Question about HP PSC 1410v All-in-One Printer
KYOCERA FS C5020N PRINTER QUEUE
After printing items in the queue, the items remain.
When shutting down,the items print again and when starting up, if they have not been cleared manually, they print again until manually cleared.
This is a frequent but not continous situation.
Joe
  • 813 Answers
Remove from driver from control pannal>add remove program>
uninstall your printer driver & reinstall it i m shore its help u
Posted on Mar 07, 2008
So far answers don't coincide with the directions I've been given, which is "Press the WSB Button for 5 seconds."
The print queue is what is locked up. Try deleting the items in the print queue.
Start by pausing the print queue. Then delete the items in the queue one by one.
When you have the last print job in the queue it will probably be jammed up in the transition between the computer and printer. Switch off the printer. This should cause the printer on the computer to become offline.
Try deleting this job abain. If it dissapears then turn the printer back on making sure the computer understands the printer is back online. Then try printing again.
If it does not dissapear then you will need to restart the computer to free up this job. When the computer is back up and running check the print queue again. If the job is gone then turn the printer back on and try printing again. If it is not gone then try once again to delete the print job and it should dissapear this time.
Once the job is gone and the print queue is empty turn the printer back on and make sure the computer understands it is back online again.
Oct 14, 2014 | Canon Office Equipment & Supplies
HP LaserJet 4100 for all applications in windows 7. When I go to print a document and click on print. The print screen exits, the print job doesn't processes, and the print queue stays empty. Noth
Ideas? Yes. I had this happen on an LJ 1000 while trying to print my tax return. I tried emptying the queue, removing power from the printer, etc, etc. What finally worked was to empty the queue (again), disconnect power from the printer, shut down the computer, plug in the printer again, restart the computer, queue up a print job again, and hit PRINT.
Hope this works for you
Apr 11, 2013 | HP LaserJet 4100 Printer
Document stuck in queue and will not delete or print.
Its a common problem. All you have to do is to restart the Print Spooler service and delete the print queue. To restart the service follow the steps: Open Control Panel > Administrative Tools > Services. Now find service named "Print Spooler" and right click over it and select "Restart" to restart the service.
Now open the "Printers and Faxes" folder and try to delete the print queue. Now you will be able to delete the print queue. If applicable you can follow the steps once again if any print queue refuse to get deleted.
Once the print queue is empty, you can print from your printer smoothly.
Cheers!
Apr 05, 2010 | Dell 926 All-In-One InkJet Printer
I am trying to print from my netbook using an hp printer. i am getting an error message saying that the print queue is full.
Yes, printer won't print if print queue is full. The fact is you are lucky your printer is giving you this message. Most printers, when queue is full, will just remain silent and leave you wandering what in the world has gone wrong.
Solution is to clear the print queue. See, when you send to print and you send another when the previous hasn't printed, they queue up. Now if for any reason the first fails to print, all others will just remain queued up but will not print until you clear the print jobs queued up.
To do, this go to start/control panel/printers. Right click on printer icon and select open. The respective print queue box appears. It should have all of the print jobs listed there in the box. On the menu bar click on printer and select "Cancel all documents." A box appears asking you to confirm if you want to cancel, answer yes. Then try to print again. If it still fails to print restart your PC and try to print again.
Dec 06, 2009 | Office Equipment & Supplies
Can not print pdf double-sided on Kyocera FS C5020N
surprised you actually got doublesided... ok... in a situation like yours... I would update to the latest adobe reader... that has been known to give you issues with printing.... and if it continues call kyocera support... this sounds like an issue they would want to work on...
Oct 05, 2009 | Canon ImageCLASS MF4350d Laser All-in-One ...
FS-C5020N just put new toner in, color not print
your best bet with this one.. is to call kyocera support... they might give you a simple answer.. where as a tech will charge you an arm and a leg...
Apr 23, 2009 | Kyocera Mita FS-C5020N Led Printer
Printer queue
I have seen things similar to what you describe. Most likely it is due to a PC setting that retains jobs in the queue. Conceivably, if you have a hard drive in the printer, it is a setting that may be corrected by logging in to the printer's IP address. I have not ever seen it caused by the printer, alone.
Mar 18, 2009 | Kyocera FS-C5030N Led Printer
HP PSC 1410v All-in-One Printer Logo
79 people viewed this question
Seeker5211
Seeker5211
