Question about Ovens
Oven elements not working after a trip from the fuse box
While cooking in the oven suddenly there was a popping sound and some smoke appeared coming out of the oven. the fuse tripped and we reset it. the stove top elements then started to work but the oven element still did not work.
  • 73 Answers
Need new element
Posted on Feb 06, 2010
When i using my oven, suddenly off i don't know how to fix
If there are no lights showing or electric fan or heat
Check the cooker trip / fuse on the main Fuseboard.
Should be 32 amp rating.
If Light works / or / and Fan but no heat then likely to be Cooker element. If its a double element or oven with grill you may still have reduced capacity to heat / cook food.
May 25, 2016 | Ovens
Bosch HBN7052 - main fuse tripping even after replacing the heating element
It appears there is too much current (electricity) being drawn towards the element, seeing once you replaced it, it worked fine for 5 minutes and then tripped again...I believe the problems lies within the wiring going towards the element, or the thermostat that controls the amount of current coming towards the element. Instead of turning off at a desired temperature, its not and continuing to heat up to the point of tripping the fuse. Try replacing the thermostat.
Dec 01, 2013 | Bosch Ovens
Smeg oven stopped working
This tutorial will show you how to check your Smeg element and how to replace your Smeg cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
  1. Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  2. If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  3. When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped you why not get me a beer? Paul is from the Naturally he would appreciate beer How to Repair Home...
Jan 27, 2012 | Smeg Ovens
Fan but no heat
  2. If you're Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
If this helped like us on Facebook please
Mar 14, 2009 | Smeg SE280X Stainless Steel Electric...
Oven element tripped main fuse box switch
Try running it with the element disconnected, if it does not trip, then element is causing prob.
If it still trips, then look elsewere for prob,.
Please rate my solution.
Thanks.
Feb 24, 2009 | Bosch HBL 5032 Electric Single Oven
Bottom oven not working
A tripped breaker or blown fuse on an electric oven or cook-top, combined with an element that has stopped working, is usually a sign of a shorted, then blown (if the fuse or breaker no longer fail) element.
If you know how to use an ohmeter, you can pull the element, disconnect the wires from each end, then measure the resistance between each end of the element, and each element to the outer sheath.
A good element has just a few ohms of resistance between the wire connection points, and infinite resistance from the wire connection points to the outer sheath. Any readings other than that means the element is bad and need's to be replaced.
Jan 14, 2009 | Baumatic B904SS Stainless Steel Electric...
Tricity bendix se211 electric cooker trips all my electrics
The symptoms you describe are a classic example of an oven element heating up, and as it gets hotter, the insulation is breaking down, thereby causing the earth leakage trip to operate.
To confirm this , switch on the oven, and turn all 4 rings on the top to full heat, 2 at a time, let them stay on for at least 10-15 mins, and if it does not trip, then you can be pretty sure it is the oven element(s) that is the problem
It is not likely to be the wall switch, as if it were faulty, i would expect the trip to go right away.
If you want to check further, then turn on the oven again and see if it trips, if it does ,then it is definately the oven element(s) that is the problem.
If it is a fan assisted oven , the element is at the rear of the oven, and possibly one under the base ot the oven. If it is a conventional convection oven, then there is an element at each side of the oven, even if one is faulty, replace both.
Plz rate my solution.
Thanks.
Jan 07, 2009 | Ovens
Belling XOU252 Single Oven Trips Fuses Repeatedly
Hi.
Probably a faulty element, if you feel competent enough, disconnect the feed to the elements in turn, this should eliminate the problem.
Good luck.
Nov 20, 2008 | Belling XOU252 Electric Single Oven
Oven made a loud noise, pop, and then black smoke....could heating element go out?
sounds like it blew a fuse or the heating element burnt out on it,look to see if the element is burnt in two
May 16, 2008 | Amana AEW3530DD Electric Single Oven
Broken cooking appliance :( please help
if the fan is spinning then it sounds as though the element has gone. has your fuse box recently tripped? it may have been the blowing element.
Jun 10, 2007 | Belling XOU252 Electric Single Oven
Ovens Logo
131 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
