Question about Craftsman 26 Hp 54" Deck Yard Tractor
Will any other engine work on craftsmen 26 hp 54" cut other than Kohler?
  • 770 Answers
Sears also built a 54" craftsman lawn tractor with a Briggs V Twin. The issues that confront you are, Crankshaft length and diameter, engine bolt pattern, Throttle and choke linkage, and wiring harness. It can be converted, but these items must be adaped to work. May be easier to repair your Kohler. Good Luck! I hope you find this to be very helpful!
Posted on Feb 06, 2010
Are there a difference in the coils on a 26 hp kohler?
Yes and the numbers should match up on both old coils. The new coils will have a different part number because they have updated them.
Jul 03, 2014 | Craftsman Kohler Courage 26 hp 54" Garden...
Craftsman 26 hp Kohler engine 54
to be honest the enigne ahas a control that the left side must fire and run before the right starts to fire it sounds to me like you have a fuel issue possibly the carb. is gummed up and dirty.
Jul 27, 2012 | Craftsman Kohler Courage 26 hp 54" Garden...
Kohler command pro 23 engine model cv23s manuel
that engine uses 2 so if you have no spark from either one check your safety switches unplug the harness going to the engine and try then some have a module check for power in
Jul 02, 2012 | Husqvarna 26 Hp 54" Deck Zero Turn Riding...
Craftsman 54 in lawn tractor W/ 26 hp Kohler engine
Could be, but test each item with your tester. Test key switch (12V in and 12 V out when turned to start., operator present switch 12V in 12V out (seat) Clutch switch, etc. till finally you test for 12V on the small terminal on the starter solonoid. Happy testing!
Jul 19, 2010 | Craftsman 26 hp 54 in. Deck Deluxe Yard...
Craftsmen tractor needs engine.
http://www.smallenginewarehouse.com/
This will direct you to all kinds of engines. You pick the one that fits you tractor.
If it is a 26 HP Kohler engine you will spend about $1,500.00 for a new one.
You may want to consider 2 options.
Finding a used engine or replacing the tractor.
Please let me know what you find
Feb 06, 2010 | Craftsman 26 Hp 54" Deck Yard Tractor
Will any other engine fit a craftsmen 26 hp lawn tractor other than the kohler
Yes there are 2 other options.
Briggs and Stratton, and Onan.
Here is the information. You will need to have your output shaft size.
Craftsman mower with 26hp kohler smokes when i cut on hill, why?
what happens is the oil gets into the valves which will come out the exhaust when on level ground after a side to side or going straight down because the valve's are in the front of engine which is pointing to the front of mower you wont hurt the engine if it does that i would just check the oil often to make sure it doesn't run out
Jun 13, 2009 | Craftsman 26 hp 54 in. Deck Deluxe Yard...
NO FORWARD NO REVERSE
I had the same problem so I looked under the mower and the belt that goes from the engine to the back of the mower was off so I pushed the clutch as far forward as I could and the belt went on it and it worked
May 29, 2009 | Craftsman 26 hp 54 in. Deck Deluxe Yard...
Craftsman 26 Hp 54" Deck Yard Tractor Logo
64 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
