Question about Ricoh Aficio 450 Copier
Error sc547 i have this error message when i turn on my copier, the only thing i have done is remove the cooling fans from rear and clean then reinsert therm
  • Daniel Wright Feb 22, 2008
    its actually fixed now, but is saying CLOSE SIDE DOOR instead
  • Ricoh Expert
  • 1,326 Answers
Did you unplug any other wires by actcident or move some thing? was that problem there before. If not recheck what you did.
Posted on Feb 22, 2008
Help with error code SC547-01
sc 547 mean fixing unit error ,you can reset by simply getting into simulation mode and then switch off an the machine ,getting into the simulation mode is simply by pressing 107 and press and hold c ,
Jun 19, 2013 | Ricoh Aficio 450 Copier
Showing error code 0046
Fusing motor cooling fan is in op due to dust build up, motor gone bad, or the main control board has gone, to reset open close front door, if it still come back (code) Then remove the back cover after unplugging and clean all filters and fans if one is dirty they all might need dust removal. remove each fan clean with can air make sure they turn properly.
May 26, 2012 | Minolta EP4000/5000 CS/PRO Copier
I would like know the method for edit error of hp laserjet P3005n error 57.03. Please suggestion or method for edit to me Thank you .
Hello Niramon,
The error message hp laserjet P3005n error 57.03 is due to sub cooling fan (FM2) error has occurred. Fan operation is verified during device power up. Fan operation occurs only during power up or during a print job.Turn the device off and then on. Verify that nothing is hindering or blocking the fan. Verify that the fan is connected to connector J512 on the ECU PCA. You might have to remove the main cooling fan to see this connection. If the message persists, replace the fan.
Jun 13, 2011 | HP LaserJet P3005n Printer
Ricoh afico 811 error sc689 and sc547
sc547 is a power supply error that can mean you have a faulty power supply. The service manual does not list an sc689, and it's not in the help desk support database either... are you sure that's the code that comes on the screen?
Oct 05, 2010 | Ricoh Aficio SP C811DN-DL Printer
Eror sc547
The error sc 547 refers to a "Zero cross signal malfunction".
This means that the applied power supply AC frequency was detected at over 66Hz or below 45Hz, and the zero cross signals are not detected within a certain period within 500 ms after the main power switch has been turned on.
Possible causes are:
- Power supply board defective
- IOCSS defective
- BICU defective
Try to reset the SC code by entering SP5810 and select 1.
Then hold down the photo mode key and the # key at the same time for at least 3 second.
Then turn the machine off and on again.
If the same issue still appears, try to replace the Power Supply Unit.
Jul 04, 2010 | Ricoh Aficio MP 2000 Black and White...
Error message to check fan #3. Where is it?
If you take the rear of the set off and hold the Interlock Switch on the right side up,Turn "ON" the set and look for three fans,one of them will not be turning. There are two small fans and one large one. The Large Fan is the Lamp cooling fan and the two fans are for cooling the Ballast and the other one is for cooling the DMD chip Heat Sink. The two smaller fans are the same type. The Lamp Fan (Large one) part# is BP31-00024A and the two small fan #s are BP31-00001A. They are all easy to replace.
Jul 13, 2009 | Samsung HLN467W 46" Rear Projection HDTV
Optima getting fan fail error what can I do?
its eather it is dusty or the fan morter is burn out.
Jan 04, 2009 | Optoma EP739 Multimedia Projector
Ricoh copier
Must have unplugged the thermister on the coupling connection bank. Reset fuser: Clear modes/ 107/ press and hold clear/stop. Pick copy sp. select mode. exit out of all screens and cycle power.
Feb 21, 2008 | Ricoh Aficio 450 Copier
Error message: E00805-0002
Check the main cooling fan (fm1) in the rear center of the copier. is it running? if not see if it is plugged in. I had a kid stick a sucker stick in the fan causing the same problem.
Nov 21, 2007 | Canon imageRUNNER 5000 Copier
Ricoh Aficio 450 Copier Logo
528 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
