Hello, I have a problem with my BT-3058: the product is composed of 2 HDD of 500GO in raid 1 (mirroring) Since some days: the blue and green light from the HDD2 are blinking one after the other. What does mean? Thanks to help me. Nicolas BEZARD
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 113 Answers
Hdd 0 is synchronizing to the hdd1
Posted on Feb 26, 2010
Raid Driver
send me you querry clearly to my email id:- venkatesh.k@cacheperipherals.com
Mar 15, 2012 | IBM System x3200 M3 7328 Server tower ...
Product: LaCie 2big quadra ((Professional 2-Disk RAID. I have no back-up with the 2 disks, and this soon after purchase (August 2010). Serial number: 5102001839. Disk 2 does not work. At the front, light...
If the failed hard disk drive is replaced with the exact same capacity, RPM and make of hard drive, then the array can be rebuilt. Raid 0 cannot be rebuilt as each drive contains half of the data, If RAID 1 then can be rebuilt as data on each drive is an exact copy. However if combination of RAID 0 and RAID 1 then can be rebuilt. It's best really to handel this hands on, I recommend taking it to a computer technician especially if the information on it is important.
Thanking you
damnor01
Nov 13, 2010 | LaCie 2TB 2BIG QUADRA RAID EXT ESATA FW800...
V have server 2003, in that v add a seperate hard disk for mirroring purpose. how to configure a mirror or raid?
1) to mirroring as a RAID, you require an additional HDD
2) right click on my computer, and select manage.
3) expand the "STORAGE" tree & go to disk management.
4) you have to convert your primary and additional both HDD into "DYNAMIC DISCS" by selcting your HDD and right click, and select convert into dynamic disks.
5) now create MIRRORED VOLUME after reboot.
Aug 14, 2010 | Computers & Internet
Confuguring raid5
Hi
You would need 4 Hard disk drives in total. you would need to create 2 RAID 0 (striping) and then Mirror them (RAID 1). to elaborate, HDD A&B will be at RAID 0 as well as HDD C&D. after, you would have to Mirror your two RAID 0. (raid 0+1 is also known as raid 5)
Hope this helps.
Jul 09, 2010 | IBM x3400 Server
To raid, or not to raid,? that is the question............
Always a good question,
For #1
Always a good idea to mirror your OS drive for quick recovery. So yes I would use 40GB of the velociraptor for a mirror. However if your board supports it I would actually suggest you would be better served for your dollar to buy some 500GB+ WD greens or seagate 7200.12's(do NOT buy 7200.11) then set them up as raid5, frankly you'll get redundancy and speed, with more space. 4 Greens will perform as well as three VRs and cost less.
I currently run two Greens and 2 7200.12's on my home server and the 7 rating is 7.6 for my HDD and I've got 4.2TB of space for under $500.
I mentions some of the pro's and cons in detail on my blog last week Pro's and Cons.
Hope this helps,
Chris
Mar 07, 2010 | Computers & Internet
RAID-1 failure on Dell Dimension 9100 Desktop
Since you are using RAID 1 (Mirroring) you will only need to send one drive for data recovery.
Since the Dimension 9100 uses SATA HDDs yes you can increase the storage capacity up to a matched pair of 650GB drives. I'd suggest you use the most current BIOS revision, but SATA controllers seem to be much more agreeable to large HDDs vs the EIDE ones before them.
RAID is redundancy, but it is not a data backup, as you have learned. Important data should be backed up to DVDs monthly/quarterly etc. and you can even do critical backups weekly.
Jan 06, 2010 | Dell Dimension 9100 PC Desktop
I cannot configure a SATA RAID 1 to mirror two WD HDD 1 TB
You sure you installed the ASUS RAID drivers when you installed Windows? Ya need to get the drivers off the ASUS disk, transfer them to a floppy, hit F6 when windows tells you to (during windows install...you only have a second or 2 to see the message!)) and use the floppy to install them. Might take a few tries to get it right.
Dec 26, 2009 | ASUS P5GD2 Deluxe Motherboard
Raid 1
there must be some key on the startup to enter into the raid menu. And in that raid menu you can create raid .
Jun 23, 2009 | IBM x3400 Server
I have hp proliant with raid 1+0 .I have 2 hard and usr in option
Sometimes shortened to RAID 10, RAID 1+0 is a particular combination of two different RAID levels: mirroring (RAID 1) and striping (RAID 0). The appeal of RAID 1+0 is simple: mirroring gives you the highest level of availability RAID offers, with the fastest rebuild times when a disk fails; while striping - using the proper chunk size - is the basis for high-performance I/O.
Jun 09, 2009 | HP ProLiant DL380 G4 Server
Problem with creating array
The Perc RAID controller in a 2600 doesn't support RAID 4.
You can do RAID 0, RAID 1 and RAID 5.
With 3 HDD's your best bet would be a RAID 5.
Mirroring is RAID 1 (which would only use 2 of the drives)
Aug 31, 2008 | Dell PowerEdge 2600 Server
Computers & Internet Logo
18 people viewed this question
David Payne
David Payne
