Question about Bronica Cameras
Fitting lens onto Bronica 2x teleconverter
I can fit Bronica 2x teleconverter-E to ETRSi camera body but am not able to fit lens on to the converter.I have no reference to a manual . must be a simple procedure but havn@ found it yet. Can anyone help?- is there a website with a free download manual?
  • Obertelli
    Obertelli May 11, 2010
    Not all lenses can be used with teleconverters. Which exact lens are you trying to use?
  • 117 Answers
SOURCE: i have a sigma
The rear element of the lens is near the mount the converter
will not fit the conveter needs about 10mm space at the
back of the lens
Posted on May 13, 2009
  • 7 Answers
SOURCE: like to fit my bronica fisheye p e into nikon f 5 camera
The lens you're refering to is the Fisheye-Zenzanon-PE 30mm, yes? As far as I'm aware no Bronica ETR > Nikon F adaptor has ever been made, and if one was to be it would be rather cumbersome.
You're probably better off selling it and using a Nikon Fisheye-Nikkor 16mm 1:2.8 in its place.
Posted on Jul 05, 2009
SOURCE: problem with digital concepts teleconverter
The SX1 has an amazing 20X optical zoom. The teleconverter will allow to get pictures if the camera zoom is not fully on 20X. It means that you can't get a full 40X zoom images, but a 30X maybe. I don't why canon has this problem.
Posted on Jul 20, 2009
Obertelli
  • 3006 Answers
SOURCE: Do they make a converter for cannon len to fit fugi
Depends what you mean.
The Fuji s7000 is a fixed lens bridge camera, so you can't remove the lens and use an adapter and fit other lenses.
All that you can do is to git supplementary telephoto, wide angle and extreme close up (macro) lenses to the filter thread on the end of the lens; if you use what's called a reversing ring you can then (within reason) mount pretty much any SLR lens backwards onto the front of yours. The reversing ring screws into the filter threads of each lens and will be quoted in two sizes: these will be whatever the filter thread diameter is on each lens. By mounting a lens backwards, you effectively end up with an extreme macro lens, but it all depends upon which lens you choose. The reverse mounted lens will just be a dumb bit of glass, there will be no focus or aperture control and no communication of any information back to your s7000.
Hope that I've helped, if so please rate my answer.
Posted on Feb 22, 2010
Obertelli
  • 3006 Answers
SOURCE: cant seem to fit the converter to a 50-500mm ex sigma lens ?
It all depends upon the lens. Not all lenses can accept teleconverters, usually due to projecting rear elements incorporated into the individual lens design. With such lenses, manufacturers will either advise that a particular lens will not be compatible with a teleconverter or for some models may produce a custom matched model usually for that lens alone.
Which exact lens are you trying to fit to your Sigma 1.4x EX APO DG teleconverter?
Posted on Feb 23, 2010
Where can I get a 2x converter for rear fit to pentaxZ-10 "?"
This camera uses KAF2 mount or earlier K mount teleconverters. Search "KAF2 teleconverter" on eBay and you'll see dozens of them ranging from $10-$20.
Hope that helps
BAX
Apr 24, 2014 | Photography
Will a quantaray AF LD 55-200mm lense work with a 2X teleconverter?
Well, this teleconverter would act as a magnifier to your lens. If you get a 2x teleconverter, it will double your zoom. so you'd then have a 110mm-400mm lens. The teleconverter is attached to your camera first, then the lens on to the converter. Make sure if you get a teleconverter that it's an autoteleconverter. Which means that it will allow you to still use autofocus. I would also make sure you get a name brand that has good glass because some converters will tint your images to a yellow ish haze that would require a whitebalance adjustment.
Jun 03, 2012 | Quantaray Cameras
How do i attach the my zeikos 52mm HD Dslr MC AF 2x telephoto lens to my nikon d90?
You don't. The Zeikos attaches to the front of lens with a 52mm filter thread, which then attaches to the D90. If you have the 18-55mm lens, for example, this will fit onto the front of that lens, effectively converting it to a 36-110mm lens. If you have the 18-105mm lens, this won't fit onto it.
This device is really intended for use with cameras that don't have interchangeable lenses. With your D90, you're much better off using another lens instead of putting this onto the front of another lens.
Feb 13, 2012 | Zeikos ZE2X52B 52mm 2X Telephoto Lens
Inherited bronica etrsi camera, removed lens and now cant get it back on, dont have manual, please can you advise. thanks barb.
A. To attach the lens to the main body, align the red dots on the lens
and the main body and then insert the lens fully into its mount.
Rotate in the counter-clockwise direction until it stops, with an audible
click, which will indicate that it is securely locked.
http://www.tamron.com/assets/pdfs/ETRS.pdf
Aug 20, 2010 | Bronica Cameras
C-af 1 2x teleplus mc7 will not auto focus with my 90-300mm canon ef lens on my canon d7 dslr. can you help please.
Teleconverter loses maximum lens speed.
With 2X teleconverter, your 90mm-300mm f4.5~5.6 will become something like f8~f11. Most SLR AF cameras need maximum aperture of f5.6 to autofocus so by using the 2X teleconverter on this zoom lens, it will not autofocus, because the lens's light gathering became too low.
Here is more information about using teleconverters.
http://tinyurl.com/29s5osk
Jun 09, 2010 | Kenko AF 2x Teleplus MC7 (AF2X7DGN) Lens...
Cant seem to fit the converter to a 50-500mm ex sigma lens ?
Feb 05, 2010 | Sigma 1.4x EX APO DG TELE CONVERTER (CANON...
Just got a 2x teleconveter and need instructions for install and removal
Pretend the teleconverter is a camera, and mount a lens onto it. Then treat the lens and teleconverter as a single lens, and mount that onto the body. It effectively doubles the focal length, and robs you of two stops. Depending on the teleconverter and lens, you may or may not lose autofocus and metering capabilities.
Feb 04, 2010 | Photography
I have a sigma apo 1.4x DG teleconverter for pentax it does not seem to fit any of the pentax lens i have. do i need an adapter or different teleconverter?
back of the lens
Jan 23, 2009 | Sigma 1.4x EX APO DG TELE CONVERTER (CANON...
Like to fit my bronica fisheye p e into nikon f 5 camera
Oct 25, 2008 | Bronica PS Zenzanon (1.4x) (bq1275) Lens...
Cameras Logo
90 people viewed this question
Top Bronica Cameras Experts
Steve
Are you a Bronica Camera Expert? Answer questions, earn points and help others
