Epson Stylus Photo 1290 InkJet Printer Logo
Anonymous Posted on Feb 06, 2010
Out of ink message but just put new cartridge in
I've just changed the black cartridge with a Radinks cartridge and the ink button stays on red and when start print , message come up out of ink. It won't go through the nozzle check, saying that the cartridge is not recognised or out of ink.
Anonymous
Level 2:
Guru:
  • Expert 161 Answers
  • Posted on Feb 06, 2010
Anonymous
Expert
Level 2:
Guru:
Answers
161
Questions
Helped
37255
Points
510
Fix your cartridge properly...maybe it is not in plce...refer for manual so that you have put it in right place...
try to rest your printer if you know how...
Testimonial: "I was about to go and buy a new cartridge. You posting made me double check, and realised my wife hadn't actually put the new one in! Doh!"
2answers
I cant print it says I'm out of black link and I just replaced it and it's flashing E 1 6
From http://www.refreshcartridges.co.uk/igloo/clearing-canon-pixma-error-message-e13-e16/
Locate the STOP/RESET/RESUME button on your printer which is represented by a triangle within a circle on the body of your printer and is usually in red, white or black as pictured below. With the reset button located hold it down for at least five seconds and then release it.
I've changed the ink cartidges but the black and color ink lights remain on and it won't print. I think the E2 error message is on.
This hapens when refilled cartridges are installed in the printer. To rectify the problem, look for the 'Resume button' normally black with a red circle around an arrow head pointing towards you. With the printer powered on, press and hold this button down for about 10 seconds. The error code will usually clear and the printer will print but the orange lights will still flash.
2answers
I have a kodak 5500 aio printer. I replaced the
Try the following:
1. Open the printer access door.
2. Put out both ink cartridges and the printhead.
3. Let the printer access door open.
4. Put out all paper.
5. Pull out the ac adapter at the back of the printer.
6. Wait 60 sec.
7. Pull in AC adapter.
8. Wait 30 sec. then turn on the printer
9: Wait for the error message: Printer access door open.
10. Close the printer access door.
11. Wait for the error message: Printhead is missing.
12. Open the access door and put in only the printhead and the close the access door.
13. Wait for the error message: both ink cartridges are missing.
14. Open access door, put in only the black ink cartridge, then close the acess door.
15. Wait for the error message: Color ink cartridge is missing.
16. Open access door, put in the color ink cartridge and then close the access door.
If the error is solved, do a firmwareupdate right now.
You can find it here.
Changed ink cartridge now it won't work
Try removing the black and see if the error is still there. If it goes away the black is bad, if it stays you got a defective new color cartridge.
Red error light stays on says needs black ink but i just put a new one in
the main issue here is that your printer don't recognize your new black cartridge.
try shutdown your printer and on it again or long press on your power button ..
and your also to open close your main door of your printer..
so that it will recognize the full black cartridge.
3helpful
Epson 830u Printer Red light stays on even with new ink
I realised that I had to replace both the ink cartridges even though I only wanted to replace the black for it to work. Once I replaced both the black and colour cartridge the red light went off. Thanks
Black ink cartridge doesn't work.
Have you tried
  1. Taking out all the cartridges
  2. Power down the power
  3. Power up the printer
  4. Open the scanner Cover
  5. Close the scanner cover
  6. Message will ask you to put the ink.
  7. Put in Black
  8. Close scanner cover
  9. It may ask you whether the Black is being changed.
  10. Open the cover.
  11. Install Cyan.
  12. Repeat step 8-10 for the rest of the 2 colours.
  13. It should resolve the Black ink empty message.
Let us know if this works.
Thank you.
1helpful
Error inkcartridge
Error message: No color or black ink cartridge-->Press the Color Copy button to install a new ink cartridge.
Solution: The indicated ink cartridge is not installed. Please install the necessary cartridge(s).
Error message: Color or black ink out -- >Press the Color Copy button to begin replacing the ink cartridge.
Solution: The indicated ink cartridge is out of ink. You will need to replace the necessary ink cartridge(s).
Error Message: Ink cartridge error -- > Press the Color Copy button to begin replacing the ink cartridge.
Solution: There is something wrong with the ink cartridge. Make sure the cartridge is genuine Epson ink. Also, try reseating the cartridge (remove it, and then reinstall it).
Error Message: Paper jam or misfeed -- > Press the Color Copy button and clear the paper jam by hand if necessary.
Solution: Paper is jammed. Check for any obstructions under the unit's cover, and in the paper tray.
Error Message: Paper out -- > Load paper in the sheet feeder and press the Color Copy button.
Solution: Load paper in the sheet feeder, and then press the Color Copy button to continue printing.
Error Message: Scanner unit open -- > close the scanner unit
Solution: Carefully close the scanner and press it down until it clicks securely into place.
Error Message: Scanner error -- > See your documentation and call service if necessary.
Solution: Press the ON button to turn off the Epson Stylus CX3200. Unlock the transportation lock, if necessary. If it is already unlocked, toggle the lock back and forth, 5-10 times. Turn on your Stylus CX3200 again.
Error Message: Printer error -- > See your documentation and call service if necessary.
Solution: Press the ON button to turn off the Epson Stylus CX3200. Disconnect it from power, and then reconnect it to power. Press the ON button to turn on the Stylus CX3200
3helpful
Help Epson CX3200
I just like to ask to where specifically you can see the red light. It will help us determine what cause the red light. To give you heads up as well, the Printer's LCD screen can help us determine what exactly the offline condition of the CX3200 is:
Solution: Press the ON button to turn off the Epson Stylus CX3200. Disconnect it from power, and then reconnect it to power. Press the ON button to turn on the Stylus CX3200.
Cartridge error
How I solved this problem was, I took out the color cartridge (which seem to be the one giving the error message) and worked only with the black ink (and chose print black and white )
My color ink cartridge had been refilled at Walgreens. The Black ink cartridge is an original Lexmark
Top Epson Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
NH TECH
Level 1 Expert
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
