Question about Proform Exercise & Fitness
Treadmill is slippng badly
My 500 series Proform treadmill is slipping badly. is there an adjustment I can make to tighten it?
    Problem Solver:
  • 18 Answers
There should be an allen head bolt on each side at the rear of the treadmill going throughthe rear cover into the tail [rear] roller. Turn each one 1/4 turn at a time equally untill slipping is stopped. If belt tracks more to one side tighten slightly more on that side.
Posted on Feb 08, 2010
Why is my proform 5.0 crosstrainer is slipping
if your walking belt is slipping it has loosened up. there are two adjustment bolts on the end of the treadmill. one on either side. these are allen heads. tighten clockwise to remove the slack. first start with treadmill running at 2 mph. tighten both one full turn. let belt adjust. check the centering of the belt. whichever side it is closer to tighten that side about a half turn. let belt adjust after each adjustment for a min.once belt is centered and if it still slips tighten both bolt evenly
Aug 30, 2014 | Exercise & Fitness
Belt seems to slip while on the treadmill
hi your belt need to be tightened, check your manuel on how to do this. but do not walk on the belt when its doing this you can damage the belt and the motor very expensive to fix.
Nov 11, 2010 | Proform Crosswalk 500 Treadmill
While trying to run the mat/track stops or studders momentarily.
If the walking belt slips when walked on, first remove the key and UNPLUG THE POWER CORD. Using the allen wrench, turn both rear roller adjustment bolts clockwise, 1/4 of a turn. When the walking belt is correctly tightened, you should be able to lift the edges of the walking belt 3 to 4 inches off the walking platform. Be careful to keep the walking belt centered. Plug in the power cord, insert the key and run the treadmill for a few minutes. Repeat until the walking belt is properly tightened.
May 10, 2010 | Proform Crosswalk 500 Treadmill
Proform 622 Exp treadmill belt slips
If the walking belt slips when walked on, first remove the key and UNPLUG THE POWER CORD. Using the hex key, turn both rear roller bolts clockwise, 1/4 of a turn. When the walking belt is correctly tightened, you should be able to lift each edge of the walking belt 2 to 3 inches above the walking platform. Be careful to keep the walking belt centered. Then, plug in the power cord, insert the key, and carefully walk on the treadmill for a few minutes. Repeat until the walking belt is properly tightened. Now if this does not solve this problem then check the drive belt and adjust accordingly, also reverse the process of the above mentioned
Apr 26, 2010 | Treadmill Doctor Proform 622 Exp Treadmill...
My 525x slips. Which part typicaly causes this?
This usually caused by a slipping drive motor belt. remove the hood cover, one screw in rear and 2 on the bottom. There will be an adjustable bracket on the drive motor. Good luck, Tim
Nov 05, 2009 | Proform Crosswalk 500 Treadmill
Proform Crosswalk Dual Motion Cross Trainer Treadmill. motor works great. Rubber on right side under the moving belt has come off so belt slips when in use
I think you are talking about the front roller. It has a rubber sleeve that helps to grip the walking belt. Sometimes you can tighten this enough to keep it from slipping but you run the risk of overtightening and damaging both rollers. We recomend replacing that roller.
Oct 24, 2009 | Proform Crosswalk 500 Treadmill
I have a proform treadmill that slips as soon as i step on track i looked at the belt it looks good how do i tighten up the track
There should be adjustment screws on the back left and right sides. The screws will be horizontal with the tread, and probably need an allen wrench to tighten. If the tread runs straight, tighten each side 1/4 turn at a time to keep them even. Check the tread after each adjustment, and stop as soon as the tread quits slipping.
Sep 08, 2009 | Proform Crosswalk 500 Treadmill
The belt is slipping and making a squealing sound
This is caused by one of three problems. First and most likely, the walking belt is loose. To tighten the belt, start by locating the two bolts that adjust the rear roller (one on each side of the unit in the back). Run the unit at about 3 mph. Tighten the bolts a 1/4 turn at a time. Make sure that what you do to one side, you MUST do to the other side or the belt will get off center. After you tighten it 1/4 turn, check the belt to see if it is still slipping. If it is then tighten the belt 1/4 turn again. Continue until the belt does not slip, but do not tighten the bolts more than 2 full turns. If it takes more than 2 turns then something else is the problem. The second problem that it could be is the drive belt might be loose. To tighten the drive belt, start by removing the front cover. loosen the bolts around the motor then tighten the drive belt by tightening the motor adjuster bolt. Once the drive belt is tight, tighten the motor back down. The third problem that it could be is the walking belt could be worn and need to be replaced. Let me know if you have any questions.
May 14, 2009 | Proform Crosswalk 500 Treadmill
Exercise & Fitness Logo
262 people viewed this question
Top Proform Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
 Atlanta Fitness
Atlanta Fitness
Level 1 Expert
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
