Question about Dell UltraSharp 2408WFP 24" LCD Monitor
I have a 2408WFPb monitor. Yesterday I prompted it to Auto Adjust. From that time on the right 3/4 of the screen was all that the open window appeared in. The other 1/4 of the screen had a forest screen color to it. The window adjustments gave me no results.
SparkGap
  • 363 Answers
SOURCE: Always says: Auto Image Adjust
These are the allowable resolutions and refresh frequencies for your monitor. 1280 x 1024 @ 60, 75 Hz 1024 x 768 @ 60, 70, 72, 75 Hz 800 x 600 @ 56, 60, 72, 75 Hz 640 x 480 @ 60, 75 Hz 720 x 400 @ 70 Hz 1280x720 is invalid but I see that you were having problems at 1024x768 which might mean the refresh timing was wrong. Make sure the monitor tab in the display properties (advanced) is correctly set with 'hide modes that this monitor cannot display' so that the display is locked to the valid frequencies and resolutions. If all else fails look at the game .ini configuration settings. You might be able to set a compatible mode there. Or run the game in a window.
Posted on Sep 24, 2007
top50
  • 134 Answers
SOURCE: Auto Adjust
There are a couple of things that you can try...
1. Setup on Monitor..: check on monitor menu, if the feature auto adj are enable,.try to Reset setting and resetting your display.
2. On windows(xp) desktop click Start > All programs > Startup... See for apps has executed for starting window. if you see "Adobe Gamma Loader" installed, maybe you haven't to saved your gamma/bright setting (it also happen when the first time installing adobe reader/photoshop, etc) you can resetting by "right" click on desktop > properties > click on Setting tab > click advance > Color management. after done, click apply then ok.
if The picture on monitor is upside, do resetting on monitor menu, > select V POSITION. (Vertical)
Hope this be of some help/idea. Pls post back should you need additional information.
Posted on Nov 13, 2007
  • 12 Answers
SOURCE: cmv monitor bad color
The problem is your monitor, not driver or settings or video adapter cards. You have basically two options get another CRT or LCD display, or if it is still under warranty call the company get a "Return Authorization Number" and ship it back to the manufacturer. I did that with a NEC MUltisync 19" years ago, it turned red, there was little ability to actually change the red image at all. cI Shipped it back to NEC and it has worked ever since. Good luck with your monitor.
PCrx4u
Posted on Dec 30, 2007
proton77
  • 1183 Answers
SOURCE: auto adjust
In case you have connected both the DVI and VGA cables to the back monitor can cause this problem. Try unplugging one of the cables and check if the problem gets resolved
Posted on Mar 23, 2008
SOURCE: Colors are off after auto adjust
the same trouble with the color
Posted on Apr 16, 2008
I have LCD monitor screen & windows xp as operating system.i cannot remove auto adjusting message box. it flashes on screen after every 2-3 seconds & due to this my screen will auto adjust at every...
The message is being created by the monitor not Windows. The only thing you can do is look for the option to disable it on the monitor's menu options. NEC-brand monitors will have something call "Onscreen Notification" which you can disable. Hopefully your BenQ will have a similar option.
Mar 20, 2011 | BenQ FP71G+ 17" LCD Monitor
Auto adjust in progress, want it removed
Your video card or monitor sounds like it might be malfunctioning. Have you tried another monitor? Does it show anything on the screen after turning on the computer? If it does then goes to "Auto Adjust" then try restarting and pressing F8 over and over until you get a menu. Then select VGA Mode. Change the screen resolution by right clicking on the desktop and clicking "Properties" then the "Settings" tab. Use the slider to lower the resolution and then restart.
Aug 03, 2010 | Microsoft Windows XP Professional
Pop up of monitor adjust screen
Hi, you probably have to set the correct resolution that fits on your monitor. The correct resolution is: 1920x1200 You can set it by right-clicking on your desktop and choosing "Screen Resolution" in Windows Vista and Windows 7. If you use Windows XP, right-click on your desktop and choose "Properties" Then open the rightmost tab to choose the resolution
Jul 19, 2010 | CTL 261UW 26Inch Wide Screen LCD Monitor...
