Question about Teac DV-3500 DVD Player
Region DVD says wrong region. will not play region 1
    Scholar:
  • 135 Answers
Follow these steps to make your DV3500 a region free player. With the power to the DVD player on...
OPEN TRAY
PRESS SETUP
TYPE IN NUMBER SEQUENCE 9 3 0 1 0
PRESS STEP
PRESS SHUFFLE
PRESS NEXT
CLOSE TRAY
POWER OFF
POWER ON
The DVD player should then be region free.
Best of luck!
Posted on Feb 21, 2008
How do i get wrong region off my dvd player so it will play dvds
If you are in region 1 for DVD's you can't play any other region. You have to buy the right region DVD for the player. http://en.wikipedia.org/wiki/DVD_region_code
Dec 27, 2012 | Sylvania sdvd7002 Ref 7" Portable Dvd...
Can't play dvd--wrong region
Commercial DVDs are released with region codes that restricts in which part of the world they can be played. Consumer DVD players sold in those regions are pre-configured with the correct region code for the given sales area. The United States, Canada, Bermuda, and U.S. territories are region 1. Europe (except Russia, Ukraine, and Belarus), The Middle East, Egypt, Japan, South Africa, Swaziland, Lesotho, Greenland and region 2.
sources:
http://forums.techguy.org/miscellaneous-tech/972005-dvd-wont-play.html
Jul 20, 2012 | Samsung Televison & Video
When dvd inserted and play button opperated screen
if you are in the uk on the back of the dvd cover it should have region 2 or region free if any other it will not play like region 1 is usa
Mar 10, 2010 | Audio Players & Recorders
DVD player is saying "Wrong region"
region codes are as follow. Region 1 North America, Region 4 South America, Australia, Region 2 Europe, Region 5 Asia Major,Africa,Region 6 Asia Minor, Probably your DVD is from another region....hope this helps
Jan 01, 2010 | Insignia Televison & Video
DVD's wont play - says wrong region but they are compatible
To change the Region code on your player, open Control Panel - System - Hardware - Device manager, and click on DVD/CD ROM drives, then right click on the DVD drive and click Properties then click on DVD Region.
You can enter a new region and it also shows you how many changes have been made.
NOTE you can make only 4 changes and the player will lock permanently on the 4th change.
If you want to play DVD from any region you maybe able to upgrade the firmware to make it region free BUT if you make a mistake or installed the wrong firmware the player will be a piece of junk.
The best solution to make the player region free is to install a piece of software that allows you to play DVDs from any region. There are several available on the Internet but my favourite is DVD-Region Free
www.dvdidle.com/dvd-region-free.htm
Nov 23, 2009 | HP Pavilion dv9000z Notebook
Says wrong region with some dvd's
Check the owner's manual to see what region your dvd player is for. What ever that region is is the only region it will play.
Example: If you have a region 1 dvd player and a region 4 dvd, it will not play on that player. The regions must match. The dvd usually has the region it is for listed on the back of the dvd case near the bottom.
Also, Any dvd's that are Region 0 or are labelled "Region Free" will play on any player.
Oct 03, 2009 | Sharp DV-SL1500W DVD Player
Have dvd that say check regional code how do i do this ?
sounds like you have purchased the wrong region coded dvd`s when you bought them from amazon? if you are in the US you can only play Region 1, Europe is Region 2 and so on. Unless you purchase a mlti region machine which is obviously not what you want to do then the only other play of playing the wrong region discs is to buy a cheap dvd player which has "DivX" compatability which will play any region for you.
Sep 07, 2009 | Zenith DVT216 System
Trying to play dvd but says wrong region soneynhv-dx350ab?
Hi, if its saying wrong region. then either your player or disk is incompatable. region 1 ntsc ( USA ) Region 2 ( UK ) et,c. check your players region coding is compatable for your country, and that you are also playing a dvd with the same region coding as the player. alternatively is to try and find a region free or multi-region solution. Mike @ Compurepair.
Jun 12, 2009 | LG RC897T DVD Recorder/VCR Combo
Wrong Regional Disc.
DVDs are ecoded with region codes to indicate what area of the world they are made for. These codes may be 1,2,3, etc depending on which region they are made for.
DVD player read these codes and if the disc region code does not match the region the device is made for, the player will not play the disc.
Region 1 is for USA so most DVDp players made for use in USA require region 1 discs.
Some DVD players called multi region DVD players can be set to play different region DVDs but they are typically more expr=ensive then one region players and the code must be changed each time a different region disc is played.
Aug 27, 2008 | Audiovox D1710 Portable DVD Player with...
Region
Probably can't, they are encoded for a reason. If you have a DVD drive on your computer MOST video players will play them.I use Nero and haven't had any trouble.
MM85
Jul 22, 2008 | Teac DV-3000 DVD Player
Teac DV-3500 DVD Player Logo
214 people viewed this question
Top Teac Televison & Video Experts
bengsoon Neo
JOHN TOPLISS
Are you a Teac Televison and Video Expert? Answer questions, earn points and help others
