Question about Hitachi UltraVision CineForm 55VG825 55" HDTV
I have a fios remote control.the remote stopped working on the tv but still works on fios
Remote volume will not work
HAD SAME PROBLEM RE PROGRAM FIOS REMOTE ENTER 4 DIGIT CODE AFTER LIGHT BLINKS PRESS VOLUME UP AND DOWN IT SHOULD WORK THEN PRESS ENTER OR OFF BUTTON FOR PROGRAM TO WORK TURN TV BACK ON.....FIOS PROGRAM MANUAL HAS SECTION FOR THAT PROBLEM...MINE WORKS FINE AFTER I DID THAT..
May 25, 2013 | Emerson EWC27T3 27 in. TV/VCR/DVD Combo
Sharp lcd tv will not respond to remote control
You are paying fios good bucks for service so let them earn it by getting your system to work with their gear as intended.
Make sense? It is THEIR not yours. U did not have this issue with the other company!
Sep 06, 2017 | Sharp AQUOS LC-32SB21U 32 in. LCD TV
What is the Remote Control Code for FLX1510
taken from their support f&q section word per word
"try the following codes 10019, 0178, 10178, 0030, 10030, 0835, 10835, or for Dish Network try 627, 659 or 505. For Fios TV (Verizon), try the code 3264. These codes may not work on some universal remotes. If there is another code listed for Element Electronics in your universal remote control guide, please try that code. Refer to the Remote Control Guide under your TV’s model number for more information."
Oct 01, 2009 | Element Electronics FLX1510 15.4 in. LCD...
Philips TV HDMI CEC EasyLink tries to control Cable set top box
I finally found a fix to this! YAY. I thought I might have to return the TV. I have the Phillips 42PFL5603D, but should work for other models.
On the TV press menu picture settings---picture---dynamic contrast (turn off) AND active control, turn off
If you have Comcast Moto box: on the Cable box go menu--->setup--->cablebox set up---RF BYbass set to ON
If you have a non-Comcast Moto Box, I'm sure there is an RF bypass setting in the menu. You'll just have to look for it. Another fix was close saying to only turn of the active control, but it took all 3 of these for it to work consistently. The latter let it work for all of 30 seconds.
Dec 29, 2008 | Philips 42PFL7403D/27 42 in. LCD TV
Vx37l stopped working with FiOS remote
I read in another forum where Vizio sometimes uses Vidtech codes. I got 0205 to work on my new Vizio V037L with my Verizon FiOS remote (Phillips RC144).
Oct 02, 2008 | Vizio VX37L Television
4 Digit TV code for FIOS Remote
what kind of tv is it? i work for fios ill get you the codes TONIGHT
Aug 11, 2008 | Protron PLTV-32 Television
FiOS TV remote control
bought an new one for $5.
Jun 28, 2008 | Onkyo TX-SR605 Receiver
TOSHIBA 36AF42
Your Fios box seems to be faulty
Mar 29, 2008 | Toshiba 36AF42 36" TV
FIOS remote with Olevia 532B12
I just got FIOS and had an Olevia 237 TV. Tried the LG, Phillips, RCA and Yamaha codes, no luck so I tried this:
- press and hold TV key
- still holding TV key, press the OK key and release both, device keys blink
- press 922
- point remote at TV and press play button
- press next button (two arrows pointing to right) about 325 times until the TV goes off.
Remote controls power, volume, input, and aspect.
Jan 10, 2008 | Olevia LT32HVM 32 in. LCD Television
Code for Verizon FIOS remote Control
Code 1292 worked like a charm for me!
Vizio SV421XVT
Dec 11, 2007 | Televison & Video
Hitachi UltraVision CineForm 55VG825 55" HDTV Logo
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