The screen has shifted to the right so that i cant see the [X]on any windows. Ive already maxed out the left shift but its still stuck to the right.
does the screen appear distorted;does it move as you shift left/right/up/down? IF THIS IS TRUE, YOU PROBABLYHAVE THE RESOLUTION SET WRONG....RIGHT CLICK ANYWHERE ON THE SCREEN;PROPERTIES;SETTINGS; ADJUST SLIDEBAR TO PROPER RESOLUTION FOR YOUR MONITOR
Mar 07, 2010 | AOC 2216Vw 21 inch LCD Monitor
Screen monitor images on the righ side is not showig.
Hi afcarrillo,
This could be a simple resolution problem. By that I mean that the resolution is set too low, therefore putting things off screen. Here's how you change the resolution:
Windows XP
Right click the Desktop and select Properties. Click the tab all the way on the right that says settings, and drag the slider to your native resolution of 1600x900
Windows Vista
Click Start, Control Panel, Appearance and Personalization, Personalization, Display Settings and drag the slider to 1600x900
Windows 7
Simply right click the desktop, select Screen resolution and pick 1600x900
If you do not have a resolution problem, then it's most likely the monitor itself. Most often times you can fix it one of two ways:
1. Some monitors have a button that says "Auto" which will auto adjust your monitor. If you have one, try it.
2. If that didn't work or you don't have one, go through the monitor's OSD (on screen display) and work through the settings so that you can manually adjust it and set it to your taste.
Hope this helps :)
Nov 29, 2009 | Acer Computers & Internet
I have a Dell monitor and the text is blurry and fuzzy, how do I fix this?
this is actually from dell support website.. hope it will correct your problem...
1 Ensure the correct resolution is set for the monitor. Flat panel monitors display the sharpest, clearest images when set to their optimal resolution. Sometimes games and other programs will change the resolution then fail to set it back once they are closed. This will then make the desktop look big, distorted, and grainy. Perform the following steps to adjust the resolution:
  1. Right-click an empty area of the desktop, and then click Properties. (Or, click Start, click Control Panel, and then double-click Display.)
  2. In the Display Properties window, click the Settings tab.
  3. Under Screen resolution, move the slider to the desired setting. For most flat panels the optimal setting will be all the way to the right.
  4. Click Apply, and then click OK.
  5. If prompted, restart the computer.
NOTE: If the resolution will not adjust to the appropriate settings, the video driver may need to be reinstalled or updated.
2 Ensure the screen is clean. Finger prints and smudges will make the screen look blurry. Clean the screen with a soft lint free cloth. If needed, dampen the cloth with warm water or use a LCD cleaning kit that can be purchased from most electronics stores.
3 Use the On Screen Display (OSD) on the monitor to select the Auto Adjust feature. Selecting this will synch the video signal and can sharpen the video image.
4 Reseat the video signal cable to ensure a secure connection.
5 Use the On Screen Display (OSD) on the monitor to select the Factory Reset feature.
6 Test the monitor on another computer or test another monitor on this computer. If available, testing different hardware will isolate if the problem stays with the computer or monitor
Sep 12, 2009 | Gateway FPD2275W LCD Monitor
Pop up auto adjust in prograss
I had the same problem with my HP LCD. I'll turn on the monitor and it will run auto adjust and set everything to the max making the screen very bright. What I did was remove the button panel board and put it back. Everything works fine since then.
Jan 09, 2009 | Dell E173FP 17" LCD Monitor
Need to Auto Adjust Envision 20" monitor every time
yes it may be a memory problem inside the monitor replace the memory from technical person
or refer the manual with the monitor some trick may given so that push menu twotimes or operate like mobole button
Nov 09, 2008 | Proview PX-986 19" CRT Monitor
LG 700E monitor gives a blurr vision
open unit, adjust focus pot on flyback, may have 2 focus pots.
do both until satisfied.
If the problem varies with temperature (on time), then you may have a failing flyback.
Oct 02, 2008 | LG Studioworks 700S 17" CRT Monitor
Auto adjustment.
Try this one:
the is not the same problem. But the cause is exactly the same
http://www.fixya.com/support/t117851-menu_screen_appears_all_time_flashes
Regards
Jan 28, 2008 | Neovo F-417 17" LCD Monitor
Dell UltraSharp 2408WFP 24" LCD Monitor Logo
180 people viewed this question
Alun Cox
