens and diverts the water to the drain. Sometimes the solenoid, or the diverting lever, sticks and prevents the dishwasher from draining or filling properly. Try to free up the solenoid to lubricate the lever. Otherwise, you may have to replace the solenoid or pump assembly. With these systems, the motor always rotates in one direction. When it's energized, the drain valve diverts the water.
Other dishwashers simply reverse the direction of the motor to drain the dishwasher. These units don't have a drain valve. Instead, there's a drain hose connected directly to the pump housing.
Belt One brand of dishwasher uses a belt to drive the pump. If this belt is broken or has fallen off, replace it.
Motor If the motor isn't turning or working, the unit won't drain. First check to be sure you have power to the dishwasher. If not, see the section "It doesn't work at all." If the motor hums but doesn't turn, it may need to be replaced.
Some dishwashers are susceptible to getting stuck if you don't run them regularly. If you haven't run the dishwasher for more than a week, you may need to manually spin the motor to free it up. If the motor is defective, you need to replace it. Dishwasher motors can't be serviced.
Timer Part of what the timer does is control the motor and drain valve. If the timer doesn't work properly, the water may not drain and you need to replace the timer. This problem is uncommon.
Please do rate this solution as "FixYa" if found useful and revert for further assistance.
Thanks
Rylee
Posted on Mar 31, 2009
heatman101
  • 43501 Answers
SOURCE: not draining water and not cleaning all, pipes ok
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
e
Posted on Sep 29, 2010
E:25 on bosch dishwasher ?
Bosch E25ErrorThe drainpump is blocked or restricted by debrisPossibly something stuck/jammed in the wash or drainpropeller, remove filter mesh at the bottom of the dishwasher. Carefully remove any excess water and debris jammed near the propeller caution there may be glassor debris near or where the water drains-out.Removeand clean the spray arms, they may have food debris jammed, rinse in hot runningwaterMaintainerWash Runa wash with a tablespoon of powder, without any dishes on the hottest settinge.g. intensive, 65C, if you have a 70C this will be more effective.
Apr 09, 2012 | Bosch Dishwashers
E 15 problem code on Neff dishwasher
Bosch E25ErrorThe drainpump is blocked or restricted by debrisPossibly something stuck/jammed in the wash or drainpropeller, remove filter mesh at the bottom of the dishwasher. Carefully remove any excess water and debris jammed near the propeller caution there may be glass or debris near or where thewater drains-out.Remove and clean the sprayarms, they may have food debris jammed, rinse in hot running waterMaintainer Wash Run a wash with a tablespoon of powder, without any dishes on thehottest setting e.g. intensive, 65C, if you have a 70C this will be moreeffective.It can bequite common for a dishwasher to not drain because either the drain hose or theair gap (if the unit has one) is clogged up. Drain hose clogs commonly occurwhere the hose is attached to the main household drain line, or where the hoseconnects with the garbage disposer. Turn mainswater off and disconnect mains power Tryremoving the drain hose to unclog any debris. Don't forget to reattach the hosebefore you start your dishwasher again.The drainpump is blocked or restricted by debrisPossibly something stuck/jammed in the wash or drainpropeller, remove filter mesh at the bottom of the dishwasher. Carefully remove any excess water and debris jammed near the propeller caution there may be glass or debris near or where thewater drains-out.Remove and clean the sprayarms, they may have food debris jammed, rinse in hot running waterMaintainer Wash Run a wash with a tablespoon of powder, without any dishes on thehottest setting e.g. intensive, 65C, if you have a 70C this will be moreeffective.Turn the main water supply and main power offE15 error means the anti-flood system as activated; you havehad an overspill of water into the base plate below the sump.
If you take the kick plate off from below the door youshould be able to access the base to remove any excess water.Behind your kick board is a plate below the door. Remove theplate.
With the power off push a rag into the base plate to soak up the water.
Failing that pull out the dishwasher onto the floor and tilt the machine backto allow the water to run outSwitch the water and power back on and restart the programto test.If the appliance is less than 2 years old Neff/Bosch Groupguarantees it
Apr 07, 2012 | Neff 24 in. S5456 Built-in Dishwasher
What is E25 on my Bosch super silence dishwasher?
I quote same wrong from other user:
Question: Model dishwasher is Bosch Exxcell SMS50E02
It stopped before the end of a cycle with the error code E:25 and the "check water" light came on
I mopped out all the residual water out of the bottom and then ran a rinse cycle, which after several trials I got to work and then it stopped at the end again with the same error code and water in the bottom as before.
Answer:
I assume by in the bottom you mean inside the dishwasher and not in the base.As long as there is no debris in the sump area and the hoses are clear it appears you have a bad drain pump.
Hope helps.
Apr 03, 2011 | Dishwashers
My bosch dishwasher will not drain and makes a humming noise
Humming noise is an indication of your drain motor getting power but not spinning. Either your drain pump is defective and needs to be replaced, or something is stuck in the pump preventing it from draining out the water. Either way you will have to take the dishwasher out and get at the pump from the bottom of the machine.
Jan 31, 2011 | Bosch SHX4AP05UC Dishwasher
Water in bottom of bosch dishwasher will not drain. How do I get this water to drain
Hi
Dishwasher not draining issue occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If still not visible then the drain filter or drain pump is clogged and you'll need to clean the drain filter and drain pump. To access the drain pump, please follow the procedure---
1. Drain pumps are mounted to sumps in the front of dishwashers --they're easily accessible from the front of dishwashers by removing toe kicks.
2. Tools needed: small flat blade screwdriver (for unlocking terminals).
3. Remove toe kick/base cover, pull up terminal cover and disconnect wires (using screwdriver to unlock locking terminals).
4. To remove pump, pull latch (on circular collar) & rotate pump clockwise (cw).
5. To install new pump, insert @ 2:00 position & rotate counterclockwise (ccw).
6. Clean water & debris from base, then check float operation.
7. Connect wires, then install base cover & toe kick.
Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Daniel
Jan 26, 2011 | Bosch SHU9915UC Dishwasher
My bosch exxcel has water sitting in bottom and doesn't appear to be draining down.
Check to see if there is a removable lower plastic cover at front of washer, if there is, then remove this, and you should find the pump filter located here, unscrew anticlockwise to remove and clean.
If no sign of filter, then remove rear panel of washer, and access the pump from here to check for blockage.
Please rate my solution.
Thanks.
Nov 09, 2009 | Bosch Exxcel WFO 2465 Front Load Washer
Cleaning the drain of a bosch dishwasher
had the same problem if you remove t20 screw on the left side of the bottom bowl & remove plastic cover this is the drain pump & can block with food or glass particles clean it out & check it revolves & should be ok
Jun 16, 2008 | Bosch 24 in. SGS45E02 / SGS45E08 Exxcel...
Dishwashers Logo
20,934 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
